7Club Refugee
Rep Power: 15 ![]() |
torque Specs, more than you could ask
ENGINE
SHORT BLOCK Oil pan bolts 69-95 in-lbs Tension Bolts 23-29 ft-lbs Flywheel Nut MT 289-362 ft-lbs , AT Counter Weight nut 289-363 ft-lbs/ Drive plate bolts 32-45 ft-lbs Eccentric shaft pulley bolt 80-98 ft-lbs Oil Pump 61-87 in-lbs Oil Pump gear locknut( the one that sits on top of the gear with the washer with the tab bent) 23-34 ft-lbs Oil pressure control valve 29-36 ft-lbs Front cover bolts 12-17 ft-lbs Oil strainer 61-87 in-lbs Engine mount on oil pan 46-69 ft-lbs Left engine Mount 41-59 ft-lbs Oil regulator value 51-58 ft-lbs A/C/ and/or P/S bracket M10 Bolt 23-34 ft lbs/ M12 bolt 41-59 ft-lbs LONG BLOCK TURBO Oil Inlet pipe 14-19 ft-lbs Rats nest bolt 14-19 ft-lbs Dynamic chamber bracket 14-19 ft-lbs Water pump 13-20 ft-lbs Metering Oil Pump 69-95 in-lbs Exhaust Manifold 23-34 ft-lbs/ Exhaust man. Insulator 69-95 in-lbs Lower intake manifold 14-19 ft-lbs Housing/ Manifold Oil nozzle 12-17 ft-lbs Stock Turbo 33-40 ft-lbs/ Insulators 69-95 in-lbs Water pipe 17-26 ft-lbs Air control Valve 69-95 in-lbs Primary fuel rail 14-19 ft-lbs Upper intake manifold 14-19 ft-lbs Secondary fuel rail 14-19 ft-lbs Throttle body 14-19 ft-lbs Clutch and Pressure Plate 13-20 ft-lbs Alternator long bolt 27-38 ft-lbs/ Short bolt 14-19 ft-lbs/ Strap 13-20 ft-lbs Air pump bracket 14-19 ft-lbs Air Pump long bolt 12-17 ft-lbs/ Short bolt 17-22 ft-lbs Crank Angle Sensor 69-95 in-lbs Stock Oil Pressure Gauge 95-139 in- lbs Oil Filter pedestal bolts 69-95 in-lbs Spark Plug 113-156 in-lbs P/S oil pump 23-34 ft-lbs P/S pulley 29-36 ft-lbs Fan Nuts 69-104 in-lbs Intercooler bolts 69-95 in-lbs NON- TURBO Water Pump 13-20 ft-lbs Metering Oil Pump 69-95 in-lbs Housing/ Manifold Oil nozzle 12-17 ft-lbs Lower intake manifold 14-19 ft-lbs Fuel Rails 14-19 ft-lbs Vacuum piping mounting bolts 14-19 ft-lbs Exhaust Manifold 23-34 ft-lbs/ Exhaust man. Insulator 69-95 in-lbs Throttle and Dynamic Chamber 14-19 ft-lbs Metering Oil Tube 87-122 in-lbs Clutch and Pressure Plate 13-20 ft-lbs Alternator long bolt 27-38 ft-lbs/ Short bolt 14-19 ft-lbs/ Strap 13-20 ft-lbs Air pump bracket 14-19 ft-lbs Air Pump long bolt 12-17 ft-lbs/ Short bolt 17-22 ft-lbs Crank Angle Sensor 69-95 in-lbs Stock Oil Pressure Gauge 95-139 in- lbs Oil Filter pedestal bolts 69-95 in-lbs Spark Plug 113-156 in-lbs P/S oil pump 23-34 ft-lbs P/S pulley 29-36 ft-lbs Fan Nuts 69-104 in-lbs Intake tube to throttle body 14-19 ft-lbs OIL SYSTEM Bolts that hold to body 61-87 in-lbs Bolts to oil cooler 40-51 ft-lbs Drain plug 22-30 ft-lbs Front Oil cooler hose nut 32-40 ft-lbs Rear Oil cooler hose blot 40-58 ft-lbs Clamp that holds hose’s together 61-87 in-lbs Oil pan bolts 69-95 in-lbs CLUTCH COMPANTS Master to frame nuts 14-19 ft-lbs Master to hard line 9-16 ft-lbs Release Cylinder to MT bolts 12-17 ft-lbs Release Cylinder to soft line 16-20 ft-lbs Release Cylinder Air bleeder screw 52-78 in-lbs Clutch and Pressure Plate 13-20 ft-lbs Clutch Pedal adjustment locknut 8-12 ft-lbs Hard line to soft line wasn’t in the FSM so if somebody knows what the specs are add it up for others to know TRANSMISSIONS MANUAL Check/fill plugs 18-29 ft-lbs Drain Plugs A(MAIN one close to engine) 29-43 ft-lbs/ B( TURBO ONLY close to trans mount) 23-34 ft-lbs Rubber mount 12-17 ft-lbs Trans mount A(4 Outside bolt) 23-34 ft-lbs/ B(middle nut) 41- 59 ft-lbs Starter A(bolts)23-34 ft-lbs/ B(nut for wiring) 87-104 in-lbs Shift lever bolts 69-95 in-lbs Trans to Engine bolts 27-38 ft-lbs Cross member for convertible 27-40 ft-lbs Driveshaft 36-43 ft-lbs 60-69ft/lbs for the flex plate to rear counterweight for light flywheel vehicles and auto cars. AUTO Oil pan bolts/bracket 52-69 in-lbs Vacuum diaphragm bolts 69-95 in-lbs Rubber mount 12-17 ft-lbs Trans mount A(4 Outside bolt) 23-34 ft-lbs/ B(middle nut) 41- 59 ft-lbs Starter A(bolts)23-34 ft-lbs/ B(nut for wiring) 87-104 in-lbs Trans to Engine bolts 27-38 ft-lbs Cross member for convertible 27-40 ft-lbs Oil pipes bolts 17-26 ft-lbs Bolt/clamp that holds oil pipes together 69-95 in-lbs Fill/dip stick tube bolts 69-95 in-lbs Shift lever screws 13-26 in-lbs Selector lever nut 69-95 in-lbs Selector cable locknut 7-11 ft-lbs
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now." John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
The cross-eyed kid
Let me just finish posting my list since you left a few parts out with the copy and paste.
