#301 | |||
Get off my lawn!!!
Rep Power: 15 ![]() |
![]() Bianca wants a big kitchen (for more baking) and I want a big garage (for moar cars)... I think we'd be good with a 500sq/ft house if it had a 100sq/ft garage and a 50sq/ft kitchen Quote:
Fucking asshole ![]() ![]()
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
#302 | ||
Rep Power: 17 ![]() |
Yeah I hear ya my brain just doesn't want to leave it. its a way off either way.. We can continue in BAW so we don't muddie your thread.
#303 | |||
![]() Quote:
#304 | ||
Get off my lawn!!!
![]() Ok, so I screwed up on the dimensions off the top of my head...
#305 |
The front is identical, the rear doesn't have the oring grove so you have to use sealant. There's no "upgrade", other than they are cheaper new.
#306 |
Rep Power: 10 ![]() |
Negative.... while the stat gears themselves are the same, the bearings are not. If mixing and matching 13B-REW and 13B-MSP eshaft and bearings, tolerances MUST be checked. Also, there is a taper in the rear of the MSP shaft, and like you said, there is no o-ring so it must be sealed. They are minor differences but they need to be addressed if you're a cheap fuck. If you just buy the MSP shaft and stat gear/bearing assemblies, you just slap them in.
#307 | |
#308 |
Yes, PN's are the same but when you buy a stat gear with bearing, the supplied bearings are of different clearances though.... at least the ones we got @ S1 were.... hence... they all need to be checked... or should... most people don't.... they just say... not enough copper showing to throw these away
#309 |
Get off my lawn!!!
Wait... so if the metal gear itself is the same, and its just the bearings which are different... I could just pick up the rx-8 bearings to match the rx-8 eshaft??? I'm thinking pressing in the different bearings would be much cheaper than buying the entire set, IF it would work and that's really the only difference...
Yes?
#310 |
Get off my lawn!!!
I honestly don't plan on getting them as an "upgrade" but rather as a matching set for the 8 e-shaft. But if swapping bearings would make them all line up right...
#311 |
Get off my lawn!!!
So I was reading over the FSM this evening when there was a knock at my door....
![]() It was the Fedex guy ![]() He brought me a little something-something.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() A Wild Life Racing ECU has appeared!
#312 | |
#313 |
Nice ECU Levi
#314 |
Get off my lawn!!!
Thanks Mike
![]() Now if only I hadn't recently gotten slammed with life expenses that stole all the money I was going to use for building this things harness (and engine)!! lol
#315 | ||
![]() Quote:
