				Rep Power: 13 ![]()  |
				EFR Internal Waste-Gate Discussion
			I thought a few of you guys might be interested in some of the latest on the BorgWarner EFR turbochargers, especially the viability of the internal waste-gate turbine housings. The 7670 and 8374 are pretty well suited for most 2 rotor applications. The 7670 is particularly nice for a sub 400rwhp car looking for ultra fast response, and the 8374 for the 500~ish rwhp cars. Anyhow here is part 1 of the 7 EFR turbo systems we are building( some we are also tuning in house too).
	http://blog.turbosource.com/2013/11/...rotary-engine/  |
			 Still Building my FD
				Rep Power: 17 ![]()  |
			What kind of response are we looking at with the 7670?  Equal or better than sequential bnr stage 3s?
	Uh.... hi.  |
				Rep Power: 19 ![]()  |
			All this does is make turbo exhaust manifold design and building easier...
	If these turbos take off for 13B applications, I see a whole lot of simpler turbo exhaust manifolds being offered in the near future; it's going to be pretty easy to design and build something with just two runners versus every piston engine turbo exhaust manifold. -Ted  |
			One owner has reported 1 bar by 2200rpms using the 7670 on his 2 rotor.
	Turblown Engineering - Rotary Turbo Kits, Rotary Adaptronic ECUs and Rotary Performance Parts. TurboSource - Performance TurboChargers, Inconel Heat-Shields, and Adaptronic Distribution  |
				Rep Power: 20 ![]()  |
			^Pretty sure you're referring to me lol.
			I have the EFR 7670 with two Tial 38mm external gates, one on each runner, with a short runner manifold. I had the runners built as short as possible out of 321 stainless. This turbo has RIDICULOUS spool. Mine starts around 2k rpm, and I'd say reaching full boost by about 3300-3500. The problem is I haven't been on an actual dyno yet to get any info, and I've had this turbo on since early last year. It also sounds like a jet engine, but that's just an added bonus lol. Anyway, the only thing I've done is virtual dyno, and I'm not sure how much stock I put in that. Supposedly it's within 5% accurate, but having not been on an actual dyno yet, I couldn't tell you for sure. And since all dynos read differently, I'm not sure it would make much difference anyway. All I know is if you want response similar to stock twins but more top end, the 7670 is perfect. I can't speak to the 8374, but I was thinking of possibly stepping up to that one next time. I wouldn't say for sure you can't break 400whp with the 7670. I'm at 6000 ft altitude and I'm already pretty close to 400 (according to the virtual dyno anyway), and we lose quite a bit of HP up here. Although the spool is so fast and strong that I have to turn down the duty cycle on the boost controller in the first couple gears, and a little in third gear, or I'll spin all the way through. That's why I was thinking about going with the 8374 next time. I imagine it spools just not quite as fast but probably pretty close, but will still get you more whp. Here are some pics of the when I was installing everything. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
			My concern with internal gated housings is if there will be enough room between the engine and firewall/strut tower.  I'm already pretty close with my external gated housing, but part of that can be manipulated with the manifold of course.
			More pics... ![]() ![]() ![]() ![]() ![]() ![]() This is something that really bugs me. My manifold came out with a 5 degree forward slant, although this pic makes it look worse than it is. ![]() Here's how it turned out before I powdercoated everything black. ![]() A couple problems I ran into were oil drain and coolant feed and return. For the coolant feed and return I had to go with a banjo fitting on both sides, and one side needed to be angled. ![]() This is what the turbo drain needed, to be modified to angle out as soon as possible to avoid the line contacting the turbine housing at the flange. ![]() Both of those problems could probably also been managed a little better with a different manifold too. Last edited by speedjunkie; 11-24-2013 at 11:38 AM.  |
				Rep Power: 18 ![]()  |
			I am very interested in this as well.  When I make the switch to single I am planning on going this route.  It solves the issue of having to reroute the waste gates which for me is a must.
	Speedjunkie, do you have any shots showing how close the exhaust housing is to the LIM? Maybe one looking straight down on it?  |
		#9 |
			I don't think so but I'll take a pic for you.
		#10 |
				Rep Power: 15 ![]()  |
			Turblown, who wrote that article?
		#11 |
			Sounds like he did.
	-Ted  |
		#12 | |
				Rep Power: 10 ![]()  |
 In terms of numbers, at 2500rpms I could see 17psi with my old BNR's, with the Stg V I'll see > 10 psi, however, at less boost I'll make more power. Most of it has to do with EMAP and how efficient everything is. At 10psi on the BNR's I would see about 15psi of EMAP, by 14.5 psi of boost I was seeing 29psi of EMAP and I was making ~378RWHP. By comparison with the GT35R STG V, at 14 psi I see ~ 15 psi of EMAP, and I was making 405 RWHP with more in there given more tuning.... I spent 45 minutes tuning that car the morning we left for DGRR. So, here's the thing, think of an engine as an airpump, boost ( MAP) goes in, EMAP comes out. MAP/EMAP = efficiency, which setup is more efficient?
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
		#13 |
			And Eric's car is fucking sexy, love that sled. I though you were running the internally gated BW though?
		#14 | |
 This really making me rethink my setup... Sadly. I love the idea of keeping my 95 FD with sequential twins for nostalgia's sake. But this sounds like it would suit my driving better... Who knows. I'll probably just stick with what I have for now, finish the build with twins. And if I don't like it, then switch over. The only additional expense I'll have to deal with that I haven't already bought and paid for is the solenoid set for controlling the twins.
	Uh.... hi.  |
		#15 |
				Rep Power: 0 ![]()  |
			has anyone actually put one of these on a rotary yet?
			i would absolutely love to ditch my water cooled dual wastegate setup and go with an internal gate, but only if it can waste enough exhaust to allow me to run low boost (10-12psi). i have turblown's dual wastegate manifold on my car with both wastegates recirculated, with water lines running to/between/from the wastegates back to the engine, and 7 vband connections that don't seal perfectly (yes, 7 vbands) and two air lines running to each wastegate. i dread even thinking about removing my downpipe. i would love to switch to this EFR turbo and run 1 air line, 1 vband, and add 2 water lines for the turbo... Last edited by jacobcartmill; 11-25-2013 at 05:52 PM.  |
