Old 02-06-2013, 10:51 AM   #1
New NGK BUR7EQ / BUR9EQ Spark Plugs
This might be old news for some of you...
I never realized that NGK redesigned these plugs recently?
It looks like there's a really minor difference in "reach" spec...
Also, the center electrode matterial has been changed?
The BIG difference is the with the "semi surface" tip to a regular, single electrode tip?
These what Mazda recommends for the RX-8 now?
Old 02-06-2013, 11:41 AM   #2
FC Zach
FC Zach's Avatar
Haven't noticed a thing, I'm getting set of 7s soon. I'll check to see if they're any different from the last set.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 02-06-2013, 11:42 AM   #3
FC Zach
FC Zach's Avatar
That's if I get a newly manufactured set of course.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-06-2013, 04:07 PM   #4
Are you saying they look like this?
That is a picture of the RX-8 spec Leading Plug (RE7C-L).
If so, that's weird since their catalog shows the old (ie: 'normal') style plug.
Old 02-06-2013, 05:59 PM   #5
Dannobre
Dannobre is on a distinguished road
Actually that would likely be the RX-8 Trailing plug
Dannobre is offline   Reply With Quote
Old 02-06-2013, 06:02 PM   #6
If that is the case, NGK is using the same picture for both leading and trailing plugs.
I have a set of NGK RX-8 plugs in the garage, but I'm too lazy to go check :-)
Old 02-06-2013, 07:22 PM   #7
I just bought two sets of BUR9EQ's and a set of whatever the colder plug for the 8 is..... lemme go check and see....
Old 02-06-2013, 07:29 PM   #8
Pete_89T2
Pete_89T2's Avatar
I just ordered a set of NGK BUR7EQP/BUR9EQP's from Rockauto, I'll let you know what they look like when I get them.
Old 02-06-2013, 07:45 PM   #9
That's where I got mine from.... Oddly enough, they are the cheapest....
Old 02-06-2013, 07:48 PM   #10
RX8 ones look like RX8 plugs, BUR9EQ's look like they always have
Old 02-07-2013, 05:00 AM   #11
Old NGK BUR7EQ PN#3559
http://www.summitracing.com/parts/ngk-3559
Brand: NGK Spark Plugs
Manufacturer's Part Number: 3559
Part Type: Spark Plugs
Product Line: NGK Standard Series Spark Plugs
Summit Racing Part Number: NGK-3559
UPC: 087295135594
Shorty Spark Plug: No
Resistor: Yes
Manufacturer Heat Range: 7
Electrode Core Material: Copper
Electrode Tip Material: Nickel alloy
Insulator Type: Non-projected
Spark Plug Thread Size: 14mm
Spark Plug Reach: 0.750 in.
Spark Plug Seat Style: Gasket
Wrench Diameter: 13/16 in.
Ground Strap Quantity: Four
NGK Part Number: BUR7EQ
Quantity: Sold individually.
New NGK BUR7EQ PN#6917
http://www.summitracing.com/parts/ngk-6917
Manufacturer's Part Number: 6917
Summit Racing Part Number: NGK-6917
Resistor: Yes
Electrode Tip Material: Copper
Spark Plug Reach: 21.5mm
Spark Plug Seat Style: Gasket Wrench Diameter: 13/16 in.
Ground Strap Quantity: One
Note between the two...
* Material - Nickel Alloy versus Copper
* Spark Plug Reach - 0.750 in. versus 21.5mm
* Ground Strap Quantity - Four versus One
Old 02-07-2013, 05:07 AM   #12
Old NGK BUR9EQ PN#5483
http://www.summitracing.com/parts/ngk-5483
Manufacturer's Part Number: 5483
Summit Racing Part Number: NGK-5483
UPC: 087295154830
Resistor: Yes
Manufacturer Heat Range: 9
Ground Strap Quantity: Four NGK
Part Number: BUR9EQ
New NGK BUR9EQ PN#5777
http://www.summitracing.com/parts/ngk-5777
Manufacturer's Part Number: 5777
Summit Racing Part Number: NGK-5777
Resistor: Yes
Spark Plug Reach: 0.846 in.
NGK Part Number: BUR9EQ
It looks like the 9's haven't changed as much as the 7's?
The reach spec has changed...
Better for us?
BTW, the "old" 7's and 9's are listed "N/A" from Summit.
Old 02-07-2013, 07:10 AM   #13
FC Zach
FC Zach's Avatar
That's odd.
This link has a generic image:
"Old NGK BUR9EQ PN#5483"
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 02-09-2013, 11:24 AM   #14
I would trust things from the manufacturer more than from Summit, they could've messed a few things up when they copied and pasted the info.... I dunno, I'm kinda want to see a new one next to an old one....
Old 02-09-2013, 01:13 PM   #15
Pete_89T2
Pete_89T2's Avatar
I just got mine from rock auto yesterday. No changes from the old style, but the box had the same part # (5255 and 4764) as the old style too, so no changes expected.
