Old 02-24-2017, 12:19 AM   #31
FC Zach
FC Zach's Avatar
Thanks Brian! That is a good explanation for me especially since I will most likely be wiring this from scratch, I'll need something for reference material. After I got off the phone with you I just couldn't go to sleep without inspecting more. Even though we were positive it doesn't contain these wires I checked an extra engine harness (passenger side) that I had laying around and it was loaded with 'T' shaped connectors so I just threw that back in the box. . . I looked for possible remains my OE two pin alternator connector by peeling back the loom on the drive side harness, still nothing. It wasn't there but what I did find was that my alternator was warm (this was after leaving that connection I made on the previous page connected for what, a couple hours?). . Looking into that, I found that I had the 'L' terminal (for dash) connected straight to battery, definitely not right.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 02-24-2017, 12:29 AM   #32
FC Zach
FC Zach's Avatar
The Bob Skelly link I BELIEVE is the one I was telling you about
That link is dead
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-25-2017, 02:37 PM   #33
1) The 12VDC reference wire (which you call a "pin") needs to be connected to +12VDC constant, direct to the battery.
This is applicable to the FD and Kouki FC alternator circuits; prior to that, the Zenki FC alternators were only wired to switched +12VDC.
This tells the alternator what the status of your battery is.
Try not to connect it to the +12V post off the alternator, cause it'll be higher than the battery + post, and there's chance that you get back EMI from the alternator operation - this is why you don't see the OEM's wire it to there, even though it's a short shot.
2) The other pin is for the idiot light.
Like others who have already said, it's not necessary to connect this to anything.
This just completes a circuit (to ground?) so your idiots lights light up when the alternator fails.
As for your problem...
I had the old silverrotor FD alternator, and it always had a major drain with the engine off.
I bandaided the situation by resetting my circuit breaker anytime I left the car off overnight.
I traced the problem to the alternator sense field not dropping even after turning the ignition key off; for some reason when I dropped the +12V reference, this would drop the field and killed the excess current draw immediately.
I just chalked it up to a crap rebuild (these things were rebuilt by silverrotor by some shop).
Once I replaced with another unit, I NEVER had that problem anymore.
So it's quite possible you're in a similar situation.
It could be possible that you have a shorted diode in the rectifier, which would cause the alternator to keep draining voltage with the engine off too.
I've fought this problem with my MX83 alternator, because I think the 15VDC+ levels my battery charger was giving it when I had to jump it.
In this situation, every time you reconnected the alternator, the current draw would always be too high.
It's very easy to troubleshoot these things, as you need someone to measure current - most DMM's do this.
Old 02-25-2017, 03:21 PM   #34
FC Zach
FC Zach's Avatar
Pin/Terminal. . . whatever, you know what was being referenced. But yeah, I am redoing the wiring now.
That's what I thought too but is contradicting to what others have said. Some say it has to be connected and others say not necessary. .
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-26-2017, 09:41 PM   #35
FC Zach
FC Zach's Avatar
I'm afraid I will still have some sort of issue even after making the proper connections. . . I drove for far too long without the 12v reference wire connected. I added new leads to the connector, now to make the connections once I find the easiest/best route to take.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 11:48 AM   #36
As odd as it is, I have close to zero experience with the S4 stuff as I never had any problems with the S4 alt because everything was virtually stock. It wasn't until I upgraded to the FD Alt that I started having issues. Much like you Ted, when I started with the FD alt, it was rebuilt by IRP and never worked right, I too blamed a shitty reman, although as it turns out, that probably wasn't the problem
Regardless, in this case with Zac, he's running an FD Alt and it needs to be connected straight to the battery, not a switched source as is already there, so that is definitely problem 1 in Zac's case
The EMI I hadn't thought of, that's a valid point. In all the searching when I was having all of my issues, the general consensus as to why that singular wire is run back to the battery is because we're altering the output of the alternator based on what that sense wire is telling us. Just because it's 14.4V at the charging post, doesn't mean that it's 14.4V at the battery and that can be due to a variety of reasons.
