Closed Thread
Old 01-11-2014, 07:38 PM   #181
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Originally Posted by JL1RX7 View Post
Oh and the VIN plate on the firewall. Don't forget that!
Well, hopefully the mods won't show from the outside. It should look relatively stock at first glance. Unless you lift the hood (or bonnet for Bri-Bri).
GySgtFrank is offline
Old 01-15-2014, 08:41 PM   #182
GySgtFrank
GySgtFrank's Avatar
frame & hoops by GySgtFrank, on Flickr
I got the other side in and welded up today with a bit of a struggle. Deleted the brake vacuum booster and incorporated the brake master cylinder mounting plate into the plate for the hoop. Far more compact mounting. I'll have to see how well the brakes work without it. This should make the frame rails pretty strong and get rid of any flex.
Old 01-15-2014, 09:08 PM   #183
hades
Good luck man. That's a lot of work.
This is going to tear
hades is offline
Old 01-15-2014, 09:41 PM   #184
GySgtFrank
GySgtFrank's Avatar
Thanks Jeff. It keeps me out of trouble, sort of.
Old 01-15-2014, 09:58 PM   #185
chibikougan
chibikougan's Avatar
Nice
chibikougan is offline
Old 01-16-2014, 06:58 AM   #186
Soooooo.....you gonna make DGRR this year?
Yikes!
djmtsu is offline
Old 01-16-2014, 08:13 AM   #187
GySgtFrank
GySgtFrank's Avatar
Yikes!
I think so. Despite how it looks, I'm actually getting pretty close to buttoning it up to reinstall everything.
Old 01-19-2014, 05:29 PM   #188
GySgtFrank
GySgtFrank's Avatar
Pics or I don't believe you
lower frame rail by GySgtFrank, on Flickr
The lower rail is what the cradle will bolt to. Should have the rail on the other side done tonight or tomorrow.
Old 01-19-2014, 07:39 PM   #189
chibikougan
Nice!
Old 01-19-2014, 07:46 PM   #190
GySgtFrank
GySgtFrank's Avatar
Thanks Cheebs. At least it has a nice flat surface to bolt the lower cradle to when I get that finished up.
Old 01-19-2014, 07:50 PM   #191
chibikougan
That is a little handy...
Old 01-30-2014, 04:45 PM   #192
GySgtFrank
GySgtFrank's Avatar
upper mounts, Part III
So... I screwed up again. The upper mounts are off by 1/2" on the driver's side and the passenger side was off by 3/4 - 1". I could have sworn I had them right that time, but it was not to be. I did have enough adjustment to get them where they needed to be, but they were at the very end of the adjustment and then some. Not comfortable running it that way so here we go again. Trying to get an accurate measurement with very few squared up surfaces is a pain in the ass. So I need to cut them out one more time. Getting a little smarter this time and building a stand alone box for the mounts. That way I can tack it in place and move the whole thing when I get the alignment equipment back on it.
upper A arm mount part 3 by GySgtFrank, on Flickr
Also did a little modification while the mounts are out. I didn't care much for the camber adjustment as it tended to move too far while adjusting and it was a pain to bring it back. So I drilled out the front holes and welded 1/2 - 20 nuts on them then put a cap and nut on the other side as well. That way I can run a fine thread 1/2" bolt in each side to push the mounting block back and forth for fine adjustment. It will also help lock it in place more securely.
Cross my fingers and hope I get it right this time.
Old 01-30-2014, 04:47 PM   #193
JL1RX7
Measure once weld 4 times?
JL1RX7 is offline
Old 01-30-2014, 04:50 PM   #194
GySgtFrank
GySgtFrank's Avatar
or keep cutting and welding until you get it right.
Old 01-30-2014, 06:11 PM   #195
hades
Because dumb great bend marine
hades is offline
Closed Thread
