Old 11-17-2013, 10:50 PM   #16
myfree7
myfree7 is on a distinguished road
myfree7 is offline   Reply With Quote
Old 11-17-2013, 10:51 PM   #17
myfree7
Racing Beat silicone hoses
Old 11-17-2013, 10:51 PM   #18
myfree7
started messing around with some monster coil wraps.
brand new water pump
masking it off to be painted
painted
had to grind down the spacer so that it would fit properly
Old 11-17-2013, 10:52 PM   #19
myfree7
finally got the rest of the crap out of the engine bay so i can start sanding for paint.
Old 11-17-2013, 10:54 PM   #20
myfree7
almost done painting the front half of the car!
when it is done i'll be waiting for new parts to arrive and be installed..........
Old 11-17-2013, 10:54 PM   #21
myfree7
finally able to post pics of some of things I've done lately.....
new clutch and brake master
Old 11-17-2013, 10:55 PM   #22
myfree7
still need to replace the seals, but it's all cleaned and painted. and I got the short shifter to work smoothly as well and installed the new ball
Old 11-17-2013, 10:55 PM   #23
myfree7
:twisted:
stainless clutch line, throw out bearing, shift fork boot, competition trans mount and seal kit...
Old 11-17-2013, 10:56 PM   #24
myfree7
trans mounted to motor and all wired up ready for install
Old 11-17-2013, 10:57 PM   #25
myfree7
this little bastard.......... this is where the tee fitting is for the coolant under the oil mount. i couldn't yank it out so i cut it off now i'm trying to get it out of the motor so i can plug the whole up and install the motor. which IS happening tomorrow lol. i also have a new pitman arm and a full energy suspension kit with an aftermarket alt. tensioner to install as well
Old 11-17-2013, 10:57 PM   #26
myfree7
couldn't get the piece out so i taped it in and drilled out the hole and plugged it with a rubber expansion plug.
Old 11-17-2013, 10:58 PM   #27
myfree7
the way i mounted the clamp for the wires i had to get a longer bolt and tap out the hole for the starter.
almost ready!
Old 11-17-2013, 10:59 PM   #28
myfree7
got an aftermarket alt. tensionor from Bonzie racing, but had to modify it to fit with the gilmer belt drive
after cutting it down and drilling a new hole the factory mounting spot would not work. it would hit the dizzy so i mounted it a little farther in and it works great.
still a long way to go, but it's in!
Old 11-17-2013, 10:59 PM   #29
myfree7
header and racing beat hoses installed
Old 11-17-2013, 11:00 PM   #30
myfree7
Modified the oil cooler today to make it fit. Then started hacking up my $150 racing beat oil lines to make them fit as well. Also ordered a 3 row radiator today.
