Old 06-23-2016, 11:02 AM   #166
project86
Can't.Make.Up.My.Mind.
project86's Avatar
So I got the Atkins 6 port inserts in. But in the process broke one of my OMP lines. I'd really like to do something more sturdy for them instead of just buying new ones that are gonna get brittle and break again. I had the idea to do steel braided lines for them. I'm sure I'm not the first person to think about that but I'm wondering if anyone knows of a pre made set?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 06-23-2016, 11:39 AM   #167
JL1RX7
I has a set of the previous braided made one's. Never been used. I forgot what buy I got them on. One end is pressed in, while other end is loose to be able to trim to fit.
Old 06-23-2016, 02:48 PM   #168
project86
project86's Avatar
Are you suggesting you'll sell them to me?
'90 GTUs
'10 Toyota Prius
Old 06-23-2016, 03:30 PM   #169
JL1RX7
If you want them. Been sitting in box since at least 10. Might as well go to a good home.
Old 06-23-2016, 04:21 PM   #170
project86
project86's Avatar
I sent you a pm
'90 GTUs
'10 Toyota Prius
Old 07-10-2016, 05:52 PM   #171
project86
project86's Avatar
Alright so I got some SS OMP lines from RotorSports and got them installed. Should be able to get everything back together pretty quickly now.
'90 GTUs
'10 Toyota Prius
Old 07-24-2016, 09:15 PM   #172
project86
project86's Avatar
UPDATE:
Everything is back together and the car fires up. I ended up putting in a new radiator as well. Just FYI for anyone following this. The fan shroud doesn't fit properly after the install despite the fact that it was supposed to be a drop in replacement.
Anywho.... Like I said, the car fires right up but won't stay running on its own even after it reaches operating temp. I suppose I have a big vacuum leak somewhere but I'm not really sure where to start looking. Any thoughts?
'90 GTUs
'10 Toyota Prius
Old 08-21-2016, 07:19 PM   #173
project86
project86's Avatar
Any ideas? DJ and I found a huge vac leak. I was hoping that was the issue but i plugged it and its still the same issue. Car starts right up but only runs if my foot is on the gas. Even after being warmed up.
'90 GTUs
'10 Toyota Prius
Old 08-21-2016, 08:19 PM   #174
FC Zach
FC Zach's Avatar
Bad sensor? Like a TPS or AFM?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-21-2016, 08:28 PM   #175
FC Zach
FC Zach's Avatar
I have a LED tester I made years ago for what I believe is for testing the TPS, I can bring it to your house in exchange for pizza & beer
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 08-21-2016, 08:30 PM   #176
FC Zach
FC Zach's Avatar
Oh, you can test the AFM with a DVOM, you will just need to know what the specs are, I imagine these numbers are in the service manual.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 08-22-2016, 09:04 PM   #177
project86
project86's Avatar
I suppose it could be either... its just seems unlikely to me since they didnt really get used or have any kind of damage when i pulled them off.
done. just need to figure out a good weekend. Maybe this sunday afternoon? whats your work schedule?
I don't know what a DVOM is ......
'90 GTUs
'10 Toyota Prius
Old 08-22-2016, 11:20 PM   #178
chibikougan
chibikougan's Avatar
Digital Volt Ohm Meter?
Old 08-22-2016, 11:34 PM   #179
FC Zach
FC Zach's Avatar
We'll check them both, adjustment is important too.
I'm always busy. . Aside from usually working six nights a week, I usually have something booked for every Saturday. Oh, then there's Sundays, Sundays can eat a bag of dicks, I have to rest for work on Sundays so the latest I stay up is around 3. . . Which translates to no daydrinking for this guy
Digital voltage/ohm meter
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 08-22-2016, 11:36 PM   #180
FC Zach
FC Zach's Avatar
Just pick a day and I'll make it work because working around my schedule isn't the easiest.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
