Closed Thread
Old 07-31-2013, 09:29 AM   #1
Rotary Engine / Parts Identification Guide
** pics will appear starting tomorrow **
I am building this guide as a one-stop shop for identifying rotary parts. It is broken down by category (i.e. housings, rotors, front covers, etc) then again by model. There will be an "other" sub-section for non-Mazda wankel information as well.
The order of infomation might also get jossled around as time goes on to make a logically progression.
If anyone can provide missing information that would be excellent! Credit will be given. I just ask that for pictures the original be sent to me and be similiar in format (if able) to the pictures used here.
Thanks to RETed for information!
Contents
1. Rotors
2. Front Plates 1 2 3
3. Intermediate Plates
4. End Plates
5. Housings
6. Front Covers
7. Eccentric Shafts
8. Counterweights
9. Flywheels
10. Seals (Apex, Side)
11. Oil Pans
12. Oil Pumps
13. Complete Engines
Whizbang is offline
Old 07-31-2013, 09:29 AM   #2
Rotors
10A (1967 - 1971)
Details
  • Found in the early Cosmo, R100, some RX-3
  • 9.2:1 or 9.4:1 compression ratio {conflicting reports}
12A (1971 - 1973)
Details
  • Found in twin-dizzy cars
  • Cast combustion chamber
  • 9.2:1 compressionr ratio
12B (1974 - 1978)
Details
  • Found in (74-78) RX-2 and (74-78) RX-3, with single dizzy.
13B "AP" (1974 - 1980)
Details
  • Found in the Rotary Pickup, RX-3 SP, RX-4 and Cosmo (RX-5 outside U.S.)
  • 9.2:1 compression ratio
12A (1978-1982)
Details
  • 9.4:1 compression ratio
12A (1983 - 1985)
Details
12A Turbo (1982 - 1989)
Details
  • 8.5:1 compression ratio
13B GSL-SE (1984-1985)
Details
13B 6PI - Series 4 (1986-1988)
Details
  • Found in FC3S non-turbo models
  • 2mm Apex seal
13B Turbo - Series 4 (1986 - 1988)
Details
  • Found in FC3S turbo models
  • 2mm Apex seal
13B 6PI - Series 5 (1989 - 1991)
Details
  • Machined combustion chamber
  • 9.7:1 compression Ratio
  • 2mm Apex seal
13B Turbo - Series 5 (1989 - 1991)
Details
  • Found in FC3S Turbo Models
  • 9.0:1 compression Ratio
  • 2mm Apex seal
13B-RE (1990 - 1995)
Details
  • 9.0:1 compression ratio
  • 2mm Apex seal
20B-REW (1990 - 1995)
Details
  • 2mm Apex seal
13B-REW (1993 - 2002)
Details
  • Found in all FD3S models
  • 2mm Apex seal
13B - MSP (2004 - 2012)
Details
  • Found in all RX-8 models
  • 10.0:1 compression Ratio
  • 1mm Apex seal
Whizbang is offline
Old 07-31-2013, 09:31 AM   #3
Rotors (cont.)
Whizbang is offline
Old 07-31-2013, 09:31 AM   #4
Rotors (cont.)
Non-Mazda Rotors
Snowmobile Engine (evanrude?)
Details
Lawnmower
Details
  • Really damn small
  • Side seals only on ONE side of the rotor. This side is the "bottom" as the rotor lays flat.
Whizbang is offline
Old 07-31-2013, 09:32 AM   #5
Front Plates
Whizbang is offline
Old 07-31-2013, 09:33 AM   #6
Front Plates (cont.)
Whizbang is offline
Old 07-31-2013, 09:34 AM   #7
Whizbang is offline
Old 07-31-2013, 09:34 AM   #8
Intermediate Plates
Whizbang is offline
Old 07-31-2013, 09:35 AM   #9
Intermediate Plates (cont.)
Whizbang is offline
Old 07-31-2013, 09:36 AM   #10
Whizbang is offline
Old 07-31-2013, 09:38 AM   #11
End Plates
Whizbang is offline
Old 07-31-2013, 09:38 AM   #12
End Plates (cont.)
Whizbang is offline
Old 07-31-2013, 09:40 AM   #13
End Plates (cont.)
Whizbang is offline
Old 07-31-2013, 09:41 AM   #14
Housings
Early 12A housings
There are actually differences between the front and rear housings.
The rear has "TCP" case into the top.
13B-PP Mazda Factory Racing Housings
Details
  • Available through Mazda Motorsport
  • "Mazda Motor Company Hiroshima Japan License NSU-Wankel" sticker on spark side / top
  • "13B Mazda" cast on edge
  • Unique, somewhat rough casting.
  • Dual Oil Injector ports
Whizbang is offline
Old 07-31-2013, 09:43 AM   #15
Housings (cont.)
Details
  • "Mazda Motor Company Hiroshima Japan License NSU-Wankel" cast on top
  • "Diffuser" in exhaust sleeve
  • Single Oil Injector port
Whizbang is offline
Closed Thread
