Old 03-03-2008, 03:49 PM   #1
BULBS!! All the locations and type..
1993 MAZDA RX-7
High & low beam headlamp
9003/HB2
Parking light
168
194
Front turn signal
3497
Rear turn signal
1156
Tail light
1157
Stop light
1157
High mount stop light
921
Fog/Driving light
H3-55W
License plate
168
194
Back up light
1156
1157
Cornering
1157
Front sidemarker
168
Rear sidemarker
194
Glove box
194
Map light
168
Dome light
168
194
Trunk/Cargo area
DE3175
Instrument-general
194
__________________________________________________ __
Old 03-03-2008, 07:46 PM   #2
ObliqueFD
ObliqueFD's Avatar
ObliqueFD is on a distinguished road
Have you ever replaced the ignition keyhole light? Mine is burnt out and it appears to be hardwired in.
ObliqueFD is offline   Reply With Quote
Old 03-03-2008, 09:34 PM   #3
SLOASFK
SLOASFK's Avatar
SLOASFK is on a distinguished road
to the best of my knowledge, both the ignition keyhole light and the drivers door keyhole light are hard wired LEDs. Nothing a quick cut and a little soldering won't take care of. Baja posted a great writeup on replacing the drivers door keyhole light on the evil forum. I'd quote it, but with the threat of lawsuits now, I'm not going to bother.
SLOASFK is offline   Reply With Quote
Old 03-07-2008, 05:33 AM   #4
If you don't mind quoting it.. There is NO lawsuit! Especially if you give a source.
Old 03-11-2008, 12:25 PM   #5
3tegStrong
XRANNIE
3tegStrong's Avatar
3tegStrong is on a distinguished road
great info- copied n saved!
got peter?
GO NAVY..Thanks to All who've served!!!!
http://www.theautolog.com/3tegstrong-1
3tegStrong is offline   Reply With Quote
Old 03-13-2008, 02:34 PM   #6
SLOASFK
SLOASFK's Avatar
Taken from http://www.rx7club.com/showthread.php?t=677186
Originally Posted by bajaman
The door lock light is only on the driver's side. It comes on for about 3 minutes when you lift the handle. It is easy to fix, you simply remove the plastic cover at the rear of the inside door directly opposite the handle, take off the 10mm nuts and lift the handle assembly off from the outside, you will only be able to get it a short distance from the door as all the cables/rods will be attached. But...you will see two white wires going into a rubber cavity. If you look hard this rubber cavity is actually a rubber plug that goes into a rubber cavity. Get some small needle nose pliers or a small pick and gently pry the rubber 'tube' carrying the small bulb out. Then you can pull the bulb out of the rubber tube thingy. Over here I go to Radio Shack and get a 12 volt 'grain of wheat' bulb. They have various colours. One that I got was cool as hell, it had two small pieces of heat-shrink tubing included. Anyway, just cut the leads as close to the bulb, slide some appropriate sized heat shrink tubing over the leads a ways back to give you some room, solder in the new leads, slide the heat shrink tubing up and apply some heat and, voila! Now just put the bulb in the rubber tube thingy, and...this is the fun part....slide the tube back into the cavity. It helps to apply some sort of lube, I went with a silicone based stuff I use on 'O' rings and it slid right in.
Enjoy this semi-cool little feature of the FD.