This is where I disagree. This could very well be the case for the S4 alts but it is NOT the case for the S5/S6 alts. The later years NEED the idiot light pin to be hot when the key is on and the alt is spinning. If not, it will die an agonizing death.
Again, I don't have the knowledge of the S4 alts just because I NEVER had a problem with mine because stock, but when I did the Cosmo swap and the S6 alt upgrade, I had issues for about 5 years... literally... because I was only running one switched wire to the alt. The death was always the same, it would start overcharging and eventually kill itself and the battery.
Also, with only the one wire for the alternator connected to a key hot, when the ign switch is off, the Alt would kill the battery in a matter of days.
Again, much like you, Ted, I solved that problem by flipping the breaker everytime I got out of the car - NBD
It sounds like it was a bad alt and it was pulling through the relay/idiot light and keeping the alt energized which would quickly kill a battery.
The "Sense" wire, the S wire, in the S5/6 is connected straight to the battery. It senses the voltage and adjusts the output of the alt to attempt to feed the battery the needed 14v. On the S4's it's called the R terminal, and that gets fed to the B/W wire which is hot when the key is in any position other than off.
Both the "L" Terminals on the surface accomplish the same thing. They illuminate the idiot light when there is a problem. However, as far as the alt is concerned they accomplish very different things and it can be seen in the wiring diagrams.
The S4 has a diode on the relay that only allows current to travel one way. When the alt goes bad, or is not charging, the W/B wire latches to ground, which energizes the coil, which closes the circuit in the relay to ground and with the other side of the idiot light connected the B/Y wire (also key hot) the light illuminates. It appears to me that the S4 alts can be run with only a single wire and run properly and as designed (meaning they won't die quickly) by leaving the idiot light wire left unhooked. Regarding the S4's, the L wire is an output, not an input as it is on the S5/6's
The diode is most likely blown on Zac's car because it's an S6 alt.
Let me state this as fact, because I've fought these issues and anyone running an S5/6 alt on an S4 car is going to run into these problems and I can say with certainty that you need to have both wires connected and working properly for the S5/6 alts to live a decent life ... TRUST ME!
c3a393a_c.jpg[/img]
Zac, right now, or rather before we started chatting, you only had one wire connected to the alt. How was that wire run and is it constant hot? ACC only? Acc and start and run? If it's a factory S4 B/W wire, that will work fine, you just need to add the resistor that we talked about. Then the S lead can run straight to your battery and it'll work fine, assuming it's not already fucocked.
Old 02-27-2017, 02:24 PM   #37
FC Zach
FC Zach's Avatar
Up until recently I had only the main battery charge cable ran but in the past, I had a lead running to a switched 12v source I found on the driver side strut tower in a vacant connector attached to the fuse box bracket. Where I had the opposite end of that lead going? ? ? I don't remember but I think I had it on the "L Terminal" so if that's the case, I've never had a reference from the battery connected to the "S Terminal".
What I'd like to do is find the old alternator wires or the connector/harness they would have come from and wire my leads there. . . wherever that is.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 03:16 PM   #38
Gotcha, If you had a switched 12v source connected to the L terminal, chances are it's probably cooked, sorry.
Here's the problem, you're going to have to modify the wiring significantly if you're going to use the chassis wiring (S4) with the S6 alternator and have the idiot light work correctly
Ok, so before you go digging into the harness looking for the mystery wires here's what I would do
Use that existing 12v key wire that you originally had running to the L terminal. Put a small resistor on that wire (I can tell you what I am using tomorrow night) and connect that to the L wire on the S6 Alternator. Yes I realize that this sounds alot like what I just said probably cooked your alt, here's the difference, look at the S6 charging diagram. You'll see the L wire runs to the alt via the ignition switch (so it only sees power when the key is on) through the idiot light in the dash (resistance) and through a diode (one way check valve). So by using that wire on the shock tower (which I'm assuming is B/W or B/Y), you can add a resistor to mimic the resistance of the 1.4W dash bulbs and that solves that problem. Now the S6 will think that your B/W or B/Y wire is being fed through a lamp circuit like it should be.
