Old 03-30-2013, 07:55 PM   #241
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Kewl.... @ 3bar it should flow about 67gph and about 53gph @ 72 psi
Ok, so if I break the seconds down into rough fractions (30 sec = .5, 45 sec = .75) then I math (minute.fraction/5)*60 I com up with the following:
42.5/60= .7083 (rounded to .71). So the time for 43psi would be 5.71. Therefore:
(5.71/5=1.142)x60= 68.52GPH
31.5/60= .525 (rounded to .53). So the time for 70psi would be 6.53.
Therefore:
(6.53/5=1.306)x60= 78.36GPH
But.... I know that can't be right because if it were flowing a higher GPH @ higher psi than it would take less time. Can't math =(
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-30-2013, 11:06 PM   #242
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
So I spent about an hour manually searching through the Lounge here to find a thread Brian made forever and a day ago about GPH calculations. Why did it take me an hour to find a specific thread made by Brian???? BECAUSE THE FCUKING SEARCH FUNCTION FAILS!!! lol
Anyway, posting this link up because pertinent.
http://rotarycarclub.com/rotary_foru...ad.php?t=11768
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-30-2013, 11:25 PM   #243
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
So, from the thread above I found this:
Originally Posted by Bryan@BNR View Post
5 gallons pumped in 3 minutes and 53 seconds= 5Gal in 233 seconds
5 Gal=18.95 Liters
18.95 Liters pumped in 233 seconds
.081 Liters per second
.081 LPS times 60 seconds is 4.88 Liters Per min
4.88 LPM times 60 minutes is 292.79 Liters per hour.
292.79 LPH.
My guess a bosch O44.
As per Bryans post I found that:
5:42.5 ----- 342 seconds (43psi fuel pressure)
.055 LPS = 3.32 LPM = 199.47 LPH :: 52.77 GPH
6:31.5 ----- 391 seconds (70 fuel pressure)
.048 LS = 2.91 LPM = 174.47 LPH :: 46.15 GPH
I'm thinking I've either got a voltage problem, some sort of a restriction in the fuel lines themselves, my fuel filters are clogged (the in-tank sock is stupid old, and may actually have it too low in the tank), or the pump itself sucks...
Lets just say that I'm less than happy... Gunna start with getting a replacement fuel filter (it's possible that bits of my old 044 are clogging it) and double checking where my pump is physically located in the tank. Unfortunately I can't monitor the voltage at the pump while testing this at home =(
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-31-2013, 07:51 AM   #244
JL1RX7
You need a good meter?
Old 03-31-2013, 09:23 AM   #245
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Yes, and a good man to work it
Do you think you'd be free to come help re-run the tests?
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 04-01-2013, 03:34 PM   #246
JL1RX7
You just know what to say! But let me know what afternoon you want me to come over.
Old 04-01-2013, 04:14 PM   #247
mazpower
Rawr Bearclaw
mazpower's Avatar
Good thing you tested it!
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 04-01-2013, 04:17 PM   #248
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
if you check the sock also check the filter inside the pump. it is a small screen filter and if it gets even a small amount of junk inside the inlet the volume will take a dump quite quickly.
E85 stripping the tank sediment plugs the pump filters rather quickly. it's almost best to not even have it in there.
http://rotaryevolution.net
Old 04-01-2013, 05:49 PM   #249
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Nice to know! I've just ordered a replacement sock, once that gets in I'll swap the sock and have a peek to see if there is anything on the screen inside the pump as well.
As far as I'm aware the pump was only used for 100-200 miles previously as an inline pump mounted after a swirl pot. I don't know for sure if the previous owner ran E85 or not, I know that I have no intention of putting it in my car though.
I've got 1 week before my buddy arrives from England, 2 weeks before my wedding, and 3 weeks before DGRR...
My new "to-do" list is to replace the filter element in my fuelab filter, replace the sock on the 044, re-test. If that results in the appropriate amount of flow than I'll be super happy. If not... I'll get Jacks sweet, sweet, man-cheeks over here and test again while monitoring voltage.
Once my fuel flow is correct (ideally that won't require buying another pump) I'll get her on the dyno and get some numbers posted! (everybody loves dyno sheets! lol)
So far I've ordered the new filter element, and I'll be ordering the new sock as soon as I finish posting here!
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 04-01-2013, 11:44 PM   #250
DriFD3S
DriFD3S's Avatar
DriFD3S is on a distinguished road
Congratulations on getting married, and I hope that you can get your car done for DGRR.
Live the DriFD3S or die trying.
JDM True Story.
the Vacuum line, to my MAP became detached while I was legally drifting.
my engine would not rev past 2500, and idled from 300-650 and was stalling.
Fortunately, I acquired a Zip-Tie.
I fixed a catastrophic engine failure, With a Zip-Tie.
JDM FTW.
DriFD3S is offline   Reply With Quote
Old 04-22-2013, 01:56 PM   #251
hades
Knock. Knock.
Whose there?
Guess who.
Ok.
Hint....not oil.
Oh must be walked e shaft.
Correct! And his friend toasted bearings!
This is going to tear
Old 04-22-2013, 04:38 PM   #252
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
^ too soon?
Old 04-22-2013, 06:12 PM   #253
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Originally Posted by hades View Post
Knock. Knock.
Whose there?
Guess who.
Ok.
Hint....not oil.
Not exactly a normal scenario as per why that shit happened. Fucking sucks to be honest. Though I am SUPER glad you guys came by after me.
Poking fun like that isn't exactly cool, or appreciated, though.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 04-22-2013, 08:56 PM   #254
banzaitoyota
banzaitoyota is on a distinguished road
Suxors.........
My deuce
banzaitoyota is offline   Reply With Quote
Old 04-28-2013, 08:25 PM   #255
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
You're telling me... This time I'll rebuild it solo, hopefully I remember enough from the last build to get it all right.
If I'm lucky than most of the engine will be salvageable. It will be a crying shame if I need to buy new rotors and irons
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
