05-07-2008, 10:30 PM | #1 | |
Rep Power: 20 |
Where to Mount Oil Pressure Gauge?
Hades brought this up in the 3rd gen section and I thought it would be a good topic to discuss.
So you want to monitor the Lubrication system in case of epic failure. I'd want to know where to plumb the system to. So, Where is the IDEAL place to mount the OIL PRESSURE Gauge probe? KEYWORDS: OIL, OIL*, PRESSURE, GAUGE, LUBRICATION, MOUNT
05-07-2008, 10:57 PM | #2 | |
rotors excite me
In the center of the front rotor.
jk idk
He isn't a killer. He just wins -- thoroughly. '87 TII 240+ rwhp on my DIY streetport, ~13psi on stock turbo, Racing Beat REVTII exhaust rTek 2.1 awaits a tune Quote:
05-08-2008, 01:22 AM | #4 |
Actually, that's the correct answer...
You want to *ideally* monitor oil pressure where it's doing it's job - at the bearings. If this feasible? No. The oil filter pedestal is a good, compromise location. It's aft of the rear OPR, so it's far away from the oil pump - pressure drops first from furthest point of pressure source. Plumbing an "adapter" isn't that much of a hassle - BIG plus here. Stock oil pressure sender is about the same location - Mazda knew something we don't? -Ted |
05-08-2008, 02:35 AM | #6 | |
rotors excite me
Oil pedestal is really easy to make aftermarket adapters to fit and it's also close to the firewall to run any lines you need into the dash for said adapters *shrug* I don't know if there are other reasons it worked well there.
