Old 03-10-2016, 11:31 AM   #16
almoststockfc
almoststockfc's Avatar
245 35 18 - RX7 = Performance car
215 40 18 - RX7 = Daily driver
-75 RE_W_PU -
Old 03-10-2016, 11:32 AM   #17
My 'vert with stock suspension was running 215/45/17 with room to spare. Stock suspension I think I was 235 at all fours.
When I got the coilovers is when I got serious about tire width.
If you're going the non coilover route there is no reason you can't get a square 235 setup. Problem is that the rear is vastly different from the front. So you can run big staggers, and personally, I prefer that look more than the square. The rear is much more sunken than the front.
I MAY be running down with the track trailer, in which case I'll also be bringing the Hoosiers
Old 03-10-2016, 11:33 AM   #18
Hehe. I think my tires are wider on the Cosmo.
Old 03-10-2016, 11:45 AM   #19
Old 03-10-2016, 12:37 PM   #20
The problem is that we're talking about NOMINAL #'s...
One tire with a 225 width isn't going to be the same as another's 225 width.
I've had a pic of my 8.0", +30 fitment with a 215 wide tire up front with stockish (unknown brand spring on GAB shocks - think KYB AGX) front suspension, and I manage to stuff a 6mm (~1/4") spacer in between the tire and the (bottom of) the spring.
If we do the math, a 225 wide tire would basically eat up all the space...
Yes, I've heard of 8.0", +35 spec wheels fitting up front, but I wouldn't risk it from my experience; be prepared to run a thin spacer just in case you hit stuff up front...
Watch out for aftermarket springs, as I know for sure the Tanabe GF210 and Tein's run larger diameters on the bottom coils, which gives you LESS clearance on wheels.
I'd put money these spring + a 8.0", +35 wheel will almost never fit...
Aftermarket coilovers might be a problem, as most will run a 7" height spring up front.
This means for most people that the adjustable lower spring collar will most likely be adjusted all the way DOWN.
Again, this DECREASES clearance...
Realistically, you can run 225's for square fitment.
If you get the (front) offset spot on, you can run 235's.
I find that FC's running close to 300 (or more) can easily overpower these narrow tires with the right foot.
I really like running 255 square, but it's next to impossible with stock front fenders...
I like running 255 / 40 / 17 tires on 9.0" wide wheels; you need an offset of around +20 (minimum) to +15 to get them to clear everything up front.
The problem with this combo is that it'll hit the fender lip!
Wider (fiberglass) fenders are an option (which I don't like) or serious modification of the stock fenders is needed.
This 255 square set-up is fun with FC's running in the 300 - 400hp range, which covers most of the cars out there that are modified.
I have fitment pages for wheels and tires here:
http://fc3spro.com/TECH/MODS/RT/rims.htm
http://fc3spro.com/TECH/MODS/RT/tires.htm
Old 03-11-2016, 10:47 AM   #21
By the By.... 18's on an FC
Old 03-11-2016, 10:54 AM   #22
FC Zach
FC Zach's Avatar
See DJ, that looks good! Old man!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-11-2016, 10:55 AM   #23
Looks queer.
Queer.
Old 03-11-2016, 10:57 AM   #24
FC Zach
FC Zach's Avatar
Alright! Alright! I'm getting off your lawn! !
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-11-2016, 10:58 AM   #25
Old 03-11-2016, 11:03 AM   #26
FC Zach
FC Zach's Avatar
I think they look great Brian!
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-11-2016, 11:11 AM   #27
Thanks Zach! Fitment was TIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIGHTer than virgin ass
Old 03-11-2016, 11:22 AM   #28
FC Zach
FC Zach's Avatar
To be safe, I'm thinking I'll need to go with a coilover setup. . Shit's close with a stock wheel and I don't want to be pulling fenders, the poke and stretch thing just isn't my style.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 03-11-2016, 11:28 AM   #29
infernosg
IT'S ALIVE!
infernosg's Avatar
I liked the look with 16's I had on my old red FC. It's too bad wheel and tire options are so limited with 16's. I need to get a good picture of the setup on the orange FC: 17x9 +22 with 255/40R17 all around although there's no way that will work with stock fenders.
Old 03-11-2016, 12:31 PM   #30
They look good. Better than the owner for sure.
Still too big. Like donkey dong. Right Bri-bri?
