Old 03-06-2017, 04:48 AM   #181
FC Zach
FC Zach's Avatar
So I swapped the clutch and installed the rebuilt transmission this weekend. The Centerforce Dual Friction I removed appears to still have a lot of life left on it, is there still a market for these? I'd sell it cheap if there's any interest in it.
I am waiting on oil I ordered from my AmsOil guy and an output shaft seal from Atkins Rotary to arrive so I can button everything up. I tried getting this seal locally from Oreillys but for whatever reason neither of the manual or auto seals were correct. . They couldn't cross-reference it either but luckily Atkins pulled through
I had to remove the fancy coil mount kit to remove the long starter bolt and as I laid it to the side I felt something protruding from one of the coil-to-plug adapters. . here's what I found:
One of the detents for the plug weren't seated completely and the bad connection caused it to get hot enough to melt almost completely through the plastic housing.
I'm no longer going to be using the COP adapters and will be replacing them with tailored wired. I'll still use the coil mount, just not as it was intended.
Since the power harness was mostly disconnected, I completely removed it with hopes of replacing it with a new harness (mine is in very rough shape). I contacted Chris Ludwig to see if he can do this, if not does anyone have any recommendations on where this can be built or purchased?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-06-2017, 02:07 PM   #182
Bring it to DGRR and wait for someone to blow a turbo clutch and sell it expensive. Of course I'll be the one looking for a clutch
Ruh Roh!
I responded in your Alt thread.... otherwise there's always buying a new one for like $400.... they're still available per MazdaMotorsports
Old 03-07-2017, 12:51 AM   #183
FC Zach
FC Zach's Avatar
HaHa noted
Ruh Roh!
Fixed I had extra MSD Super Conductor wire from previous builds but unfortunately had to scavenge from a new box for 8 boots and terminals
Sweet, thanks! that may be a better option. . . probably cheaper too. When you say "MazdaMotorsports", like a dealership?
Trans seal arrived while asleep today and oil picked up from Amsoil guy, will hopefully get this done in the morning.
Before going to sleep today I installed my shifter and ran through the gears but couldn't get it to go in fifth or reverse I don't recall the engine having to be running to go in these gears. . could this simply be gears not aligned to allow the hub to slide in position? ?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 09:28 AM   #184
HaHa noted
Too bad they didn't live longer. I would've been curious to see if they made a real world difference in power on the dyno. Ironically.... well.... was it a leading or a trailing that took a shit?
Negative, like MazdaSpeed, factory parts from shipped from Canada for dealer wholesale. Need to have legit race results though to qualify
Not usually. I would drive that bitch quick in case something is fuxored with the trans. That cost me DGRR '10 was a bad rebuild on a tranny. Couldn't get 5th or 6th and then it jammed in fourth and I rage quit
Old 03-07-2017, 10:53 AM   #185
FC Zach
FC Zach's Avatar
That one was a trailing but looking at the discoloration of the contact on another plug (L2) it appeared that it could have started on another. I'm not knocking on the design since it was retrofitted to work on a 2nd gen 13b but I'd still say some of it is design flaw.
Well, I guess this isn't an option. Thanks for getting my hopes up
Before going any further and completely wasting my time by reconnecting drive shaft, heat shields, exhaust. . . As well as wasting $60 in Amsoil and that damn seal I searched around for. I started it up (I did have to reinstall that janky harness though) and tried shifting with the engine idling, still no luck man what a last couple of days! Nothing is going right, I almost fell through the ceiling Sunday afternoon! Got a hole in the bedroom to prove it LOL. . . This too shall pass!
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 11:19 AM   #186
infernosg
IT'S ALIVE!
infernosg's Avatar
Holy crap on the COP adapters! I guess it's a good thing I never worked out a mounting scheme. Hopefully this is just indicative of the "variation" of the IGN-1A coils and not Peter's work. I'll stick with my coils mounted on top of the engine for now.
Old 03-07-2017, 11:25 AM   #187
FC Zach
FC Zach's Avatar
I believe it is a coil issue, I had to modify the adapters to snap in place.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 12:43 PM   #188
That's so unfortunate about the trans
Well shit, at least there's time and it's not 02:00 on Friday Morning the day before DGRR
Old 03-07-2017, 12:44 PM   #189
FC Zach
FC Zach's Avatar
True
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 02:02 PM   #190
FC Zach
FC Zach's Avatar
Good news guys! ! I found the problem! The shifter housing spring loaded return and detent weren't assembled correctly and prevented the shifter from moving on that side. I took it apart and the lever shifted freely into both gears! It's beer thirty now!
So happy I don't have to remove and replace another tranny
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 02:17 PM   #191
WOOT for easy fixes! If only my trans were that easy to fix
Old 03-07-2017, 03:34 PM   #192
FC Zach
FC Zach's Avatar
I'm glad it was an easy fix, sure did save me a lot of headache! Now the search continues for the power harness. Oh yeah, I still gotta fix that alternator issue too.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-07-2017, 04:17 PM   #193
I just keep laughing because I compare it to my todo list for DGRR and it's like....
RX8 - Pull engine and blah blah blah blah exhaust blah blah blah blah rear tires blah blah blah blah new windshield blah blah blah blah
RX7 - Swap rear diff blah blah blah blah swap tranny blah blah blah blah new driveshaft blah blah blah blah headlights blah blah blah blah DYNO!!!!!
Old 03-07-2017, 05:38 PM   #194
Every time I talk to you on the phone lately, you've been like....
Blah blah blah I'm drunk
Blah blah blah blah I'm about to get drunk
Blah blah blah herp derp I'm working on Pete's FC
Old 03-07-2017, 07:33 PM   #195
Pete_89T2
Pete_89T2's Avatar
I suppose that's why he needs to be drunk!
