Old 07-17-2012, 02:08 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Ever hear of an engine conking out while cranking?
Today, I went to start my car ('86 n/a) and when the engine began turning, I heard a metallic clattering sound. I didn't think much of it, chalking it up to a heat shield rattling around or something. But, as I cranked it more, the car wouldn't start. I pulled the EGI fuse and cranked it for a while, and noticed I could hear the compression pulses out of the exhaust. They sounded even, but more spaced out than usual.
Fearing the worst, I busted out the compression tester and discovered 0 psi on the rear rotor.
The last time I drove the car (day before yesterday), it ran perfectly. I gave it a bit of a romp before pulling into my neighborhood, but it ran fine in the neighborhood and idled fine in the driveway before I shut it off. It didn't make any odd sounds when I shut it off.
What happened?
Old 07-17-2012, 02:34 PM   #2
bryant
bryant's Avatar
bryant is on a distinguished road
sorry to hear this and doubt the damage was done cranking it more than likely was done the other day.
and you should hear three pulses, so more spaced out pulse would sound to me like one or more apex seals missing - chipped and or broken.
how many miles are on the motor?
94T-78 (Want 500WHP)
bryant is offline   Reply With Quote
Old 07-17-2012, 03:15 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
204,5xx, I guess it was about time.
The front rotor compression is starting to get pretty low too, looked to be about mid-80s.
At least I can cannibalize this car to finish my other one now.
Old 07-17-2012, 03:28 PM   #4
bryant
bryant's Avatar
i would say you diff got your moneys worth out of that one
Old 07-17-2012, 04:20 PM   #5
Its a far stretch and very rare but low battery voltage and long dwells on aftermarket coils "can" crack a weak seal during cranking.
Most likely it was just your engines time to let go.
Old 07-17-2012, 06:41 PM   #6
need RX7
Clean S4 Nutswinger
need RX7's Avatar
le sigh. I'll throw in some ATF or something and let it sit for a few days before I go tearing into things, just in case.
On the bright side, if this car is finished, I can swap over my 5-lug equipment to my nice car, and all the brake and clutch hydraulic stuff, reducing my list of stuff to buy. If I do that, the only thing I'll need to buy to get it on the ground and running is a set of bushings.
Old 07-27-2012, 06:21 PM   #7
Tougemonster
Meat Popsicle
Tougemonster's Avatar
Tougemonster is on a distinguished road
I just had used motor seize on start up. It turned and fired normally, almost reached idle speed, then clunked pretty violent like. I'm tearing it down soon to see what happened. Thought it was carbon locked,still might be. I did break a 1/2 breaker bar trying to free it up though. Now i have swellbo, I thought N/A's weren't suppose to break this much
Tougemonster is offline   Reply With Quote
