Old 05-04-2016, 12:45 PM   #61
FC Zach
FC Zach's Avatar
Let's see how long before the corrections come flying in...
LOL, I got nothing
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-04-2016, 12:51 PM   #62
JL1RX7
89 91 S5 GTU, single piston vented front, non vented rear brakes. Rest should be all the "heavy duty" style brake/suspension package.
Old 05-04-2016, 01:44 PM   #63
Werd. And AFAIK there was never a 2-pot rear, nor front.. They were single piston sliding.
All the mounting points are the same though.
Even the swaybars were the same MOUNTING point, although the diameters are different between SE and basically all others, including 'vert.
Old 05-04-2016, 01:49 PM   #64
JL1RX7
Rear brake calipers are the same too, only the bracket being different. Front brake mounts are the same from single to four pot. Only difference being the brake lines. Four pots have hard lines vs soft on the single's.
Old 05-04-2016, 02:37 PM   #65
That's true of all the Zenki / S4 FC's...
I believe the Kouki / S5 did have a vented rear disc brake rotor?
Most catalogs does list them as 5-lug, rear vented for those base models...?
These damn things are rare enough...
i don't get too see too many of them down here nowadays in person!
Old 05-04-2016, 03:59 PM   #66
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Yep, as TTT said, it's the same...
In fact, the base models had the "special" suspension and brakes.
GXL is the "loaded" model, and the turbo (i.e. Turbo II) is a GXL + turbo engine.
The 1998 "GTU" + 1989 / 1990 "GTUs" are just GXL models minus all the heavy (i.e. powered) shit and some special features (i.e. no sunroof, but amazingly there are some that did come with sunroof).
The 1986(?) and 1987 has a "Sport" model available, and this was a precursor to the 1988 "GTU."
The brakes are standard across the board with the exception of the base models; this is for the 4-pot fronts with vented disc and 2-pot rears with vented disc.
This big brake or heavy-duty brake package were on all GXL, turbo, and convertible models + the abovementioned 1988 "GTU" and 1989 / 1990 "GTUs" models.
Brakes on base models - 1986 / 1987 "base" + 1988 "SE" - had the 2-pot(?) front with vented disc and single-pot rear with NON-vented disc; these were obvious due to the 4-lug wheel lug pattern.
In 1989 - 1991 base models, all FC's were 5-lug wheel lug pattern, but the base models had different brake calipers and discs.
(Forgot some of the specifics here...)
This all sounds correct to what i've read about the GTUs.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-04-2016, 04:07 PM   #67
project86
project86's Avatar
Well today started off well...
Plans were to wet sand and polish my tails. Driver side went off without a hitch. Pulled the passenger side and mid polish i knocked it off the table and broke the corner...
So... I finished it all and put them back in. Ill just need to find another passenger light in the near future. They look great. It will probably be hard to tell in the photos but they polished up amazingly.
I'll be ordering new seals for them soon though. They are all sorts of nasty.
I found it odd that there were twisty wire caps in the harness though. It was like that on both sides.. I don't remember ever seeing that before.
By the way .. the photo that has both lights shown is an attempt to show the polished driver side and the unpolished passenger side.
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 04:19 PM   #68
chibikougan
chibikougan's Avatar
D'oH!
Looks good! Glue that chunk back on and sand it.
http://www.hobbylinc.com/htm/dev/dev...FQmVfgodLnUFyQ
I made a trade for that nose candy on your bumper...Bag it up!
Old 05-04-2016, 04:22 PM   #69
project86
project86's Avatar
D'oH!
It broke off in multiple pieces and i think i know where i can get another set of lights so I'm not gonna bother with it.
whats this nose candy you speak of?
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 04:30 PM   #70
project86
project86's Avatar
Unrelated to the tail lights....
I have plans at this point to send my steering rack to ChipsMotorsports to have it rebuilt and depowered.
But i just had a thought... couldn't i just get a manual rack from another car and use that instead of going through the depowering process?
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 04:41 PM   #71
chibikougan
Oh that is faded white...
Old 05-04-2016, 06:35 PM   #72
There is a very large difference in the ratios between the manual and the power racks. As a comparison on the Dragon with a de-powered power rack your arms will never cross. With a manual rack there are some turns that will have you almost going hand over hand
Old 05-04-2016, 06:38 PM   #73
project86
project86's Avatar
So it will work, there just might be some instances where i have to turn the wheel more?
'90 GTUs
'10 Toyota Prius
Old 05-04-2016, 06:59 PM   #74
Of course it will work. The only difference between the steering knuckles is whether or not there's ABS, and the subframes are all the same, I believe even for the 'vert
Old 05-04-2016, 07:05 PM   #75
project86
project86's Avatar
Cool beans.. I was just doing some research in the mean time. I found out that Chip does do it the same as you (depowering the rack). Found an old post from someone who had pictures of it. I'll probably just hold out and have that done.
'90 GTUs
'10 Toyota Prius
