Closed Thread
Old 08-22-2015, 01:29 PM   #151
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
^I hate when that happens. One little thing takes forever and you feel like you got nothing done. Not quite infuriating, more annoying I think.
It did annoy me. Especially when I had to wait for parts, and then they wouldn't work.
GySgtFrank is offline
Old 08-23-2015, 01:55 AM   #152
Now THAT is infuriating, for me anyway.
speedjunkie is offline
Old 08-23-2015, 01:32 PM   #153
GySgtFrank
GySgtFrank's Avatar
in the interest of full disclosure ... oops!
oops by Kevin Frank, on Flickr
Routing the pipe down and back I found that I had goofed. The cross bar supporting the back of the fuel tank was in the way of the radius on the top exhaust pipe. I could have just run it lower, but then the pipes would be a lot further down than I wanted. Solution: break out the cut off wheel and trim that out of the way. I will need to remove the tank again and put an L shaped piece in there after I get the rest of the exhaust run back between the tank and the rear spring. Always some niggling little thing to brighten the day.
Old 08-23-2015, 04:47 PM   #154
chibikougan
chibikougan's Avatar
Ya big goof!
chibikougan is offline
Old 08-26-2015, 01:00 PM   #155
GySgtFrank
GySgtFrank's Avatar
Rear pipe section done connecting the muffler to the axle portion of the exhaust system.
rear muffler connector pipe by Kevin Frank, on Flickr
bolted in:
rear muffler connector pipe - installed 3 by Kevin Frank, on Flickr
rear muffler connector pipe - installed 2 by Kevin Frank, on Flickr
rear muffler connector pipe - installed 1 by Kevin Frank, on Flickr
Old 08-26-2015, 01:03 PM   #156
GySgtFrank
GySgtFrank's Avatar
Some shots of the exterior view for those of you wondering how far it sticks out below the car.
rear muffler connector pipe - exterior 2 by Kevin Frank, on Flickr
rear muffler connector pipe - exterior 1 by Kevin Frank, on Flickr
Old 08-29-2015, 02:57 PM   #157
GySgtFrank
GySgtFrank's Avatar
While I'm waiting for more funds to purchase pipe and flanges, I figured this was a good time to address some of my goofs and concerns. There was some concern about how close the exhaust pipe would be to the tank. Indeed it was a bit closer than I cared for as I had it. So I pulled the tank and bent the right side flange downward. This allowed me to move the tank over a little bit more to the right. I also massaged the left rear corner of the tank with a big rubber mallet. After re-fitting the tank, I found that probably wasn't necessary. The extra 3/4", or so, that I gained by moving the tank had given me plenty of room.
exhaust clearance - tank & spring 1 by Kevin Frank, on Flickr
exhaust clearance - tank & spring 2 by Kevin Frank, on Flickr
exhaust clearance - tank & spring 3 by Kevin Frank, on Flickr
I also used a half moon cut section of thick wall pipe to bridge the gap created when I had to trim my rear tank support. The tank was remounted so that the back flange of the tank sits up against the bottom of the support, instead of over the top of it. I did this because I am looking at putting in either a watts link or panhard rod. Getting the tank in and out would have been a problem the way I had it. There will be very little room left behind the differential so the stock emergency brake pedestal has to be moved/rethought to get a bar in there. From the little bit that I have been able to drive the car I could tell that it needs positive axle location badly.
Old 08-29-2015, 03:07 PM   #158
JL1RX7
Gunny - How close are you getting to firing it up? It is looking good so far.
JL1RX7 is offline
Old 08-29-2015, 03:31 PM   #159
GySgtFrank
GySgtFrank's Avatar
Still a ways out.
I have to finish the exhaust, run wiring, and close up/reinforce some of the body and frames mods I made. Oh yeah, a radiator and driveshaft would be nice as well.
I have to get things done in a certain order so that I don't cause myself more extra work than I do already with my little goofs. The exhaust is one of those things that has to get done first, so that it actually fits when I go to put it back together. I don't want to pull the engine and transmission again until that is in place, as it may affect fitment.
The harvest will be coming in anytime now. So once the corn dries enough to cut, I will have to go to work. I will lose two months or so of tinkering time when I get the call for that. The positive side is that I should have the money to buy the bits that I can't build myself.
Old 09-14-2015, 09:09 AM   #160
GySgtFrank
GySgtFrank's Avatar
While waiting for funds to buy more exhaust parts I have been trying to get a few minor things done. I haven't accomplished a whole lot, but I did manage to finish fabricating and installing the muffler box heat vents. These replaced the back up lights in the rear panel.
heat vents 1 by Kevin Frank, on Flickr
heat vents 2 by Kevin Frank, on Flickr
The focus on the first picture wasn't very good, but you get the idea.
Old 10-24-2015, 05:29 PM   #161
GySgtFrank
GySgtFrank's Avatar
Done with work, so back to the car. Ordered exhaust parts from Racing Beat and am in search of perforated SS tubing to build a couple of mufflers. Also in need of an S4 wiring harness which I have not been able to find as of yet.
Old 10-26-2015, 08:47 AM   #162
RXtacy
RXtacy's Avatar
http://www.amazon.com/LA-Choppers-Pe.../dp/B0041CAFXK
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
RXtacy is offline
Old 10-26-2015, 09:12 AM   #163
GySgtFrank
GySgtFrank's Avatar
Thanks, that was one of the suppliers that I was looking at. It comes in 24" cut lengths. I was hoping for something longer, but it would work in a pinch. Most of the manufacturers are in China, no surprise there, but shipping nixes small quantities from there. There is also a manufacturer in MI that I was going to call today.
:edit: I went ahead and ordered through them on their website. They offer 4 ft lengths as well as the 2 ft. It isn't exactly what I wanted as it is only 22ga. instead of 16 ga. and it doesn't say whether it is welded or the sure lock tubing. We'll find out when it gets here I guess. Either way I'll make it work.
Old 10-26-2015, 01:13 PM   #164
FC Zach
FC Zach's Avatar
Looking forward to seeing this little car, this thing should be a hoot to drive!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 10-26-2015, 01:18 PM   #165
GySgtFrank
GySgtFrank's Avatar
I'm thinking it should be Zach. I always thought the rotary and the lightweight Midget body would be the perfect match. Pushing hard to have this one at DGRR. My track record for getting a car there is less than admirable though.
Closed Thread
