Go Back   Rotary Car Club > Multimedia > Videos, Photos, Manuals, > 1st Gens
Old 03-03-2008, 04:42 PM   #1
Bryan@BNR
Bryan@BNR is on a distinguished road
BNR's 1st gen REW powered Dyno vids
This is my 1g RX7 in the process of building. Doing a 8.8 swap which probably won't be done for Deals Gap in April, but I will have it done sometime this year.
84 GS converted to 5 speed
Race ported REW with all OEM seals/springs
T2/FB hybrid transmission which is bolt up with no cutting on the car
62-1 TO4B turbocharger .85 a/r Comp-1.00 a/r turbine housing
HKS T04 Cast divided manifold
HKS Racing wastegate
3.5" down pipe and full stainless 3" exhaust with 2 magnaflow mufflers
NPR large intercooler
3" intercooler pipes with China Tial blow off valve
Haltech E6K engine management (tuned by Steve Kan)
550-1600 staged injectors
300ZX fuel pump intank with custom lid for tank
Adjustable FP regulator
Custom BeCool Radiator with siocco cooling fans/shroud
DYNOed 440.2 RWHP/ 356 RWTQ at 20 psi of boost outside temps were around 100F on the dyno
http://www.youtube.com/watch?v=fcMZJn8jKfQ
http://www.youtube.com/watch?v=Ja2Wh...eature=related
Future plans for the car is:
Snow Performance stage 2 methenol injection kit
T67 T4 with tubular stainless manifold
and most important A/C
Bryan@BNR is offline   Reply With Quote
Old 03-03-2008, 04:56 PM   #2
How high did you rev that thing?
Old 03-03-2008, 11:53 PM   #3
Bryan@BNR
The first vid it was about 7600 RPM the second one was 8-8300 RPM. Limiter is set up at 8300.
Old 03-03-2008, 11:56 PM   #4
Thanks. I just say the tach disappear so I couldn't tell. BTW, sounds great and can't wait to see it. Planning on running it at SpeedForSale 08?
Old 03-04-2008, 12:44 AM   #5
Bryan@BNR
I just want to start driving it to be honest with ya. I am trying to eliminate all the weak links of the car so I can put down 450-520 RWHP and the car be somewhat reliable. I think 450 RWHP is about the limit for reliabilty with a REW motor properly tuned. You can make more but there is more upkeep changing plugs more frequent, running race fuel. I will run the car for a while with the 62-1.
Old 12-26-2008, 09:51 PM   #6
orion84gsl
Try methanol injection. lots of gains to be had, or just run it for the sake of cooler a/f mixtures, and less chance of detonation.
Old 12-26-2008, 11:25 PM   #7
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
Maybe I should have paid more attention to this. I have a large hole in my floorboard.
staticpat is offline   Reply With Quote
Old 12-27-2008, 01:50 AM   #8
x2 lol
Old 12-27-2008, 03:09 AM   #9
rx7 FC TII
rx7 FC TII's Avatar
haha pat ya you might want to look more into that.
Old 12-28-2008, 12:51 AM   #10
sk8world
600rwhp club member.
sk8world is on a distinguished road
Brian, I just saw this for the first time! Very nice... I bet it will be very fast with that amount of power and weight!
sk8world is offline   Reply With Quote
Old 12-29-2008, 10:50 AM   #11
dang
Old 02-16-2009, 10:28 PM   #12
Nutsid
Temporarily insane.
Nutsid's Avatar
Awesome car. I love it.
Kindle
Nook
Old 03-04-2009, 10:31 AM   #13
Bryan@BNR
thanks guys. I did the 8.8 swap and now minus a few things. I have to flare out the rear a bit to clearance for the 255 drag radials. I also completed the methenol injection kit. The only thing left is the T67 set up and it will be ready to make 500.
The transmission took some time to do. Setzep from the other forum did this as well. The 2 tail housings are interchangable. You have to shorten the linkage tube and weld it to the correct length. Also after the tail housing goes on, A custom trans mounting bracket has to be made. It is involving, but worth not hacking up a car.
Bryan
Old 03-04-2009, 01:10 PM   #14
sk8world
Nice Brian.. I have been wanting to do an auto set up with a transbrake-big 6800 stall. Maybe a solid rear too. I know of one guy that did the th400 tranny but had bad issues and the gearing was way off. Top speed was 130mph....
6.? @ 11? drag pass
http://www.youtube.com/watch?v=9wfxT2RMr7c
Old 03-05-2009, 11:10 AM   #15
Bryan@BNR
The Turbo400 is a 3 speed. You will have to run some lower gears or way taller tires to get any mph out of it. Plus some Torque! Anyway, you will give up all your streetability with the ultra High stall speeds. The bands always slipping will cause trans fluid temps to get really hot. Then you screw up stuff. You need a good gear box. Possibly a 4+1 doug nash or a Richmond 5 speed. They would be your cheapest options. Other than that the Dog box is also an expensive option.
Do a T2 rear chunk and some chromoly axels in the rear and you should be fine with the IRS. Go until you break it I guess .
