Old 01-15-2013, 06:24 AM   #1
Pettersen
EGT: how high does it need to log
So i bought a good open tip probe and an inexpensive signal conditioner wich uses any k-type probe and sends out a 5v signal.
It sends out 5v when the temp is at 990C/1800F, is that high enough to log?
The probes have operating temp from -100C to 1300C, so they should be good enough.
Old 01-15-2013, 07:05 AM   #2
RICE RACING
Don Mega
RICE RACING's Avatar
open tips do not last long term on rotaries, you need closed tips.
990 deg C is no where near high enough.
If you are using the power hard and often in 4th gear and 5th gear it will go over 1100deg C in regular basis.
My thread on Aquamist site talks extensively on the life of open tip probes, and also lots of information on temperatures logged on all kinds of tests too.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-15-2013, 07:29 AM   #3
Pettersen
Should probably mention that it's in an NA.
Won't be using the power that hard, not in 4 or 5 gear anyway. It's my dd, so it's only driven hard when i'm on trackdays a few days a year.
Tought the closed tip probes where to sluggish.
Old 01-15-2013, 07:42 AM   #4
RICE RACING
Don Mega
No I have checked them back to back and there is very little in it for response and true readings even in transient tests.
NA's still run high EGT, same levels especially cause you are running near 0.9 Lambda for high power so the EGT will be high, if not higher than on turbo! I have tested them on engine dyno's and the pipes become translucent and you can see the gas flowing through them! so very very hot.
All peripheral and bridge ports will run 1000deg C easy.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-15-2013, 01:58 PM   #5
Pettersen
Thanks for the answers.
I will be getting new signal conditioners then. And new probes once the open tip ones stop working.
