| 20B/3 Rotor Conversion.. All things to do with 20B/3 rotor... Post pics, video, tech, etc.. |
Xcessive Manufacturing 20B Lower Intake Manifold (LIM)
Just thought I'd share what Xcessive has been working on as of late.
Full length version: Quote from Xcessive's website: Xcessive's all new cast lower intake manifold for the 20B is based on the same concept as our original 13B-REW manifold, better runner flow balance, more volume and more fuel. We've made these manifolds with 6 injector bosses machined to fit Bosch type top feed injectors with 14mm o-rings without any adapters. We've placed all the injectors on the inside of the manifold to keep them away from heat leaving more room on the outside for turbo motors as well as a cleaner install. The new lower manifold fits stock upper castings and comes in both a full height (stock) and short versions. This is the FULL HEIGHT (stock) version. They are also available with and without fuel rails. This manifold kit includes the fuel rail assembly. The fuel rail has 3/8" NPT ports on both ends with a -8 (1/2", 13mm) through hole and comes with the apropriate stand off's for full height top feed injectors. No more welding bosses onto a stock manifold and chopping and welding the upper flange, we've done it all for you in a single brand new piece that'll also out flow a stock manifold. This Kit Includes New cast manifold - Full height (stock) version 6 port fuel rail for top feed injectors Rail stand off brackets and bolting hardware Front mounting bolt (New boss height) http://www.xcessivemanufacturing.com...step=4&pid=301 |
Front of the long version Xcessive LIM
Here you go!
Short version for non JC cosmo chassis swaps!!!
There is also a short version for easier swapping into non JC cosmo chassis'
Short version: Quote from Xcessive's website: Xcessive's all new cast lower intake manifold for the 20B is based on the same concept as our original 13B-REW manifold, better runner flow balance, more volume and more fuel. We've made these manifolds with 6 injector bosses machined to fit Bosch type top feed injectors with 14mm o-rings without any adapters. We've placed all the injectors on the inside of the manifold to keep them away from heat leaving more room on the outside for turbo motors as well as a cleaner install. The new lower manifold fits stock upper castings and comes in both a full height (stock) and short versions. This is the short version that is 1 1/2" (38mm) shorter than stock. They are also available with and without fuel rails. This manifold kit includes the fuel rail assembly. The fuel rail has 3/8" NPT ports on both ends with a -8 (1/2", 13mm) through hole and comes with the apropriate stand off's for full height top feed injectors. No more welding bosses onto a stock manifold and chopping and welding the upper flange, we've done it all for you in a single brand new piece that'll also out flow a stock manifold. This Kit Includes New cast manifold - Shortened version 6 port fuel rail for top feed injectors Rail stand off brackets and bolting hardware Front mounting bolt (New boss height) http://www.xcessivemanufacturing.com...step=4&pid=300 |
Short version front
Bam!!!
Hooked For Life!
amazing!
s5 Infini RHD -RIP S6 Efini RHD RE, Custom Burnout -Build in progress |
Rotary parts manufacture
Very nice manifold!! Any semi-pport manifolds in the plan?
Nope.
no plans for semi-peripheral port manifolds at this time. |
The finish on the LIM to block gasket needs some work, has Rich bought a new fly cutter yet?
