Old 07-28-2008, 03:00 PM   #1
s5 turbo stock wastegate question
heres the deal:
s5 n/a block with complete stock turbo setup.
boosts 5-6psi max
If I plug the wastegate line it will hit 10 (before I backed off)
would that be a weak wastegate spring??
If so, I was thinking about a boost controller or just replacing the wastegate... my plan was always for 9-10 max. what would be the best way go?
anyone have a spare wastegate actuator?
Old 07-28-2008, 03:09 PM   #2
TehMonkay
port the wastegate.
Old 07-28-2008, 03:24 PM   #3
Monkey, how would porting help? Its already ported which we think is the problem...The stock spring is like 7-8psi, but a 7-8psi spring starts opening earlier to maintain 7-8psi....With a ported wastegate, it takes less actuation to achieve the same wastegate venting so by the time you reach 5-6psi, its already opened as far as a stock gate at 7-8psi.
Old 07-28-2008, 04:11 PM   #4
TehMonkay
ahh, read that completely wrong.
Yeah just try another actuator, unfortunately i dont have any of those though.
Old 07-28-2008, 07:15 PM   #5
No problem man, you just had me really confused lol
Old 07-28-2008, 07:38 PM   #6
Turbo vw
i know i cant spell
Turbo vw is on a distinguished road
thers some way you can rig a spring on the out side of the wast gate to make it open sooner IDK a guy on a nother forum had one set up for some sort of bild he was doin but if i was you id just git a new wastgate make ur life a hole lot easer
Turbo vw is offline   Reply With Quote
Old 07-28-2008, 07:49 PM   #7
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
why not just use a boost contoller, manual or electric
Old 07-28-2008, 08:05 PM   #8
I was wondering the same thing. I figure the wastegate was faulty since he didn't metion anything about a boost controller.
Old 07-28-2008, 09:18 PM   #9
I did mention something about a boost controller... about possibly using one if that was the best alternative...
I'm not using a boost controller and the wastegate is ported.
Old 07-28-2008, 09:29 PM   #10
There ya go Paul...Making things all confusing like
Old 07-28-2008, 09:41 PM   #11
no i'm not... people don't pay attention
Old 07-28-2008, 09:50 PM   #12
TehMonkay
as long as you didnt go too big on the porting, or perhaps you need to adjust the actuator? I think there is an adjusting nut, dont blame me if i'm wrong though.
Old 07-28-2008, 10:03 PM   #13
i don't think its a porting problem because when I didn't hook up the wastegate it boosted past 5 easily
Old 07-28-2008, 10:17 PM   #14
I think you will have this problem with any stock actuator, bigger wastegate porting will cause this regardless IMHO. Get a boost controller
Old 07-29-2008, 08:29 AM   #15
TehMonkay
if he plugs the wastegate line, it should go past 10 no problem, theres something else wrong that a boost controller cant fix.
