Old 07-11-2016, 06:22 PM   #31
RotaryBC
RotaryBC is on a distinguished road
No, still no start
Pressed, gas peddle and clutch peddle
Stare at this tomorrow.
2005 RX-8 Shinka 171
2005 RX-8 Shinka 1137
RotaryBC is offline   Reply With Quote
Old 07-12-2016, 07:03 AM   #32
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Originally Posted by RotaryBC View Post
Was that a drive by thread jacking?
It's fairly typical on the interwebs, I'd say it was merely a minor side conversation though. Now... if the thread suddenly changed and we all started posting up pictures comparing My Little Pony erotic fan art... THEN I'd say you suffered from a thread derailment
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-12-2016, 07:22 AM   #33
RotaryBC
Just being funny
The not turning over issue, I think it is the throttle body not being on the car. Coolant runs thru the throttle body, I can see if the TB is not present, then do not start.
Old 07-12-2016, 08:15 AM   #34
Dude, WTF is going on here. You're trying to find out whether or not the engine is blown right? Do a compression test and put the thing to bed once and for all.
Are you seriously trying to start it w/o a throttle body?
Old 07-12-2016, 08:21 AM   #35
RotaryBC
No, I'm trying to turn over the engine.
The starter is not engaging, thus not turning over.
Old 07-12-2016, 08:52 AM   #36
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I think he's more wondering why you're trying to crank the engine at all without the throttle body installed.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-12-2016, 09:03 AM   #37
Cranking w/o the TB is fine, trying to start it, not so much though.
I'm wondering if the EGI fuse helps power the starter.
Is it not engaging or just not spinning, not doing anything at all?
Old 07-12-2016, 09:11 AM   #38
RotaryBC
Put the #2 plugs back in, pull th TB off, pull the EGI fuse and crank the engine over and LISTEN very carefully
I did what he said?
The fuse is marked IG on mine, I did find what I think is a relay that is marked EGI.
I pulled the TB and the fuse marked IG, put compression tester in Top #1 plug hole, spark plug in lower #1 plug hole, I put plugs in #2.
Connected battery
depressed clutch peddle
depressed accelerator peddle
Turned the key
Nothing, no click, nothing
Old 07-12-2016, 09:20 AM   #39
The relay and starting circuit are different on the 8 than the other models. Pulling the IG fuse may prevent power from going to the solenoid.
You MAY have to pull the CAS plug and reinstall the EGI fuse.
Old 07-12-2016, 04:49 PM   #40
Dannobre
Dannobre is on a distinguished road
The oil in the air filter can be from from the oil fill..the oil can run run down the breather tube into the air filter. Looking at your pictures though it looks like it has been blowing oil out into the intake...usually that is a poor compression issue
You should clean your MAF..it is likely flooded with the oil from the intake
The front seal can leak...but another common place for the RX-8 to leak is from the oil metering pump area. Oil on top of the engine is often a leaking o-ring where the oil fill tube and the iron meet. The nuts there seem to get loose easily and leak
If they are the original coils then replace them...and the wires and plugs. They are a well known weak point on the Renesis
The easiest way to try and start it is to pull it... Check the spark with a spark tester or an inductive timing light if it won't start.
Pull the ES sensor plug to do the compression test...it is easier than anything else
Another thing to try is reset the Eccentric shaft profile...it's the key on...pump the brakes 20+ times quickly until the oil guage sweeps. The ES sensor controls the ignition and injection ...so it is always a good thing to reset if you don't know whats been done to the car
With that kind of mileage , unless you got a unicorn...it likely has low compression and needs a rebuild
Edit...sorry for the repeat for some reason I just read the first page ;(
Dannobre is offline   Reply With Quote
Old 07-12-2016, 06:53 PM   #41
RotaryBC
Compression Test:
#1 = 50psi
#2 = didn't do
Old 07-12-2016, 07:47 PM   #42
RotaryBC
What do we do with this thread, just let it die?
I'm taking the car to a frame shop to check it out. If the frame is straight or can be straightened I will attempt the engine swap.
Until the frame shop!
Old 08-16-2016, 10:48 AM   #43
RotaryBC
It starts and runs
Saturday I did the de-flooding procedures, it started and smoked, I keep it running until the smoke subsided.
Drove it a short distance on the road, shut it off, restarted it, shut it off for the day.
Sunday, I tried to start it, it would not start, started the de-flooding procedure again, forgot to press the gas petal before turning the key, it starter right up.
Could this mean the engine is a good rebuild candidate?
I've read the rebuilders web sites, they read, that most engines are too damaged to be rebuilt.
Old 08-16-2016, 11:37 AM   #44
JL1RX7
Kevin Landers of Rotary Resurrection in Morristown Tennessee. He is the home of the budget rebuilds. Quality work with no bull shit. Until the keg is cracked open no real way of knowing the true condition of it.
Old 08-17-2016, 10:25 AM   #45
It starts and runs
The donor for FrankenB had all the same problems. Everything internal was immaculate save the housings had the typical wear caused by the assist piece. Built my Treffeisen Special Renni and it did 207rwhp
