Closed Thread
Old 09-13-2013, 03:45 PM   #151
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Since we got rained out today, I finished up the passenger side wheel arch and test fitted the wheel and tire. I had to do a little more minor trimming to ensure that the wheel can turn through it's entire radius while under full compression and extension.
Wheel at full compression:
full jounce by GySgtFrank, on Flickr
You can actually see how I mounted my fancy dancey cold air intake. The stock box is modified and through bolted to the bottom of the structure in front of the tire. I remove the front nose panel to access it. It clears, so it looks like I don't have to redo that part at least.
GySgtFrank is offline
Old 09-13-2013, 07:06 PM   #152
Mitchocalypse
Mitchocalypse's Avatar
Mitchocalypse is on a distinguished road
that car is in insane condition given its age.
nice.
Mitchocalypse is offline
Old 09-13-2013, 07:25 PM   #153
GySgtFrank
GySgtFrank's Avatar
nice.
Thanks Mitch. It is just a base model that came with the 12A and 4 speed. The only option it had was A/C. The engine was blown and it was probably destined for the crusher, as so many other 1stgens are, if I hadn't bought it. It has some hail dents, but very little rust. The only rust through it had was where the front of the lower rear axle control arms mount to the body, the normal spot. This is no longer a concern.
Old 09-13-2013, 08:36 PM   #154
chibikougan
chibikougan's Avatar
Bitchin stang bro!
Haha I can't even keep air in my tires
chibikougan is offline
Old 09-13-2013, 08:41 PM   #155
GySgtFrank
GySgtFrank's Avatar
Bitchin stang bro!
Bite me! Biotch.
Well, mine haven't exactly been getting a lot of wear and tear on them lately either. It could be worse, we could own FDs where one set of tires is all you'll ever need.
Old 09-14-2013, 01:23 AM   #156
the spyder
the spyder is on a distinguished road
Awesome build thread- how are you keeping the front end trammed in during the build?
the spyder is offline
Old 09-14-2013, 05:51 AM   #157
Pete_89T2
Pete_89T2's Avatar
LOL, yeah you get a break on tires but you'll need a damned good set of jack stands that are rated for 24/7 usage!
Pete_89T2 is offline
Old 09-15-2013, 12:07 AM   #158
GySgtFrank
GySgtFrank's Avatar
LOTS and LOTS of measuring and fitting. Which is why it is taking so long for just a little bit of work. It has been 2 steps forward and 1 step back during this part of the build. Some days more back than forward.
I thought those came as standard equipment on all FDs?
Old 09-15-2013, 02:37 PM   #159
scarsofcarma
scarsofcarma's Avatar
scarsofcarma is on a distinguished road
Nice progress, keep it going I want to see what this can do when its done.
scarsofcarma is offline
Old 09-15-2013, 10:21 PM   #160
GySgtFrank
GySgtFrank's Avatar
Thank you for the encouraging words. I'm hoping to be pushing into the one G plus skidpad range for grip (on a reasonable street tire) without it being glaringly obvious what I've done. The RX-7 was pretty good at close to .8 G when they came out. I'm hoping to equal or exceed most of the new high end cars for handling. That and the ability to haul it down from speed quickly.
I have never seen anyone else doing anything quite like this to a first gen. So I'm in uncharted territory as far as I know. My experience with other cars is that the unequal length A arm suspension is markedly superior to the MacPherson Strut suspension in most respects. It also allows me to tuck a really wide tire under there, and contact patch is King (for the most part) when talking handling.
I have read up on what a lot of the folks running first gens in racing have done and what they have found effective. The good part is that they have been used in racing, and winning more often than not, for so long that there is quite a bit of experience out there. Unfortunately, while their insights have been valuable, they are limited by class rules which would preclude anything remotely like what I am doing up front. The rear suspension is a blatant copy of what others have found to work on their track cars. I have merely tried to make it more livable on a street driven car.
I'm kind of itching at the bit myself to find out whether I have been inspired or that I'm a flippin' idiot. Bets could go either way at this point.
Old 09-16-2013, 01:11 AM   #161
scarsofcarma
Yeah 1+ G is a benchmark I'm aiming for as well. I know I've experienced that before on Laguna Seca riding in a Porsche 911 on slicks. Just amazing how well that car gripped... especially while braking. It was like throwing an anchor out the back.
Racetrack tarmac is very smooth and sticky though. Not at all like the crappy street surfaces we usually drive on. 1+ G on street tires is possible sure, but it largely depends on where you're driving.
