Old 12-12-2018, 06:02 AM   #1
Change out your stock intercooler hose(s)
When it rains, it pours...
After rebuilding my turbo, I was disappointed that it made no boost!
Turning the Rotating Assembly was rather stiff, so I thought the RA just seized from too little clearance, or I used too much Loctite green.
Boy, was I relieved it was a leaking intercooler hose...
The part is 30+ years old.
I used a rather strong t-bolt clamp that caused the tear.
The car used to see boost up to 15psi (via a boost controller).
The car regularly sees 10psi of boost for the past several years...until this happened.
I guess I can't blame the hose for failing...
I've replaced it with an eBay find, silicone unit.
Since this is an early Zenki model, I did pick up a 2" to 1.75" 90-degree hose which fit everything fine.
I really should get the FMIC up and running... :P
Old 12-12-2018, 12:45 PM   #2
chibikougan
chibikougan's Avatar
Yeah I think Samco still has the cooler hoses mebbe..
I remember doing this with a buddy had the rear pop off... Thought it went pop.
