Old 10-30-2012, 10:37 AM   #1
Pete_89T2
Pete_89T2's Avatar
SS brake line recommendations?
I'm looking to replace the stock flex lines between the calipers & hardlines with DOT approved stainless steel braided lines. Anyone have a brand to recommend?
Looking for high quality and perfect fitment, not too concerned about cost. Doing some shopping around online, it looks like DOT approved SS line sets for the S5 T2 are available from Goodrich, Russell and a few other brands within $10~$20 cost difference of one another.
Old 10-30-2012, 10:43 AM   #2
tweiss3
Mazda Lover
tweiss3's Avatar
I just installed Goodrich on mine, and they fit perfectly. I would go with them again given the chance.
Old 10-30-2012, 12:33 PM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
I have the DOT-approved lines from Mazdatrix on my GXL. I'm not sure if the lines are Mazdatrix in-house brand or sourced from somewhere else. Either way there've been no issues here.
Old 10-30-2012, 04:19 PM   #4
Did Goodridge (assumed "Goodrich") change their design?
I run a set on my car, and they were not drop-in perfect.
The hex fitting on the brake line side was different size than stock, and this made it a pain to secure properly on the mount tab on the shock.
Also, on the rear brake calipers, the stock lines have some kinda tab on them to keep the brake line from rotating?
(Don't quote me on this since this was YEARS since I've done this.)
My Goodridge lines did not have such a tab...
Old 10-30-2012, 08:43 PM   #5
tweiss3
Mazda Lover
tweiss3's Avatar
You are correct on the rears. The stockers had a round stock tab that goes in a spot on the caliper, the goodrich did not.
As for the fronts, they were dead drop in for me (swapped from single piston fronts to the T2 4 piston fronts) and they went into the tabs on the frame rail snugly, but fit well, and they attached to the hard lines easily.
Old 10-31-2012, 01:15 AM   #6
mattallac
mattallac's Avatar
mattallac is on a distinguished road
i have my brake lines made at a local shop , may be you can find a local place where you live and have some made . Usually shops that do hose repair for fork lifts and tractors do steel bradded D.O.T. brake lines . The guy I use in the bay area even captures my original fittings (oem is always my preference for good fitment ). My re speed brake lines were not D.O.T. and not the highest quality imo , but he probably farms them out . At my local shop I get 2 lines made for around 80.00 . Thats a better price than most of the mail order lines I see and the quality is second to none . Hope that helps
mattallac is offline   Reply With Quote
Old 10-31-2012, 05:35 AM   #7
Pete_89T2
Pete_89T2's Avatar
Thanks - lots of good info here. Those fitment issues Ted described are exactly what I want to avoid. The stock rear lines do have a tab/pin cast into the banjo fitting that helps orient it during assembly and prevents the banjo from rotating when torqued down.
Old 11-01-2012, 02:57 PM   #8
My5ABaby
My5ABaby's Avatar
I bought the Mazdatrix ones about 7 years ago and haven't had a problem yet.
Community Service Manual
RotorWiki
Old 11-23-2012, 06:16 PM   #9
Pete_89T2
Pete_89T2's Avatar
FWIW, I ended up picking up a set from Mazdatrix, which they apparently source from Goodridge, as the tags on the lines indicate. Anyway, unless they sent me the wrong set, these are NOT a drop-in fit. Mazdatrix isn't answering their phone today, probably off for the T-day weekend, so this job will wait till next week.
If I end up keeping these lines, they can be made to fit by grinding out the holes in the brackets a little bit for them to fit inside and clip properly just like the stockers. Took some measurements, and the round part of the new lines that is supposed to fit in the brackets is about 1/32" larger in diameter than the stock lines.
Old 11-23-2012, 07:18 PM   #10
infernosg
IT'S ALIVE!
infernosg's Avatar
Interesting. I don't recall having to do anything to get mine to fit. Did you get the DOT or non-DOT approved lines?
Actually, now that I think about this I did the brake lines the same time I installed my coilovers. I have the old style Stance GR+ coilovers and everything went together nicely. What suspension setup are you running?
Old 11-23-2012, 07:28 PM   #11
For the record, my Goodridge lines do not fit on Tokico Illuminas.
Old 11-23-2012, 10:56 PM   #12
Pete_89T2
Pete_89T2's Avatar
I'm running the KYB AGX adjustable struts, and I ordered the DOT approved lines. The thing is, the lines don't fit the brackets on the body side either, so it's not due to the aftermarket struts.
Old 11-24-2012, 05:59 PM   #13
tweiss3
Mazda Lover
tweiss3's Avatar
They were very tight for me, but did fit with a bit of pressure
Old 12-01-2012, 10:46 AM   #14
Pete_89T2
Pete_89T2's Avatar
Update - I called Mazdatrix last Monday to see if they might have sent me the wrong lines or if maybe the ones I had were defective/out of spec. Turns out they sent me the correct part #, but they also said that the fittings Goodridge uses from one batch to the next batch are often different. Apparently Goodridge only specs these fittings to match the type of hydraulic connection (e.g., banjo size and/or flare type & thread size/pitch). They don't spec the fitting's body diameter that is supposed to fit thru the stock brackets on the body or shock tubes. So bottom line is some batches will fit and some won't.
While we were on the phone, I asked the MT guy to take diameter measurements of a set of line fittings he had in stock (same part #), while I did the same with the lines I had for comparison. My lines were about 0.8 mm larger in diameter, which was enough to make it impossible to fit thru the stock brackets without a grinding job. They agreed to send me that "smaller" fitting set to swap out with, and did so with a UPS pre-paid label for the return shipment. I like good customer support - MT is a class act!
Replacement lines arrived yesterday, and I took comparison measurements against the stock rubber lines. Turns out this set is only 0.01 mm larger in diameter than the stock rubber line fittings, and should either drop right in or be tight fit. So the mystery of why some Goodridge lines fit and others (with same part #) don't has been solved.
