Old 05-13-2016, 10:19 AM   #106
project86
Can't.Make.Up.My.Mind.
project86's Avatar
I disapprove. All rotaries should be turbo. Especially those with a displacement greater than 1.3L
Lol.... Disapprove away. But I feel pretty good about it at this point. I've not read one bad thing about a NA 3 Rotor set up. All I've read says how much fun they are to drive. But .... we'll see... there is plenty of time for me to change my mind.
I've been running the 8 6spd for a while. It hasn't proven itself all that reliable
Thats not a very comforting statement in your pitch for every NA Rotary needing a 8 transmission
As far as the shifting properly goes... are the people who can't do it properly just pulling and pushing WAY too hard during the shift?
That's what I plan on doing actually... that's what I did for the most part last time... although I rented the booth and shot it myself. Not sure I wanna do that again though.
Did you rent the booth from a local body shop? How long did you rent the booth for? What did they charge you?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-13-2016, 10:26 AM   #107
You can get a small turbo with a big exhaust and properly sized turbine and have the same hp, more torque, and be more fun to drive.... cheaper... in my opinion.
My problems have been all shift assembly related. Having to modify the tailshaft and linkages has proven.... difficult. The last iteration lasted 2 years and now it's pissing fluid everywhere. Not sure why... haven't looked yet. I'll let you know though.
Mostly
The owners are friends of the family. Rented it on a saturday, charged me $250 for the 5 hours. Picked the car up on monday morning
Old 05-13-2016, 10:59 AM   #108
Shut up queer. I'm done with turbo rotaries until I win the lotto.
Old 05-13-2016, 11:15 AM   #109
wah wah wah spinny bits are expensive and the gremlins shit out apex seals for no reason, WAHHHHHHHHH
Old 05-13-2016, 11:30 AM   #110
Hey now.
I didn't shit an apex seal. I annihilated a rotor bearing.
It was tragically impressive.
Old 05-13-2016, 11:33 AM   #111
Turbo can't really be blamed for that
Old 05-13-2016, 11:53 AM   #112
infernosg
IT'S ALIVE!
infernosg's Avatar
Absolutely correct. Not to mention the 5.11 gears and Hoosiers that put way more strain on a tranny.
How I'd love to have a 5.11:1 final drive ratio. Looks like the highest option other than complete custom for the FC is Mazdatrix's 4.77:1.
Even with the 350 hp number in mind? At this point my plan is to do a NA 3 rotor when its time to do the engine swap. Its what i really wanted originally with my old car (or an RE swap but i don't want to deal with turbo now). I guess I shouldn't have been so vague in the beginning with this question. So now its all out there.
Im probably really showing my ignorance now but why would it be a expensive/confusing to just swap a TII transmission in? Seems like that option would be less expensive than buying another trans and then having a shop swap the gears and mod the input shaft?
Oh, I didn't realize you were planning on swapping a 20B. 350 hp in a naturally aspirated 20B is optimistic without sacrificing some drive-ability, but that's another conversation. I still think as long as you're not beating on the car constantly (hard launches, constant high-RPM driving, etc.) the N/A gearbox will be fine. You can always change the fluid more often to be safe.
My comment about the complexity was assuming the stock N/A 13B. To switch to a turbo gearbox you need a turbo clutch and flywheel, starter, and unless you want a custom driveshaft to the stock N/A rear end, the turbo differential as well.
Old 05-13-2016, 11:54 AM   #113
project86
project86's Avatar
For the record i have no qualms with going turbo. I just want to really experience NA for a while. I still see turbo in my future. just not yet.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 02:11 PM   #114
project86
project86's Avatar
I think the 350 number is attainable from what I've been reading lately. I came across a thread on the other forum that a guy did a 3 rotor na build for his FD. The made 345whp. His comments were that the car was just fine on the street drivability wise minus his clutch choice. So i am hopeful.
That makes perfect sense. Im glad to know that that miata gear swap is still on the table.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 02:35 PM   #115
almoststockfc
almoststockfc's Avatar
Sooo, please correct me if i'm wrong because i'm confused. You wanted a FD but you said it was too expensive, that is the reasoning behind you purchasing the FC. Now you want to have a NA 20b in your FC........
-75 RE_W_PU -
Old 05-13-2016, 02:55 PM   #116
Smaller chunks of moneies at once.
We did 350 on Gordons 3-rotor, stock port, n/a
Aside from the sound which is orgasmic, there's no bene to a 3 rotor if you're only looking for 350rwhp.
Now 600.... We've done that on pump gas with three rotors.
Old 05-13-2016, 03:10 PM   #117
project86
project86's Avatar
no need to be confused. a decent Fd would have cost me 10k on the low side. and then i would have had to dump a bunch of money to make it look nice. My FC cost 3.5K and its in good running condition and the body is straight. the money i saved not buying a FD means money i can use for the FC.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 03:12 PM   #118
project86
project86's Avatar
Speed1 built his? I thought Defined built it? I mean its either a singe turbo RE or a 3 rotor na. Seems like i would run into less annoying things and hang ups with out the turbo.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 03:21 PM   #119
Speed1 built his? I thought Defined built it?.
I forget who built it, but it blew up good about 200ft before making it to the Dragon......
Old 05-13-2016, 03:32 PM   #120
Pete_89T2
Pete_89T2's Avatar
Yes it did, that was what, 2 DGRR's ago?
