Closed Thread
Old 05-17-2017, 09:18 AM   #256
It'll never fit!!!!!!!!!!
Oh wait, nevermind. Looks good, want to hear some brap!
TitaniumTT is offline
Old 05-17-2017, 05:32 PM   #257
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Bullshit! I can make it fit, I has torch and am not afraid to use it.
Pictures of it installed, which should shed some light on why it is such an oddball shape and size.
view from the bottom of the car ...
middle muffler mounted (bottom) by Kevin Frank, on Flickr
passenger side ...
middle muffler mounted (passenger side) by Kevin Frank, on Flickr
driver's side ...
middle muffler mounted (driver's side) by Kevin Frank, on Flickr
GySgtFrank is offline
Old 05-28-2017, 09:35 PM   #258
GySgtFrank
GySgtFrank's Avatar
Over the axle pipe is welded up. All the different turns, bends and little whoop-te-doos for clearance made it look like something Dr. Frankenstein would have come up with. Just need to smooth the remaining welds to check for pin holes, then get paint on it. At that point this tour in building the world's most frustrating exhaust should be finished.
Over the axle pipe 1 by Kevin Frank, on Flickr
Old 05-29-2017, 07:45 PM   #259
GySgtFrank
GySgtFrank's Avatar
... and done.
Over the axle pipe - finished by Kevin Frank, on Flickr
Old 06-07-2017, 08:12 PM   #260
GySgtFrank
GySgtFrank's Avatar
I got the exhaust system bolted together and everything fitting. I only had one area where I had to clearance some of my previous work on the gas tank surround for clearance on a flange.
Over the axle pipe bolted and in final position. Lots of odd bends and offsets to make this work.
Over the axle pipe - bolted in by Kevin Frank, on Flickr
This is about the best shot I can get of the entire exhaust system finished and bolted together without putting it on a lift. (which I do not have anyway)
exhaust system - finished by Kevin Frank, on Flickr
Old 06-07-2017, 10:57 PM   #261
FC Zach
FC Zach's Avatar
That's a lot of work! Good job!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 06-08-2017, 07:53 AM   #262
GySgtFrank
GySgtFrank's Avatar
Thanks. It was a lot more involved than I thought it would be when I started on it ... as usual.
Old 06-17-2017, 01:35 PM   #263
GySgtFrank
GySgtFrank's Avatar
Dash is stripped of padding so I can try to build a template. Trying to make the FC instrument cluster fit in here somehow, along with a tilt column from a 1986 Mustang. It's going to be a challenge, that's for sure.
Dash work by Kevin Frank, on Flickr
Old 06-23-2017, 05:47 PM   #264
GySgtFrank
GySgtFrank's Avatar
Stainless steel dash roughed in and bolted.
Dash - roughed in by Kevin Frank, on Flickr
Old 06-25-2017, 08:57 AM   #265
hades
Good job.
This is going to tear
hades is offline
Old 06-25-2017, 10:18 AM   #266
Nutsid
Temporarily insane.
Nutsid's Avatar
Great job Mister, mister.
Kindle
Nook
Nutsid is offline
Old 06-25-2017, 11:32 AM   #267
GySgtFrank
GySgtFrank's Avatar
Originally Posted by hades View Post
Good job.
Thanks guys, more pictures to come as I figure out how to make this thing actually fit in there. I have found that the 16 gauge stainless steel sheet is a lot harder to work than a mild steel equivalent. I've heard that, but never had much call to work with stainless steel before. I had to do some repairs to my plasma cutter to get it cut out as it's a bastard to do any other way.
edit:
...and the doors close! Getting those ends trimmed and hammered into shape for this to happen only took me a large chunk of the weekend, but success at last.
Old 07-08-2017, 11:46 AM   #268
GySgtFrank
GySgtFrank's Avatar
progress report ... slow with a strong chance of cussing storms. I need to weld in some finishing bits to make it all look integrated with the car.
Dash work 1 by Kevin Frank, on Flickr
Dash work 2 by Kevin Frank, on Flickr
The bolts will eventually be replaced with SS allen head button screws like I have bolting down the sides of the dash. I plan to adhere a sheet of walnut to the steel when I have the face of the dash in final configuration. The foot well sides are to be covered in carpet.
Old 07-09-2017, 03:09 PM   #269
Nice work on that dash!!
speedjunkie is offline
Old 07-10-2017, 08:25 AM   #270
GySgtFrank
GySgtFrank's Avatar
Thanks, beware - sharp edges cut the shit out of you while reaching up underneath to work on stuff. Who'd'a thunk?
Closed Thread