AUTO Oil pan bolts/bracket 52-69 in-lbs Vacuum diaphragm bolts 69-95 in-lbs Rubber mount 12-17 ft-lbs Trans mount A(4 Outside bolt) 23-34 ft-lbs/ B(middle nut) 41- 59 ft-lbs Starter A(bolts)23-34 ft-lbs/ B(nut for wiring) 87-104 in-lbs Trans to Engine bolts 27-38 ft-lbs Cross member for convertible 27-40 ft-lbs Oil pipes bolts 17-26 ft-lbs Bolt/clamp that holds oil pipes together 69-95 in-lbs Fill/dip stick tube bolts 69-95 in-lbs Shift lever screws 13-26 in-lbs Selector lever nut 69-95 in-lbs Selector cable locknut 7-11 ft-lbs Driveshaft 36-43 ft-lbs BRAKES Brake booster/ power brake unit to frame(4 nuts) 14-19 ft-lbs Master to brake booster nuts 7-12 ft-lbs Hard lines to Master 9-16 ft-lbs Pedal adjustment Locknuts A(In front of pedal) 10-13 ft-lbs/B(behind pedal on rod) 17-25 ft-lbs FRONT Caliper bracket bolts 58-72 ft-lbs Caliper to bracket bolts(bolt that helps rotate up on single pistons) 23-30 ft-lbs Soft lines to caliper 16-20 ft lbs(single piston)/ 9-16 ft-lbs(4 piston) Bleeder screw 52-78 in-lbs REAR Caliper to bracket bolts (bolt that helps rotate up) 12-17 ft-lbs Caliper bracket bolts 33-40 ft-lbs E-brake cable nuts 14-21 ft-lbs Soft line banjo bolt 16-22 ft-lbs Bleeder screw 52-78 in-lbs Parking brake lever bolts 14-19 ft-lb REAR END/SUSPENSION Axles to Differential 40-47 ft-lbs Axles to rear hub 174-231 ft-lbs Differential fill/drain plugs 29-40 ft-lbs Differential mounting nuts 54-69 ft-lbs Shocks Lower bolt 46-69 ft-lbs/ Upper(to body) nuts 17-22 ft-lbs Subframe nuts 72-87 ft-lbs Control link bolts(Trailing arm/Subframe) 27-40 ft-lbs Adjusting bolt and cam plate 46-70 ft-lbs Lateral link (Trailing arm nut) 22-33 ft-lbs/ (sub frame nut) 33-43 ft-lbs Sublink bolts 54-69 ft-lbs Control link(trailing arm/sway bar) 27-40 ft-lbs Sway bar mounts 27-40 ft-lbs Front diff mount nuts 65-77 ft-lbs FRONT SUSPENSION Lower control Arm (front bolt/nut) 46-69 ft-lbs/ Rear bolts 43-54 ft-lbs Control link (to arm/bolt) 27-37 ft-lbs/ (to sway bar/nut) 27-40 ft-lbs Sway Bar mounts 13-20 ft-lbs Shocks lower bolts 69-86 ft-lbs/ Upper(to body) nuts 22-27 ft-lbs STEERING SYSTEM Tie-rod end bolt 22-33 ft-lbs Tie-rod end Locknut (right after boot) 25-29 ft-lbs Steering Wheel nut 29-36 ft-lbs Intermediate Shaft bolts (Upper Bolt) 13-20 ft-lbs/(Lower bolt) 12-17 ft-lbs Steering Shaft bolts 12-17 ft-lbs P/S rack mounting bolts 22-33 ft-lbs OTHERS Sunroof nuts 5-6.5 ft-lbs Convertible top motor bolts 23-34 ft-lbs Convertible top fabric Hook/Bolts 22-31 in-lbs/ Nuts 37-55 in-lbs Seat bolts 28-38 ft-lbs Convertible roof panel locks 37-55 in-lbs/ hinges 5.1-7.2 ft-lbs Last edited by RETed; 01-16-2015 at 01:42 PM. Reason: Unnecessary language |
#3 | |
Rep Power: 17 ![]() |
Hey guys here are all the torque specs for every part every year every car...Plus the whole FSM... We don't need HC style posts of random info. We have Factory Service Manuals...
![]() Or go to the source. I like the idea but the info is already put together so well... http://foxed.ca/index.php?page=rx7manual