The S wire on your alt can be temporarily hooked up to the alt charging post or brought back to the battery, either will work fine for testing purposes.
There is a big difference in the way the S4 works from the S5/6. The two main differences are.
The S4 uses the R terminal to turn itself on, and to sense the voltage. The S5/6 uses the L terminal to turn itself on. The S4 doesn't have an S terminal, the S5/6 don't have the R terminal
The S4 uses the L terminal as an output. When the alt goes bad or isn't charging, this terminal latches to ground triggering the idiot light. The S5/6 use this terminal as a turn on. When it sees voltage, it excites the alt.
The S4 doesn't have an S terminal. It uses the R to determine voltage regulation duties. The S5/6 have the S terminal and they use this to sniff the voltage to determine regulation duties.
Does that make sense, at all? Again, this is what I went through 3 years ago
Old 02-27-2017, 03:25 PM   #39
FC Zach
FC Zach's Avatar
Eh. . What makes the most sense is what I can see drawn out, like the diagram at to beginning of this page lol.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 03:34 PM   #40
FC Zach
FC Zach's Avatar
But yes, I see that there's difference in terminals and their requirements, please share your resistor size/part number. . I'm sure it could be beneficial to others as well.
So far things seem pretty clear as to what I need to do. . I just need to get it done. So with what you have said, I'm ditching the idea of searching for the OE wires and will run my leads like mentioned (I believe we're on the same page here).
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 03:43 PM   #41
FC Zach
FC Zach's Avatar
Then, once I have the wiring done (I've been meaning to do this anyways) I need to get the alternator bench tested.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 04:11 PM   #42
FC Zach
FC Zach's Avatar
I'm checking that connector I mentioned. . It's a white/black wire that I believe I was using. . Checking it with a meter, it doesn't have power in any position of the ignition switch so I'll have to find another source.
What about this. . Use an unused 12v injector wire from my Ludwig harness for the "L terminal"? with a resistor of course. . What do you think? This would definitely be the tidiest route to take. Or would resistance on this wire cause any unwanted problem/s?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 04:45 PM   #43
I will do my best to remember to check it. If you don't have a text from me by 8pm tomorrow night, text me. It means I've forgotten
I would do it the way I posted about for testing purposes only. Once it's confirmed that the wiring is good, and the alt passes it's bench test, you've run it and it charges properly, there's no electrical whine, there's no current draw on the battery and you can leave it for a few days/week with no ill effects, than I would start looking for the factory wires.
However, if you're using the factory wires that you find in the harness, a few things are going to need to change in the car itself.
First, the Alt relay that controls the idiot light needs to be addressed. The B/W wire on the S4 chassis needs to be connected to constant power. Both of which are easy enough
That's fucked up. What's the connector originally for?
It would be the easiest, but I would not suggest going about it that way only because of the potential problems it could cause down the road.
Factory it's the FE-03 connector that's on the front harness that houses the wires for the alt. Page 50-16 in the S4 FSM I would find that connector, find the B/W wire and see if that has voltage, if it does, there's your L circuit (originally R) Then it's a matter of finding on the same connector W/G wire and ohming it back to the idiot lights. If you find that connector you can then tap that into anything on the dash harness (stereo) that has constant power. This is the new S terminal on the S6 alt. That would do it as well.
Old 02-27-2017, 04:58 PM   #44
FC Zach
FC Zach's Avatar
Alright, will do.
Alright, currently have one wire (S Terminal) temporarily ran to the battery. "L Terminal" pending till I find the proper resistor and a switched 12v source.
Noted. .
No idea, I'll share a picture of it later.
Ten four
I'll look into this
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-27-2017, 06:42 PM   #45
FC Zach
FC Zach's Avatar
Test connector? ? was secured to the backside of the fuse block bracket.
Since this is out and it may not be wise to tap into an unused injector wire in the Ludwig harness, I will search for a different source later down the road. Till then I'll make temporary connections.
Oh, I took a picture of the resistors I have laying around. . What are the chances any of these are the right ones?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
