Old 09-07-2013, 12:23 PM   #1
My5ABaby
My5ABaby's Avatar
How bad is this flywheel?
I'm swapping a TII tranny into my car and have a new ACT 6 puck clutch and Heavy Duty pressure plate. I was going to use the stock flywheel I have but it has some cracks in it and I'm not sure how normal/usable this are. The biggest one is about 3/4" and then there's probably about 10 smaller cracks.
I will be taking the car to the track so the drivetrain will probably get some abuse and see sustained higher rpms.
Community Service Manual
RotorWiki
Old 09-07-2013, 01:07 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
IMO, if you plan to use a flywheel at high rpm, any cracking or flaws mean that it should be tossed. Having a flywheel come apart and take off your legs is not something that I would care to chance. Some sort of scatter shield would be a good idea as well since you said it will see sustained high rpm use.
Old 09-07-2013, 01:18 PM   #3
My5ABaby
My5ABaby's Avatar
Thanks for the reply. I currently have my redline set to 7200 so it's a normal redline, I just meant it will be near that a lot. Nothing extravagant like a crazy PP at 13k rpms.
RotorWiki
Old 09-08-2013, 11:56 AM   #4
My5ABaby
My5ABaby's Avatar
Second question, does this look like it can be resurfaced?
RotorWiki
Old 09-08-2013, 08:55 PM   #5
Garfinkles Motor Works
I would not resurface because if you undercut the cracks and it all looks good the heat that has been produced will keep the cracks coming back .Get an after market steel flywheel that is lighter than stock .It will need to be bolted to an automatic tranny counter weight from the same year as the motor so the balance will be correct .This will rev up faster and save the transmission as well .If a flywheel has hot spots I will not have them undercut ,a new part is in order .Cracks are worse .
Old 09-13-2013, 04:55 PM   #6
My5ABaby
My5ABaby's Avatar
Managed to find a local TII flywheel that didn't appear to have any cracks in it (thanks Charles!).
Here's the before and after of having it resurfaced by Tennessee Clutch and Supply. Worth every penny. The couple brown streaks/marks on the face are just some run off from the cleaning/blasting process and wiped off.
RotorWiki