For now yes, but I will be modifying my FB to this extreme as well just wait and see lol
Yes there is no doubt the double-wishbones provide a better contact patch for the tire... I had a few MKIII Supra's and I drove an FD a few times which also have that setup.
However imo there is sometimes more to be said for the MacPherson in terms of feedback. It's like a tuning fork for the tire it really picks up all the minute sensations from the road. I found the driving experience of the FD RX7 and the MKIII Supra a bit more numb in that regard.
Don't get me wrong, I'm not saying the cars were any slower in my hands because they weren't MacPherson. It's just that I was slightly less confident about what the limit of the tire was, and were not even talking about a big difference. Maybe 10-20% less feedback felt like to me.
On a track that difference wouldn't seem so big, but on a mountain road with a generally lousy road surface, with no runoff areas, feedback from your tires is everything.
Yeah I am also very interested to learn about what has been tried and done on high performance racing FB's that were not so limited by class rules. Millen's RX7's, and those group B FB rally cars for instance were pretty extreme.
Old 09-16-2013, 09:27 AM   #162
GySgtFrank
GySgtFrank's Avatar
It's what I'm shooting for, doesn't mean I'll get it. I'll give it my best shot anyway. I don't know about the feedback issue, you may be right on that. I wonder how much of that is due to the weight of the car though, the FD and especially the Supra aren't exactly lightweights. That's the biggest reason I chose the 1st gen over the FC and FD chassis. (I don't actually hate the other generations, just returning the harassment others have dished out ) The first generation RX-7 was ridiculously light for a street car. I thought about going with a swapped Miata for this reason, but the RX-7 chassis should be stiffer than the convertible chassis and there is very little difference in their weights.
I know the SLA suspension will keep the tire in better contact with the road, providing more ultimate grip. So between the grip factor, and the need for tucking in large rubber, I decided to go this direction. A widebody with an increase in track width would have been more effective, but I want to keep it approximately stock in appearance. I would imagine that a widebody would get a lot of scrutiny from any law enforcement in the area. Between the large rubber and my upgraded brakes I should get pretty decent braking performance as well.
As you said there is a big difference in quality of the road surface between a racetrack and normal street driving though. Race cars can get away with a lot of things that won't work on the street. I'm trying to come as close as I can to that level of performance without losing the ability to drive it regularly.
Old 09-16-2013, 02:46 PM   #163
scarsofcarma
Yeah a Supra is a heavy beast but weight is not always bad. A Supra is not a flickable or tossable car but it turns better than you might expect. There are lots of heavy cars that can manage 1+ G. More weight on a tire (to a point) creates a greater coefficient of friction and helps grip. More weight allows for more static grip in the tire, as well as more weight available for weight-transfer in grip driving. But of course, more weight works the tire harder so it wears and possibly overheats faster.
There are many great cars in the world that are heavy but through clever engineering actually make that extra overall curb weight an asset like the GTR.
In the general sense of performance, the ratio of power to weight is more important than the actual power or weight numbers themselves. In the truest sense of performance though, power is king as long as you can find a way to put all that power to the ground. That's what makes cars like the GTR and 911 so impressive.
My bridgeported RX3-SP, fully caged with a Ford 8.8" rear end in it was in the 2300 lb range when I corner weighed it. But so what? That car had no traction. When I swapped its engine in my FB (just a street car with a full interior) I was actually able to put the bridgeport power to use. The FB was way faster, but on paper it should have been slower.
That's exactly my goal as well. I drive sports cars not just for fun, but because I know they can out handle and out brake those other cars with incompetent drivers that cause accidents all the time in urban areas. Or help me dodge the grossly overpopulated deer population in rural mountain areas.
Old 09-16-2013, 03:53 PM   #164
GySgtFrank
GySgtFrank's Avatar
Funny you should mention deer as a very close encounter is what started me down this path.
A lot of the RX-3s problem is that the stock suspension on those suck. They were designed as an economy commuter car and handling wasn't really in the equation except as an afterthought. The FB didn't weigh all that much more and even the first gens suspension was a vast improvement over the earlier cars. My SA weighed in at 2340 with everything in it and a full tank of fuel before I started modifying it. Hopefully I don't add too much weight to it, but I'm sure I'll add some.
Old 09-28-2013, 12:24 AM   #165
Anoesis
Anoesis's Avatar
Anoesis is on a distinguished road
Anoesis is offline
Closed Thread
