| Tires,Wheels,Suspension,Brakes Info about Tires, Wheels, Suspensions, Brakes, etc. |
|  03-10-2016, 11:31 AM | #16 |
| ..... Join Date: Jan 2010 Location: Murfreesboro, TN
				Rep Power: 16  |
			245 35 18 - RX7 = Performance car     215 40 18 - RX7 = Daily driver
				__________________ -75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO  - DGRR 2011 Peoples Choice - April 2011 Rotary of the  Month  -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
|  03-10-2016, 11:32 AM | #17 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			My 'vert with stock suspension was running 215/45/17 with room to spare.  Stock suspension I think I was 235 at all fours. When I got the coilovers is when I got serious about tire width. If you're going the non coilover route there is no reason you can't get a square 235 setup. Problem is that the rear is vastly different from the front. So you can run big staggers, and personally, I prefer that look more than the square. The rear is much more sunken than the front. I MAY be running down with the track trailer, in which case I'll also be bringing the Hoosiers
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  03-10-2016, 11:33 AM | #18 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			Hehe.  I think my tires are wider on the Cosmo.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  03-10-2016, 11:45 AM | #19 |
				Rep Power: 10  |
|  03-10-2016, 12:37 PM | #20 |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  |
			The problem is that we're talking about NOMINAL #'s... One tire with a 225 width isn't going to be the same as another's 225 width. I've had a pic of my 8.0", +30 fitment with a 215 wide tire up front with stockish (unknown brand spring on GAB shocks - think KYB AGX) front suspension, and I manage to stuff a 6mm (~1/4") spacer in between the tire and the (bottom of) the spring. If we do the math, a 225 wide tire would basically eat up all the space... Yes, I've heard of 8.0", +35 spec wheels fitting up front, but I wouldn't risk it from my experience; be prepared to run a thin spacer just in case you hit stuff up front... Watch out for aftermarket springs, as I know for sure the Tanabe GF210 and Tein's run larger diameters on the bottom coils, which gives you LESS clearance on wheels. I'd put money these spring + a 8.0", +35 wheel will almost never fit... Aftermarket coilovers might be a problem, as most will run a 7" height spring up front. This means for most people that the adjustable lower spring collar will most likely be adjusted all the way DOWN. Again, this DECREASES clearance... Realistically, you can run 225's for square fitment. If you get the (front) offset spot on, you can run 235's. I find that FC's running close to 300 (or more) can easily overpower these narrow tires with the right foot. I really like running 255 square, but it's next to impossible with stock front fenders... I like running 255 / 40 / 17 tires on 9.0" wide wheels; you need an offset of around +20 (minimum) to +15 to get them to clear everything up front. The problem with this combo is that it'll hit the fender lip! Wider (fiberglass) fenders are an option (which I don't like) or serious modification of the stock fenders is needed. This 255 square set-up is fun with FC's running in the 300 - 400hp range, which covers most of the cars out there that are modified. I have fitment pages for wheels and tires here: http://fc3spro.com/TECH/MODS/RT/rims.htm http://fc3spro.com/TECH/MODS/RT/tires.htm -Ted |
|  03-11-2016, 10:47 AM | #21 |
				Rep Power: 10  |
			By the By.... 18's on an FC
|  03-11-2016, 10:54 AM | #22 |
| RCC Loves Me Not You Join Date: Mar 2008 Location: Eagleville, TN
				Rep Power: 20  |
			See DJ, that looks good! Old man!
				__________________ 1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
|  03-11-2016, 10:55 AM | #23 |
				Rep Power: 22  |
|  03-11-2016, 10:57 AM | #24 |
				Rep Power: 20  |
			Alright! Alright! I'm getting off your lawn! !
|  03-11-2016, 10:58 AM | #25 |
				Rep Power: 10  |
|  03-11-2016, 11:03 AM | #26 |
				Rep Power: 20  |
			I think they look great Brian!
|  03-11-2016, 11:11 AM | #27 |
				Rep Power: 10  |
			Thanks Zach!  Fitment was TIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIGHTer than virgin ass
|  03-11-2016, 11:22 AM | #28 |
				Rep Power: 20  |
			To be safe, I'm thinking I'll need to go with a coilover setup. . Shit's close with a stock wheel and I don't want to be pulling fenders, the poke and stretch thing just isn't my style.
|  03-11-2016, 11:28 AM | #29 |
| IT'S ALIVE! Join Date: Dec 2009 Location: Richmond, VA
				Rep Power: 16  |
			I liked the look with 16's I had on my old red FC. It's too bad wheel and tire options are so limited with 16's. I need to get a good picture of the setup on the orange FC: 17x9 +22 with 255/40R17 all around although there's no way that will work with stock fenders.
|  03-11-2016, 12:31 PM | #30 |
				Rep Power: 22  |
			They look good.  Better than the owner for sure.   Still too big. Like donkey dong. Right Bri-bri?
