		#76 | |
				Rep Power: 17 ![]()  |
			Cold Weber?
		#77 |
				Rep Power: 21 ![]()  |
			no its making the tach jumpy
	For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook  |
		#78 |
				Rep Power: 18 ![]()  |
			maybe the pick-up is failing in the dizzy they move a little and the wire may be broken inside.
	____________________________________________ 1976 Cosmo needing lots of work 1993 Rx-7 410 RWHP single turbo toy 1985 Rx-7 toy/project car 411HP stoplight terror 2001 Dodge ram 4wd.parts hauler 2016 Ram 2500 cause its a hemi 2006 VW TDI commuter __________________________________________ I guarantee there's a pregnant redneck teenager somewhere in a shitty trailer park that thinks "Ebola would be a lovely name for their child"...
		#79 |
			 Waffles - hmmm good
				Rep Power: 0 ![]()  |
			Take the tach signal from the msd if you can and see if it works fine.
			Is it just the tach or do you feel it actually missing?
	1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00  |
		#80 |
			Im going to try the tach off the MSD as well. I yea, I actually feel it missing. Stumbling quite badly when it occurs.
		#81 |
			i have some spare dizzys so ill be changing it out too if the problems persist past the coil and ignitor.
		#82 |
		#83 |
			dizzy failed mechanically. was making loud clunking noises, replaced and she runs good minus the idle circuit. I need to get that dialed in.
		#84 | |
			Sweet.
		#85 |
		#86 |
		#87 |
				Rep Power: 13 ![]()  |
			Whoa... what is that about? I'm very curious
		#88 |
			breaks up and/or deflects the pressure waves (supposedly) and prevents them from bouncing back against the flat top metal lid.
		#89 |
			Found some larger 65 pump jets. Seems to have help some. Car still has off idle / light throttle leaning issues causing dead spots.
			Racing beat muffler has replace the flowmaster so know it sounds better and quieter. A much needed thing. The motor that controls the vent mode for the heat went out so i just removed it so i can manually change the settings. I might fix it proper some day. I just was tired of no defroster. Also powersteering is back in the car with mazdatrix heim bumpsteer bits.
		#90 |
