Closed Thread
Old 02-14-2016, 06:17 AM   #1
Deividas
Deividas is on a distinguished road
question about rotor gears
Hello, i'm novice at rotary engines and new member at this forum
I'm interested in these engines, and wanna ask question about stationary and rotor gears. All info, that i can find, says, that these gears ensures the rotor moves exactly 1/3 turn for each turn of the eccentric shaft, but then how rotor can move differently, if there would be no gears? Can it move more or less than 1/3 turn for each turn of the eccentric shaft? Sorry if question is dumb, but i'm novice and i like to know
P.S. sorry for my english, it's not my native language
Deividas is offline
Old 03-24-2016, 04:52 AM   #2
Slides
Slides is on a distinguished road
You need the gears to constrain its motion or it would just crash the lobes of the rotor into the housing at random. It needs to be phased rotation to allow it to contain the different cycles or "strokes" too.
Slides is offline
Old 03-24-2016, 10:20 AM   #3
Pete_89T2
Pete_89T2's Avatar
^What he said, but to clarify a bit, the gear ratio is tied directly to rotor/housing geometry. So for the Mazda design, which is a 3 sided rotor, it has to be a 1:3 ratio - rotor turns 1/3 for every full revolution of the E-shaft to complete a 4 stroke Otto cycle of a internal combustion engine with a 3 sided rotor.
So for example if you designed a rotary engine with a 4 sided rotor and appropriate housing geometry to suit, the ratio would be 1:4 and so on.
Pete_89T2 is offline
Closed Thread
