Old 06-18-2008, 12:59 PM   #1
Rex7
"It ain't no secret"
Rex7's Avatar
Rex7 is on a distinguished road
alternator problems
what gives i've gone through 3 of alternators in a years time. would an aftermarket pulley cause the problem. i've also relocated the battery to rear of the car.
Rex7 is offline   Reply With Quote
Old 06-18-2008, 01:11 PM   #2
well, I'm having the same problem with my S5. I've been through 3 in the past 6 months.
I Keep killing the voltage regulator. I was told that it could be a faulty battery or the wiring that goes from the B-terminal to the battery. I just rewired the connection from the B-terminal to the battery (bypassing the stock one) and I'm going to see if the Alternator dies again.
IF the alternator survives longer than 2 months (that's the time it took to kill the last alternator) then I know it's the wiring. If not then I'll try another battery.
I feel your pain.
Now, IF your belts are not tensioned properly they could cause your alternator to fail. You can't have one tight and another one loose. You can't have them both on too tight and you can't have both too loose. Screwed if you do and screwed if you dont.
Double check to make sure the alternator, pullies and belts are in good shape and try avoid the issues above.
Old 06-18-2008, 01:26 PM   #3
Rex7
Rex7's Avatar
i've only got one belt. I did the rewire to the terminal. i'm waiting on a battery to come in tomarrow. i've got a yellow top it's only 625 ca and i'm getting a red top with 910 ca.
Old 06-18-2008, 01:28 PM   #4
cool. Did you do the re-wire on the current, dead, alternator? or on the new, WORKING, alternator you're getting?
Old 06-18-2008, 02:02 PM   #5
Rex7
Rex7's Avatar
the current or dead one had the rewire.
Old 06-18-2008, 02:16 PM   #6
hmmm, how long did it last with the wire? Did it last longer than the old alternator?
Let's hope it's a bad battery (it happens sometimes) otherwise we'd need to figure out what the problem is (since I JUST did the rewire on the alternator with the new voltage regulator and I'm not sure if the problem will persist.) if the modification + new battery doesn't help.
Let me know how it goes for you.
Old 06-18-2008, 02:44 PM   #7
What kinda Voltage is it putting out when it works?
Old 06-18-2008, 03:12 PM   #8
Rex7
Rex7's Avatar
the last alternator lasted about a month and a half. but when i got it the casing on it was cracked. got it from auto zone. they're replacing it for me. i'm hoping it's the battery. it's been over charged by a battery charger that got posessed. been left completely dead for 5 mos. when i was in alaska. it even had juice come out of it once. it has been around for the last 4 years and always tested fine at auto zone. as far as voltage it usualy reads 14.1 to 14.6.
Old 06-18-2008, 04:57 PM   #9
well, we both agree that it takes 1.5 to 2 months for the alternator to die so let's see how it goes. You may have battery issues and I may have wiring issues. How crappy.
I've never had problems with my yellow top so i think the red top should be fine but they may require special procedures to recharge. I accidentally killed the yellow top in my TII when I charged it improperly. Keep that in mind.
Old 06-19-2008, 06:40 PM   #10
Rex7
Rex7's Avatar
Phoenix7 with my battery issues your wiring issues we might be able to get one of them right.lol. got done putting everything in today voltage is back to reading 14.4. hopefuly everything goes well.
Old 06-19-2008, 06:57 PM   #11
Let's hope it doesn't act up. We'll know in a month or two.
Old 07-19-2008, 03:31 AM   #12
Oliv
Oliv is on a distinguished road
My voltage can vary from 13.7 at iddle to 14.4. something wrong here?
Oliv is offline   Reply With Quote
Old 07-19-2008, 08:21 PM   #13
DaveW
DaveW's Avatar
DaveW is on a distinguished road
Somewhat off subject, but rebuilt alternators often can be junk. Just because it was old, I replaced a perfectly good but 190K mile alternator on a Chevy Van I use to tow my racecar with a rebuilt - the rebuilt died (bearing failure) in less than 10K miles, and I had to reinstall the 190K one in the middle of the night on the road.
Rebuilders often just replace enough stuff so it works, everything else not absolutely needed is still the original old stuff.
Dave
'93 Base VR bought new in March 1992, PFS SMIC & CAI (modified), HKS DP w/ Jet-Hot 2000, RB dual-tip CB, Linearized OE temperature gauge, Dual "Home-Depot" ceramic ball-spring MBC's, Pettit AST
DaveW is offline   Reply With Quote
Old 07-19-2008, 08:23 PM   #14
DaveW
DaveW's Avatar
sounds normal to me...
Dave
Old 07-19-2008, 11:49 PM   #15
blwnrtr93
blwnrtr93's Avatar
blwnrtr93 is on a distinguished road
^ That's what I was thinking. The voltage isn't going to be 100% constant, but will usually vary from 13.5 - 16.5 volts depending on the system. My old truck (63 Chevy V-8 conv. w/ stock I-6 alt.) used to see 14.4 constant (didn't have a radio or any accessories).
1993 BB RX-7
2005 Black Mazda 6i
1991 Primer Celica GT
1968 Camo Chevy P/U
Garfinkle's Airpump Idler Pulley: Keep the stock contact patch on your water pump w/o running Airpump!
blwnrtr93 is offline   Reply With Quote
