Go Back   Rotary Car Club > Multimedia > Videos, Photos, Manuals, > 2nd Gens
Old 06-30-2008, 06:02 PM   #1
SpooledupRacing
Guest
Posts: n/a
my race
http://youtube.com/watch?v=wQen5hFMGHI
My car
86 RX7
13BT Swapped
N/A drive train
6 puk Spec clutch
Fidanza flywheel
stock S4 turbo 3" V-band downpipe
LARGE street port
Large exhaust port
6psi
FMIC
STOCK S4 ecu
720cc secondarys
550cc primarys
Competitor
240sx
SR20DET swap
16psi
aftermarket ECU
FMIC
IC hard pipes
first time the camera shut down cause a car was coming so I did not run
2nd time he said he had no traction
3rd race he launched and got the pull untill I hit second...
SEE YAAAA!
btw since I am using the n/a drivetrain I cant "launch" all of those are rolling out the clutch then stompin on the pedal.. I NEVER launched the car
oh yeah and on the last run I blew my IC pipe off and still won
Old 06-30-2008, 06:18 PM   #2
why are you wasting gas on a 240?
go kill a V8 and redeem yourself. Or at least win some gas money if you're gonna go waste it on slow cars.
you have a light FC + turbo so no matter what, YOU WIN. How's the tranny and rear end holding up? Everyone says that the NA drivetrain is weak while others say it's fine for a stock 13BT. How do you like it so far?
I believe it's weak but i'm only basing it on an NA motor.
Old 06-30-2008, 06:28 PM   #3
SpooledupRacing
Guest
Posts: n/a
sr20det (turbo swapped car on 16psi) against my measily 6psi
I figured it would be a close race... guess I was wrong..
I wont be racing till I get the engine pulled and the ring replaced.
then I will take it to a dyno and a track to get times.
he said he ran 13.1 in the 1/4 I beat him by 3 cars atleast
Old 06-30-2008, 06:32 PM   #4
I NOTICED that it said SR20 in your description but KA-T in the vid. Either way you rocked him and I don't see how it's a 13 sec. car.
See edits above also.
Old 06-30-2008, 06:49 PM   #5
SpooledupRacing
Guest
Posts: n/a
the person that posted that was not there.. he told me it is a SR20DET
the trans is starting to grind into 2nd and 3rd but it pulls fine.. the rear end is fine to (not LSD)
Old 07-01-2008, 10:51 AM   #6
Street racing is bad Mmmmmmkkkkkkay.
Old 07-01-2008, 04:37 PM   #7
josh18_2k
yah.. that is not a 13.1 second 240.
and the NA rear end is good to around 300hp. you'll prolly blow it up eventually with 200 or whatever, but after 300 they wont last more than two clutch drops.
ps street racing is bad-
go to a drag strip! ok i get that you dont wanna blow up your drivetrain. o well.
