Old 09-08-2008, 01:51 PM   #1
phantomworks
phantomworks is on a distinguished road
No more adjustment on TPS
I have installed a new TPS on my car and I've run out of adjustment?.
While adjusting the TPS I'm getting the proper closed/narrow voltage readings but when I try to adjust the TPS to get my WOT voltage correct I can't get anymore then 3.58 and 3.84.
The TPS will not rotate anymore on throttle body, I checked the throttle cable adjustment and it"s fine and the TPS was installed correctly.
What do you guy's think?
phantomworks is offline   Reply With Quote
Old 09-09-2008, 07:38 PM   #2
Spindoctor
Spindoctor's Avatar
Spindoctor is on a distinguished road
Sounds like the tabs may be on the wrong side....take it off and reinstall it
Spindoctor is offline   Reply With Quote
Old 09-09-2008, 08:09 PM   #3
phantomworks
No they are not on the wrong side, In fact I took it off and reinstalled it again today with the same results.
Old 09-09-2008, 08:22 PM   #4
bad TPS? I don't understand, the screw just won't turn anymore?
Old 09-09-2008, 09:15 PM   #5
phantomworks
Brand new TPS from Ray Crowe, I hope it's not bad. The TPS won"t rotate anymore on the throttle body.
I'm wondering if there is just a voltage drain on the system. maybe a bad ground?
Old 09-10-2008, 08:42 PM   #6
Spindoctor
Spindoctor's Avatar
Perhaps you could remove it one more time and run it through its limits detached from the TB to see if it's even capable of reaching specified voltages. That may rule out a few things right off the bat. Is the harness in good condition? Have you tried probing the wires right at the connector?
Old 09-11-2008, 12:47 PM   #7
phantomworks
Great idea I'll try it off the throttle body, thanks.
I'm probing right where the wires go into the connector
Old 09-13-2008, 05:08 PM   #8
cewrx7r1
The Judge
Are you opening the throttle 100%?
If you are not doing it manually at the TB, you can't ber sure unless you have had your linkage checked out.
