Old 01-10-2014, 08:05 PM   #76
scarsofcarma
scarsofcarma's Avatar
scarsofcarma is on a distinguished road
Originally Posted by Whizbang View Post
truth be told the 12a and the 13b transmissions are both M-type. there is no difference in durability. Not until you move up to the R type (turbo transmission) Mine is the 12a case, with miata gears. Which was in my old rally car for a couple years without issue.
Ah so you are running miata 5 speed gears which features a non-overdrive 5th gear correct? Also, I forget did you say you have another Weber somewhere?
scarsofcarma is offline   Reply With Quote
Old 01-10-2014, 11:23 PM   #77
check out the trans diff FAQ
Mazda Miata Gearbox
1st: 3.136
2nd: 1.888
3rd: 1.330
4th: 1.00
5th: 0.814
Old 01-11-2014, 05:42 PM   #78
scarsofcarma
12A Engine Swap (Cont.)
Mazda Miata Gearbox
1st: 3.136
2nd: 1.888
3rd: 1.330
4th: 1.00
5th: 0.814
vs what I'm running right now...
Mazda Rx-7 87-88 13B 6PI (Type M) Gearbox
1st: 3.475
2nd: 2.002
3rd: 1.366
4th: 1.00
5th: 0.697
and my original GSL-SE transmission...
Mazda Rx-7 84-85 13B (Type M) Gearbox
1st: 3.622
2nd: 2.186
3rd: 1.419
4th: 1.00
5th: 0.807
I agree the Miata gearbox seems like a good bet. Lower 1st and 2nd gears should be better in the mountains and the shorter split between 2nd and 3rd should improve overall driveability. The .814 overdrive should even allow for some acceleration in 5th... hard to say if it could improve overall top speed though. In the past when I've tested top speeds on various cars, the rev-limit in 4th gear is the maximum gear-limited top speed unless you have enough power to overcome all that wind resistance in an overdrive gear. (Or just happen to be driving down a really long steep hill)
Reading up about modifying the miata input shaft got me thinking though... I saw this pic on Mazdatrix and I was wondering if it was possible to use an RX7 input shaft on a miata gearset? That would simplify things a lot.
However, after searching about it, it seems that it has been tried with no success.
Originally Posted by RX7 Club
All right. I made some measurements and tried to assemble a hybrid box today using an RX-7 input shaft and a Miata gearset.
The initial problem is that the diameter of the input gear of the RX-7 shaft is about .100" larger than that of the Miata shaft. I did not measure the diameter of the gear on the counter shaft because I do not have a mic that large. I figured I'd try to put everything together, see what fit and how it all mated. I measured 3 RX-7 shafts and 2 Miata shafts and all the numbers were spot on among the lot.
The tooth count is different between the two input shafts and counter shafts but the pitch appears to be the same because once they are together they mesh very well and the assembly initially rotated very freely.
I assembled the whole front side of the box (1st-4th gears) and everything looked great. The problem occurred after reverse gear was in place and I began to add the OD gear. The OD gears would not go on. There is enough of a side load on the shafts from the diameter difference of the input gears that the clearance is ruined on the backside of the tranny.
Old 01-12-2014, 04:56 PM   #79
the longer first is better all around. short 1st is useless
Old 02-20-2014, 01:54 PM   #80
scarsofcarma
So I decided to give up on the fb project. I traded it for a Corrado VR6 that also has upgrades to its brakes and suspension. I was too impressed after driving it to say no.
But by no means am I giving up rotaries themselves. If I coulda kept both I would. I'll still be attending rotary meets and helping friends with their RX7's, so I'll be involved in their scene indefinately no worries.
Old 02-20-2014, 02:00 PM   #81
chibikougan
chibikougan's Avatar
Thumbs down
Old 02-20-2014, 02:58 PM   #82
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Working on more karma scars I see.
Old 02-20-2014, 04:30 PM   #83
well the corrado is a neat car. At least its not a G-Lader either!
Old 02-21-2015, 07:07 PM   #84
scarsofcarma
I'm back behind the wheel of a rotary again... albeit an unusual frankenstein build, but it will be fun!
The GSL-SE is actually sold to a good friend of mine now who lives in my neighborhood. So I still see it all the time and occassionally go for a spin in it.
Here's recent pics...
Old 02-22-2015, 02:12 AM   #85
Looks good! I like those wheels too.
