Go Back   Rotary Car Club > Tech Discussion > RX-7 3rd Gen Specific (1993-2002) > Archives
Archives Where all the stickies are
Old 03-03-2008, 11:59 PM   #1
ObliqueFD
ObliqueFD's Avatar
ObliqueFD is on a distinguished road
Resource Websites
Here is a list of websites with RX-7 specific information for modifying and diagnosing issues with your RX-7. Feel free to add to the list.
http://www.fd3s.net
http://www.robrobinette.com
http://www.maxcooper.com
http://www.clubrx.org
http://www.wrex-racing.com/web/fd/info.htm
ObliqueFD is offline   Reply With Quote
Old 03-04-2008, 09:06 AM   #2
RXtacy
RXtacy's Avatar
www.turborx7.com
www.autosportracetech.com/RX-7/rx7stuff.htm
Old 03-04-2008, 10:30 AM   #3
Brent
Sua Sponte
Brent's Avatar
Keep it up guys!! I'm the 3rd gen section moderator and I'm working on putting together a huge resource thread that will be a sticky. Looking real good so far.
Old 03-04-2008, 06:19 PM   #4
RXtacy
RXtacy's Avatar
Great detailed reading about the rotary engine.
Kenichi Yamamoto Rotary Engine
Newby info / Buyers guides
Rx7Voodoobox.net
Marx7.org
epinions.com
Old 03-04-2008, 07:55 PM   #5
RXtacy
RXtacy's Avatar
How to read the parts fische
How to find Mazda Part Numbers
A lot of people ask for Mazda part numbers, when in reality they can find them even faster.
First, download the parts list for your model year. 96+ guys, good luck so far nobody has made those parts lists available.
In this example, I will find the part numbers for the relays mounted to the ABS unit.
Now open the PDF, skip past the first page, and look thru the pictorial index to find the section where the part will be. If you're looking for several different parts, it can help to jot down the section numbers. Be patient - this step is hardest since it's not always obvious which section has the part, and there are many sections. It will become less of a problem as you get to know how Mazda organized the parts.
Pictorial Index:
OK, the first page of the index is just engine and drivetrain parts. If you keep going, you'll find the section with the braking system.
Here it is: the ABS unit is in section 4370.
So scroll thru the whole PDF, looking at the section numbers on the top of each page until you find the right one. Some downloaded versions are divided into 3 files, so you may need to open a different file to get to the right section.
The scan quality of these parts lists isn't great, so it really helps to set the zoom of the document to 100%, 150%, or 200%. Anything in between just makes it harder to read.
Dig around and look thru the picture for the parts. Sometimes the illustrations are a little rough or crude. Also note that for some sections, the illustrations are spread over more than one page.
Here we see a couple of boxy shaped things that resemble the relays. Their position codes are 43-7A3 and 43-7A2. This is not the Mazda part number, but you're almost there.
Now look up those numbers in the right hand column. We see for part position 43-7A2 that it's a "Relay, Motor Hydraulic Unit". The Mazda part number is NA23-43-7A2, and there is a quantity of (1) per car. The second relay is listed right below it.
If the part is a fastener, it will have the Mazda part number listed beside it in the picture. For example: 99940-0801. These numbers can be the hardest to read, so it sometimes helps to check the same illustration on another page.
Pay attention to any notes about manual vs. automatic transmission, and option packages. "Hard susp." = R1 or R2 package.
Sometimes there are different versions based on the VIN number of the car, in which case you should know the VIN and look to the bottom of the parts page to see which one it should take. If it's an interior part you will need to choose a color suffix "-00" or "-02". These get added to the Mazda part number, for example "FD18-88-111-02".
If you want a price, take those numbers to a site like www.mazdapartscheap.com and enter it into their parts number search. You'll then get prices, and if the part has been updated since the parts list was scanned, an updated number too. If you choose to order from another source, use the updated (supercede) part number, although the dealer can use either one.
