Old 03-16-2017, 10:20 AM   #331
RXtacy
RXtacy's Avatar
Dyno with and without. Air temps won't be an issue because on the dyno the hood will be up and airflow across the filter will still be there. Trick will be mounting the 7" ID on the filter to the turbo... although for testing you could just get a slightly different filter that will fit over the vanjen on the turbo
Not sure I care enough to go through the effort.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-27-2017, 09:15 AM   #332
RXtacy
RXtacy's Avatar
A lot of work happened this weekend, but not a whole lot to show for it. That's how it goes sometimes.
I had to redo the -16 AN fitting locations on the radiator, WP housing, and filler neck due to interference with the AC pulley and for line routing. I guess it helps to have all the parts in the car when you are mocking things up
Not pretty but they should work.
Once I got those finalized I made up the radiator lines (didn't grab any pics). Then I was able to finalize the duct mounting.
Only grabbed a pic midway through, but both sides are done now.
And I was also able to mount the oil thermostat. Again no pics.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-29-2017, 04:22 PM   #333
Looks awesome! Nice work!
Old 03-30-2017, 10:32 AM   #334
RXtacy
RXtacy's Avatar
Thanks!
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-31-2017, 09:52 AM   #335
knonfs
knonfs is on a distinguished road
AGREE!
It might not be weld porn, but when its a DIY and it works... to me that's 100% better than weld porn
knonfs is offline   Reply With Quote
Old 04-03-2017, 09:04 PM   #336
RXtacy
RXtacy's Avatar
Got some small items finished off this weekend. Finalized all the coolant fittings and hardlines on the WP housing and turbo, fixed the -6 AN vacuum bung on the UIM and prepped a bunch of stuff for powder coat. Also got the exhaust figured out and the mid pipe fully tacked and ready to final weld. Just need to cut one more piece for the rear section and it's ready also. At this point effectively all of the fab work is done. Just need to run the AN fuel lines, oil lines, and PS lines and slap everything back together. Then the only thing left is finish pinning the engine harness and make the aux harness and jumper ECU harness.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-10-2017, 09:18 AM   #337
RXtacy
RXtacy's Avatar
It's been a long time since I've had a chance to work on the car, but we got a good weekend in.
I got the 4" exhaust finished up and hung.
Got started on the powder coating (still a lot more to do), and Brian banged out the oil cooler lines and a bad ass PS cooler mount.
I also got the ECU harness fully pinned, but no pictures of that.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-10-2017, 09:23 AM   #338
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Very nice. Much prettier than mine.
Old 07-10-2017, 09:44 AM   #339
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Sexy. I love how it's looking man!!!! I *really* need to get my ass in gear so I can slide in to Brians box, err.. garage, once you're done!! I'd love to get some sloppy seconds after you're finished.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-10-2017, 10:02 AM   #340
RXtacy
RXtacy's Avatar
Thanks Kevin. Routing looks like it was much easier on mine
I like your dash btw.
Thanks Levi.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-10-2017, 10:40 AM   #341
GySgtFrank
GySgtFrank's Avatar
You weren't stupid enough to try to stuff an EFI rotary in a Matchbox car.
Thanks on the dash, it's taking some thought to try and fit the gauges and controls in there and still look like it's supposed to be that way. We'll have to see if I'm successful.
Old 07-10-2017, 11:25 AM   #342
Pete_89T2
Pete_89T2's Avatar
Looking good there Mike! Now stop distracting Brian so he can get back to fixing my harness
Old 12-18-2017, 08:29 PM   #343
RXtacy
RXtacy's Avatar
Well it's been quite a while since I've updated this. A lot has happened over the last 6 months or so. Not as much of it on the car as I would prefer
I picked up a new toy and have been enjoying tracking it over the summer.
Oh, I also got engaged
I haven't had a lot of time to get up to work on the car, but we've made some good progress.
Got the rest of the powder coating finished, and all the engine accessories are getting on for the last time! Still need to fabricate an overflow and washer fluid tank, finish the wiring , make a turbo drain line, and mount/plumb the wastegate solenoids. Sounds soo simple when you type it out
Brian did a killer job on plumbing the oil coolers, and the hardlines for the PS cooler. He's also been putting in work on the wiring which is much appreciated and has stayed my murderous desires every time I look at the fucking wiring.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 12-18-2017, 08:37 PM   #344
GySgtFrank
GySgtFrank's Avatar
Coming along nicely. I would say something smartass about progress and geological epochs, but I seem to have too many damned windows in this house for rock throwing.
Old 12-18-2017, 08:58 PM   #345
RXtacy
RXtacy's Avatar
Said comment would be well deserved
I could retort with something along the lines of perfection takes time, but that would be too arrogant even for me
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
