DGRR Archive Threads from Previous Deals Gap Rotary Rally Events. |
Dedicated Rotorhead
Rep Power: 17 ![]() |
Lets get it going, post up your post-holiday lunacy plans for your car(s), trucks, bikes, whatever.
I will be posting my list in a little bit, but I will just start with: -engine build -EMS install And I'll ask the burning question we all always have; What do you have NOT planned but are going to freak and do before DGRR, Brian? ![]()
DGRR 2013. |
Professional Stick Poker
OK, I'll play. Lets seee...
1. Replace rear suspension with full 3 link (in progress). 2. Fit and plumb new Cobra R brake system (sort of in progress) 3. Replace front suspension with Kenny Brown subframe and figure out how to fit front upper unequal length control arms. 4. Make the wheels I bought actually fit. (thus 1 & 3) 5. Annddd make it all look presentable before DGRR. Just a short little list, nothin' to it. ![]()
Paint drivers side of car
Reroute exhaust Rad and oil cooler mounts Find 13" street tires Windshield wipers installed
My deuce Last edited by banzaitoyota; 12-25-2012 at 08:41 AM. |
Gold Wheels FTW
Kick the RX7 and tell it to finish itself!? Sadly, it'll be a couple years till my FC is where I want it. At least I have the 8 for now.
Guess I can play seriously... Replace transmission Replace SSV valve Replace throwout bearing Replace end links
My Cars: 1974 RX4 Coupe 1991 FC3S RX7 - Sold 2003 ZZW30 MR2 (Rotary swap after RX8) 2004 SE3P RX8 (20B Swap in the works) |
shortblock swap, mount and paint body kit, new wheels and tires, maybe APR wing.
Rep Power: 22 ![]() |
I'll play.
RX-8 1) sell it Cosmo 1) rebuild brakes 2) rebuild rear differential (bearings/seals) 3) rebuild carb 4) rebuild front bearings/seals 5) new fluids 6) e-fan 7) upgrade alternator 8) upgrade ignition (electronic) 9) fix some rust 10) tires Hope all this works so I can drive it to DGRR. Otherwise 1) put gas in the Speed3 ![]()
#7 | |
Rep Power: 10 ![]() |
'98XJ - Official Rotary Support/Tow Vehicle - Northern Chapter Fixed Yoke kit and new diveshaft Install new flywheel Install New ACT Clutch ReGear both axles w/3.55 gears Some sort of locker in both Axles... would love to do an ARB airlocker but I need to see if it's compatible with the 3.07 gear in the axles now because I have bigger plans Install tranny/t-case Battery tray and jumper leads... this is a ROTARY support vehicle afterall A little rot repait - this may wait till next winter when I "freshen" the paint Build Rock Rails I'd LOVE to have an ARB front bull bar so I can build a reciever hitch for it... mmmmmm moving trailers from the front of a vehicle.... Electronic trailer brake controler; again.. because ROTARY Build rear hitch basket Rear cargo shelf and divider and tool box Diamond plate roof top storage box '88 FC - You all know this thing Build new exhaust mani Build new 4" exhaust from mani to bumpers Fix broken center panel Repaint bumper (yearly thing) and both fenders Bigger dual oil coolers mounted in a different location Redo brake ducting Re do engine and aux harness Meth tank Overflow tank New sub - Levi ![]() ![]() 500hp dyno sheet '04 FE Build new custom SS 3" exhaust from RB header back Find and kill clunk in the front end Wire in sunroof module for auto-close 2 subs in center pass thru rear-view camera?? 'Vert Finish engine harness Build W2A intercooler Install rebuilt rear Install rear suspension bushings Wire up the entire car build w2a water tank ... ya know what.... this is easier... BUILD ENTIRE FUCKING CAR
This begs the question, do I tow the duece up there. Remember my clutch change out in 2007 in the parking lot:-)
My deuce |
#9 |
That's why I'm bringing my Jeep.... any major problems... on the trailer she goes... jump in other rotary, have fun....
#10 | |
We stopped and asked if you needed help, but you can only fit so many dudes under an RX-2. Lol
#11 |
My list depends on car driven:
FD : change oil, coolant , kick tires add gas and enjoy. FB : pick the car up find tires/wheels to use the available HP, fix steering, detail car should fix trans and add USDM 5th gear instead of JDM one in it that SUCKS.
____________________________________________ 1976 Cosmo needing lots of work 1993 Rx-7 410 RWHP single turbo toy 1985 Rx-7 toy/project car 411HP stoplight terror 2001 Dodge ram 4wd.parts hauler 2016 Ram 2500 cause its a hemi 2006 VW TDI commuter __________________________________________ I guarantee there's a pregnant redneck teenager somewhere in a shitty trailer park that thinks "Ebola would be a lovely name for their child"... ![]() |
#12 |
Getting enough tire under there for that beast is going to be a challenge.
#13 |
Should I pack extras???
#14 |
Where are you finding 205/13's?
My deuce |
#15 |
![]() Yours? At least they'll match your Centerforce clutch disc. ![]()
Bookmarks |
Thread Tools | |
Display Modes | |
