Old 04-27-2016, 06:22 PM   #16
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Originally Posted by MolotovMan View Post
Hands down the best mod I did to the car was having an NB Miata gear set put into the S5 N/A case. It made the car so much more fun to drive.
So you just sourced Miata trans and had someone do the input shaft mod for you? Does the fc shifter still fit the same way since it's just the internal parts being changed?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 04-27-2016, 07:13 PM   #17
project86
project86's Avatar
Turns out my weird shuddering is happening in more than just 1st gear. On my drive to get coolant flushed i noticed it quite a bit. Although it seemed to come and go in later gears. It leads me to believe that maybe something is loose. It feels like most of it is coming from under my seat.
'90 GTUs
'10 Toyota Prius
Old 04-28-2016, 07:34 AM   #18
infernosg
IT'S ALIVE!
infernosg's Avatar
The mod is essentially putting the Miata gears into the RX7 transmission housings so the rear housing and shift linkages are still all RX7. Though technically you could swap some Miata stuff over so you could run a Miata short shifter if you wanted. They're much cheaper for some reason. It sounds straightforward but it's a pretty complicated task. You have to completely disassemble the transmission to get to remove the input shaft. I posted a how-to on here a while back detailing the process per the FSM.
Old 04-28-2016, 10:57 AM   #19
Describe the 'shudder'.
Like the engine is missing? Clutch chattering? Suspension shunt?
Old 04-28-2016, 12:25 PM   #20
knonfs
knonfs is on a distinguished road
A good local standup guy (in Northern VA that is) is selling a NA FC trans with the Miata gears on it. I don't want to cross post threads, but if you are interested, I can get you in touch with him (or pm you his FS thread)
knonfs is offline   Reply With Quote
Old 04-28-2016, 08:05 PM   #21
chibikougan
chibikougan's Avatar
I have those injectors and new connectors if you want them. You cover shipping and they are yours.
Old 04-28-2016, 08:12 PM   #22
project86
project86's Avatar
its more of a heavier vibration coming from under my butt. I looked on Mazdatrix and actually found a trouble shooting guide for that sort of thing. I've basically narrowed it down to bad u-joints, trans mounts, or bad ring and pinion (crap i hope not because those are pricey). So i started cheap and ordered the trans mounts. Ill just work my way up from there until I've replaced it all.
Feel free to post the link here or PM me. I may not be in a position to buy it now but I'd love to know the price. Or see if i can work out a deal with him.
Heck yeah Ransom. Text me 406-450-4103.
'90 GTUs
'10 Toyota Prius
Old 04-28-2016, 08:17 PM   #23
chibikougan
Texted ya. I will get them ready to send out Monday. I will just ship them and we can figure it out. If I get an address
Old 04-28-2016, 08:36 PM   #24
project86
project86's Avatar
Ransom you da man!
'90 GTUs
'10 Toyota Prius
Old 04-29-2016, 12:18 AM   #25
FC Zach
FC Zach's Avatar
its more of a heavier vibration coming from under my butt. I've basically narrowed it down to bad u-joints, trans mounts
Have you inspected your trans mounts? Most likely they're bad considering the age and exposure to oils which turns them into a mushy mess. I've seen this on a few 2nd gens. I've had some completely separate.
Good choice, if you don't have the aluminum shield for the mount closest to the exhaust I'd recommend getting it.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 04-29-2016, 06:11 AM   #26
project86
project86's Avatar
Yeah I'm hoping that will make a difference. I'm not sure about the shield though. It looks like all that is still present but i could be wrong. Its been so long since I've been under one and worked on it that I'm having to re learn a bunch.
'90 GTUs
'10 Toyota Prius
Old 04-29-2016, 08:19 AM   #27
project86
project86's Avatar
Just to elaborate more on my inspection yesterday. I laid under the car for about an hour or so just looking around at stuff, trying to move it, etc. Nothing was obviously loose or easily moveable. Bushings are obviously worn which I'm sure is a contributing factor to the vibes I'm getting.
Bushings will be coming soon as well but i figured trans mounts would be a better first place to start. I ordered a new trans brace as well. I'm contemplating dropping the trans and just cleaning it up when i do the mounts. Its just nasty and has what smells like gear lube on it but I didnt notice any leaks. I guess it would be a good idea to drain it and refill as well. If i do drop the trans.. is there anything else i need to do before i put it back in?
'90 GTUs
'10 Toyota Prius
Old 04-29-2016, 09:03 AM   #28
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
get snot slinging drunk.
Old 04-29-2016, 09:12 AM   #29
FC Zach
FC Zach's Avatar
There will be bolts missing if that happens!
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 04-29-2016, 12:10 PM   #30
If it's trans mounts, it'll make a LOT of noise on shifts...
Anything from a thud to a BANG during the shift is your typical sign of failure.
It's uncommon that bad trans mounts induce a shudder during driving though, but this could be a symptom of something else...
