Old 07-25-2016, 01:09 AM   #1
Madmen
Madmen is on a distinguished road
Fb lsd?
Can anyone please point me where I may find and LSD from my FB? Not for racing but spirited street use. Any advice would be greatly appreciated.
Thanks.
Madmen is offline   Reply With Quote
Old 07-25-2016, 01:39 AM   #2
Madmen
Hang on...you can swap it for a miata diff with a torsen???
Old 07-25-2016, 07:27 AM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
GSLs had LSD in em OEM, so if you can find one of those from a junkyard, your good to go.
May want to rebuild the LSD before plunking it in there.
Old 07-26-2016, 08:45 AM   #4
Madmen
Hi t_g_farrell.
No scrap yards in Manila sad to say. Also Mazda never sold any rx7s over here.
I read somewhere that a miata torsen will fit into the diff of an early FB. Anyone here done that?
Old 07-28-2016, 09:43 AM   #5
Only the 7" miata diff since the rx7 differential is 7". Dont get the smaller one. Also i think it will only accept the 84/85 axle siince those years have larger spline and bigger bearings.
Old 07-29-2016, 01:44 AM   #6
Madmen
I thought I replied with my thanks to Whizbang already but I don't see it.
Trying again.
Thanks Whizbang!!!
Old 10-09-2016, 12:02 AM   #7
Sh00bs
I5's Doritos & dualsports
Sh00bs's Avatar
Sh00bs is on a distinguished road
did you try google?
ok so
gsl's have 3.90 lsd, but after 1983.5, they became large axle through end of production year ('85)
gslse (84/85) have a 4.11 lsd, big axle of course
Yes Miata pumpkins can be swapped in
so can, mazda 80's truck front diff's which are 4.44
So can kia sportage (90's) front diffs, which are 4.77
you can also source custom lsd's, like I just picked up an '81 GSL rear with 4.88 gears in it
Just bear in mind your axle to what pumpkin you're putting in it, OR if you swap the whole rear to acquire disc's, that's fine but you also have to swap out the proportional valve up by the master cyl AND WHAT MOST PEOPLE FORGET ABOUT is you'll need different E brake cables for the disc rear
So if you find a LSD/Disc rear at the junk yard, make sure you get
1) complete rear with calipers
2) take the proportional valve from the engine bay
3) get those e brake cables
probably more than you were looking for but hopefully the next person searching will find this thread and the above info and it'll solve duplicate posts down the road
'85 GS frankenstein 13b bridge
Gf's '79 LE sa w/85 12a
GF's 04 rx8 dyno'd 189whp, meh not bad
Sh00bs is offline   Reply With Quote