All info courtesy of dgeesaman.
Old 03-04-2008, 11:36 PM   #6
Cp1
Cp1's Avatar
Unauthorized Image Linking
"For access please contact Ryan@rx7.com"
LOL
Old 03-04-2008, 11:57 PM   #7
RXtacy
RXtacy's Avatar
Ha funny thing is I had permission from dgeesaman too...
Old 03-06-2008, 04:22 PM   #8
7_rocket
7_rocket's Avatar
7_rocket is on a distinguished road
Sticky this thread
http://www.rotarydynamics.ca
7_rocket is offline   Reply With Quote
Old 03-06-2008, 06:45 PM   #9
Brent
Sua Sponte
Brent's Avatar
Originally Posted by 7_rocket View Post
Sticky this thread
Done. Eventually this thread will be merged with a couple of other threads as a super resources/FAQ thread. Keep up the good work guys.
Old 03-15-2008, 12:37 PM   #10
charlies7
one broke moderator
charlies7's Avatar
charlies7 is on a distinguished road
For those looking to find good rebuild dvd's check out:
atkinsrotary.com
also try and find a copy of DIY 13B-RE
charlies7 is offline   Reply With Quote
Old 03-19-2008, 09:06 AM   #11
Signal 2
Viable Fossil
Signal 2's Avatar
Lately this has been my personal favorite...... http://rotaryengineillustrated.com/ Informative short videos.
Old 03-26-2008, 05:05 PM   #12
RXtacy
RXtacy's Avatar
http://reganrotaryracing.tripod.com/rx7main.htm
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-27-2008, 05:11 PM   #13
RXtacy
RXtacy's Avatar
http://rotarygod.com/index.php?title...ry_Engine_Wiki
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-24-2008, 02:16 AM   #14
Teenwolf1393
Teenwolf1393 is on a distinguished road
memphis im gonna go ahead and give you a giant list, a list thats been in the making for a few years now. this is almost all the sites ive found with parts for your RX7.
umm i didnt read the post very well so not exactly what your looking for. but god damn someone should sticky this post alone.
www.rotorsportsracing.com
www.racingbeat.com
www.rx7store.net
www.srmotorsports.com
www.gothamracing.com
http://www.2kracing.com/Model/Mazda/RX-7.html
www.topspeedauto.com
www.FDNewbieimports.com
http://www2.ocn.ne.jp/~knight78/over...x3_oversea.htm (knightsports in english)
http://www.fujita-eng.com/fd3s/index_2.html (FEED, not translsted)
www.sp-power.com
www.corksport.com
www.Pineappleracing.com
www.speedmachineperformance.com
www.mazdaparts.com
www.turblown.net
http://www.re-amemiya.co.jp/commodity/ (not translated)
www.japanparts.com
http://www.endless-sport.co.jp/index.html
http://mrcmfg.com/catalog/index.php (RE-Speed)
http://www.rotaryresurrection.com
http://www.fuji-racing.com/
www.banzai-racing.com
http://www.ksp-eng.co.jp/ATTAIN/menu2/5.html (KSP, Attain, Real)
www.evo-r.net
www.tamondesign.com
www.rx7world.com
www.dm-spec.com
www.mazdamaniac.com
www.rotary13b1.com
www.buymazdaparts.com (Trussville Mazda)
www.pettitracing.com
www.rotaryshack.com
www.good-win-racing.com
www.rotaryresponse.com
www.mariahmotorsports.com
www.rotaryextreme.com/intro.html
www.AtkinsRotary.com
www.bnrturbos.com
www.RicksSpeedShop.com
www.RotaryRebuildStore.com
www.rhdjapan.com
www.revvinsevens.com
Now i DEMAND a MILLION forum bucks
Teenwolf1393 is offline   Reply With Quote
Old 12-24-2008, 01:05 PM   #15
RXtacy
RXtacy's Avatar
That should be Rx7Store.net
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
