Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 09-30-2015, 08:48 AM   #16
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
The point is to see the back pressure before the turbo. Post turbo emap would not give any really useful information unless the exhaust is very restrictive.
Hmm... Why is that? (Sorry to derail the thread, I'm honestly curious).
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 09-30-2015, 09:40 AM   #17
C. Ludwig
Rotary Masochist
Pressure in the manifold will be a cumulative of manifold and tail pipe pressure. It will always be higher than tailpipe pressure. If you're mapping your fuel map as a MAP v. EMAP, you'll need to know manifold pressure. Tail pipe pressure is useless for this calculation because it disregards manifold pressure. Monitoring tail pipe pressure is only useful in a sense that you want it to be as low as possible and therefore would want to know if it's relatively high.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 09-30-2015, 10:49 AM   #18
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Interesting... Wish I didn't know that now! I def intended to have EMAP as an input for my F88, but I don't know if I'll have space for both EGT AND EMAP bungs on both runners.
I feel like there would need to be a LOT of heat dissipation to keep from blowing out sensors if you took readings in the manifold as opposed to the DP..
Sometimes I think life would be more simple without knowledge (Ignorance is bliss and all that... lol)
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 09-30-2015, 01:23 PM   #19
C. Ludwig
Rotary Masochist
For EMAP you need a long run of tubing to dissipate the heat before the sensor. Think Pete had some good pics of his own arrangement. AEM sells a kit with a sensor, bung, and SS tubing.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 09-30-2015, 01:30 PM   #20
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Yeah, in my minds eye I'm seeing like 10' of copper or aluminum tube that runs away from the heat source, then just coils along the firewall for like 2' until reaching sensors mounted near the wiper blade motor.
My concern with that would be the potential for a pressure drop due to the turns and distance required to cool the air enough for sensors to last a reasonable amount of time.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 09-30-2015, 01:54 PM   #21
C. Ludwig
Rotary Masochist
More like 24" total. You're overthinking it.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 09-30-2015, 01:56 PM   #22
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Fair enough.
I've had "accidents" as a result of NOT overthinking it in the past, so I figure it might be better to go with the "moar is bettar, because MOAR!" approach
(But yeah, the 10' figure was intentionally overzealous, I wouldn't ACTUALLY try to stuff 20' of metal line in there for a pair of EMAP sensors )
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 09-30-2015, 02:23 PM   #23
RXtacy
RXtacy's Avatar
Originally Posted by Fendamonky View Post
Fair enough.
You only really need one EMAP sensor.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 10-03-2015, 03:34 AM   #24
Ric Shaw
Ric Shaw Racer
Ric Shaw's Avatar
Ric Shaw is on a distinguished road
Well done.
Nice work Elliot, cast is the way to go. I have always used cast manifolds to handle heat. your design is great.
Ric Shaw is offline   Reply With Quote
Old 10-30-2015, 12:38 AM   #25
RICE RACING
Don Mega
RICE RACING's Avatar
One day, some day, I'll test this set up, hopefully sooner than later.............. 6 mother fucking months!
Old 01-05-2016, 07:55 PM   #26
shawnm565
shawnm565 is on a distinguished road
We have 9 Turblown BorgWarner EFR IWG Cast Manifold Turbo kits Available for sale for the FD & FC Chassis.
The Kit gives you the choice of three different size of the BorgWarner EFR IWG Series Turbo's:
EFR 7670 - $3,999.00
EFR 8374 - $4,249.00
EFR 9180/9174 $4,499.00
The kit includes the following:
* Your choice of T4 EFR 7670 IWG,8374 IWG, 9174, or 9180 IWG turbocharger
* Stainless hard line turbo cooling lines( oil feed, coolant feed/return & Flexible oil compatible heat shielded oil return line) & hardware
* 304SS TIG welded & back purged Mandrel Bent 3" V-Band downpipe with single o2 sensor bung, vband clamp and 2 bolt gasket/hardware
* 347SS Investment Cast Tapered IWG turbo manifold
* Replacement WG actuator bracket Adapter for necessary placement
* Inconel T4 Turbo Gasket, and Inconel turbo manifold studs & nuts
* Rear turbo oil return block off plate
* K&N 3.5" or 4" air filter depending upon size of the turbo selected
* 2 feet of fire wrap heat sleeve
* FD heater core hardline replacement with new hose and clamps
Please contact our Sales Manager Shawn Christenson to place your order. 763-753-9939
shawnm565 is offline   Reply With Quote
Old 01-07-2016, 11:43 AM   #27
Just so everyone is aware, I plan on cleaning this thread tonight over cocktails.
Posts will be deleted
Threads will be created
Links will be added
Any issues should be directed to me via PM. But don't expect a response until Monday
Old 01-07-2016, 08:36 PM   #28
And for anyone wishing to continue....
http://rotarycarclub.com/rotary_foru...ad.php?t=18861
Old 06-06-2016, 05:03 PM   #29
Turblown
Turblown is on a distinguished road
We are now onto our 2nd group buy. We have 80 cast manifolds almost finished, and have tweaked the kit a little bit more to improve everything.
http://www.turbosource.com/Turblown-...efriwgcast.htm
Turblown Engineering - Rotary Turbo Kits, Rotary Adaptronic ECUs and Rotary Performance Parts.
TurboSource - Performance TurboChargers, Inconel Heat-Shields, and Adaptronic Distribution
Turblown is offline   Reply With Quote
Old 07-07-2016, 09:44 AM   #30
Turblown
We are at 13 deposits.
Also we managed some good numbers yesterday on one of our shop cars with the cast 8374 IWG kit
borgwarner efr, turblown, turblown.net
