Video--Can You ID this Sound???
Professional Stick Poker
Really hard to diagnose from a video. Almost sounds like a slight exhaust leak. Can you tell where the noise is coming from?
Cannot isolate "where". I was hoping it was the airpump, but the sounds seems to be coming from farther back than that.
thanks |
Take off the belts and run it for a short time. See if that helps.
It sounds like the rotor is touching the housing. Did you check this clearance? Did you change a rotor or gear/bearing assembly? This indexing is important. Barry |
Just drove it 200+ miles.
-water temp steady at 160F or below -vacuum steady at highway speeds at -16 -oil pressure steady at 55ish noise was still there at idle/low rpm at end of trip. thanks |
