Closed Thread
Old 04-01-2014, 07:08 PM   #226
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Originally Posted by mazpower View Post
Badass Kevin!
Did you still want a bellhousing? I might be able to tow it behind my car LOL...
Whenever you get a chance. Like I said, I kind of have my hands full with this part of the project at the moment.
GySgtFrank is offline
Old 04-01-2014, 08:21 PM   #227
mazpower
Rawr Bearclaw
mazpower's Avatar
Will you have a way of bringing it back to KS with you from DGRR? Or is shipping better?
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline
Old 04-01-2014, 08:24 PM   #228
GySgtFrank
GySgtFrank's Avatar
We'll probably have to go with shipping, as I'll be flying this time. I don't think I'm going to have the car together in time.
Old 04-05-2014, 08:53 PM   #229
GySgtFrank
GySgtFrank's Avatar
I finally got the rear portion of the driver's side wheel well done. It was a pain as I had to make it from small sections of flat sheet, heat and bend them, then weld the whole mess in. The welds are smoothed and I have primer on it anyway.
Old 06-01-2014, 12:04 AM   #230
chibikougan
chibikougan's Avatar
Damn fine for no sandbag, planishing hammer, and English wheel
chibikougan is offline
Old 06-01-2014, 02:44 PM   #231
GySgtFrank
GySgtFrank's Avatar
I'm not that fancy. I just want to get it back on it's wheels and moving.
Currently paying the price for trying to work on a GM product. I need to get back on the RX-7, but the @#$%* truck has other ideas. The up side is that it gives a perspective on just how good the Mazda engineers were, (and just how bad GM is).
Old 06-02-2014, 07:19 AM   #232
Yeah.... fuck gm
What's the latest on the 7? Or has she been shunned for the POS PU?
TitaniumTT is offline
Old 06-02-2014, 02:25 PM   #233
GySgtFrank
GySgtFrank's Avatar
Yeah.... fuck gm
I keep looking at it and wishing I was working on that instead.
I've been through 3 engines and two chassis' with this POS and still no joy. All of my spares turned out to be garbage and the original still won't run. If you think Microwreck ECUs are bad, try screwing around with the early stock GM TBI ECU. Finding wiring diagrams and information is almost impossible (Chilton and Haynes books must have been written by people working at GM, utterly useless), it's as if GM thinks they're data is Top Secret. I'm at the point where I'm about to yank the whole works and push it off to the side, until I can afford to build an old school carbureted and HEI ignited small block. They were the last thing Garbage Motors built that was worth a crap. This thing is just not worth the headaches.
Old 06-18-2014, 01:17 AM   #234
GySgtFrank
GySgtFrank's Avatar
back to work by GySgtFrank, on Flickr
... and back to our regularly scheduled programming.
Old 06-18-2014, 01:27 AM   #235
chibikougan
Cool!
Old 06-18-2014, 01:15 PM   #236
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
Thumbs up
Glad to see you back at it, one of my favorite first gens.
I hope to see it next year at DGRR
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline
Old 06-18-2014, 01:41 PM   #237
GySgtFrank
GySgtFrank's Avatar
Thanks, so do I.
Do you think you'll have your FB ready by next year?
Old 06-18-2014, 06:07 PM   #238
estevan62274
Thanks, so do I.
Yeah, that's the plan but it was the plan last year and it didn't happen
-74 RX-4
-84 REW GSL-SE
Past rides
-93 FD base
Old 06-18-2014, 07:28 PM   #239
GySgtFrank
GySgtFrank's Avatar
It sounds like you're on the same plan I am. I need to get a different plan.
Old 06-22-2014, 12:28 AM   #240
GySgtFrank
GySgtFrank's Avatar
Finally done with the grinding on the left side and threw a quick coat of primer on there. I can no longer get the good 3M etching primer here, so I had to make do with Krylon. Which is why there is a color change in my primer.
Oh well. I'm not going to get carried away with paint yet. A good rattle can job will do in the engine bay until I'm done with the engine and all likely mods. I'll then have everything media blasted and use filler (or lead?) to smooth everything out prior to laying on the actual finish coat.
left wheel well 1 by GySgtFrank, on Flickr
left wheel well 2 by GySgtFrank, on Flickr
left wheel well 3 by GySgtFrank, on Flickr
left wheel well 4 by GySgtFrank, on Flickr
... and a shot of both wheel wells done and in primer. It's amazing how much faster and easier it always is to tear stuff apart rather than putting it back together again.
left and right wheel wells by GySgtFrank, on Flickr
I still have to do a little cleanup on the bottom of the right side and get it in primer, then I'll be finished with the sheet metal portion. Then back to the lower K-member/upper shock mounts. *groan* I have to put it all back together again. at least once and probably more, just to check measurements and then take it all back apart again for final fixes to both.
Yes I will get this done this year. At least until I tear something else apart and have it laying in pieces again. I suffer from a little recognized malady known as Brian Treffeisen's Disease, or CQFWI (Can't Quit F***ing With It).
Closed Thread
