Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 02-13-2017, 04:06 PM   #31
chibikougan
chibikougan's Avatar
Fun TidBit
https://www.boltdepot.com/fastener-i...iandpitch.aspx
Old 09-06-2018, 10:12 PM   #32
Nwar
Nwar is on a distinguished road
Fly Wheel Nut thread pitch spec?
Read the info in the first couple of posts.. there is mention of the fly wheel nut being 54mm Hex wrench size but NOT the thread pitch specs. Anyone have that info? Presume it is the same as the eccentric shaft end threads, but I didnt find that also.
Someone?
Also;
Tension bolts(Short ribbed #10-E51B-N350) - M10 x 1.0P threads, thread Length is about 57mm from end, 281mm OAL, 274.5 Stem Length(including threads), 17mm HEX Wrench head size.
Dowels - For 1 piece solid Length is 230mm, a good bore for a 1 piece drilled dowel is 8mm.. since the oil galley of the front is less than 5/16". You can add a 10mm Length of thread, M8 x 1.25P, on one side for removal purposes for the solid and drilled.
Nwar is offline   Reply With Quote
