Old 04-12-2008, 03:58 AM   #1
81gen1
81gen1 is on a distinguished road
squeaky brakes
ok, so my car supposedly had new brakes when i bought it a few weeks ago, but they started squealing really bad, so i replaced the pads. (the rotors are in perfect shape) the squeaking went away for a few hours, but now it's back.
any ideas?
1988 GXL-White
1985 GS-Red
1984 GSL-Primer
1983 Limited Edition-Champaign Silver-Full Suspension, Konig Rewinds
1982 GSL-Charcoal Grey-Weber 45, RB SP Exhaust, MSD Direct Fire
1981 GSL-White
1981 GS-Red, IMSA widebody, 3 piece Epsilons, Custom Exhaust
1981 GS-Blue
1980 SA-Black
1979 SA-Black Dragon Bodykit-White 12A Bridgey Turbo project
81gen1 is offline   Reply With Quote
Old 04-12-2008, 03:12 PM   #2
Kentetsu
Kentetsu's Avatar
Make sure that the shims are in place, and properly installed. If they are, then there is some goop you can buy to reduce squeeling.
Old 04-13-2008, 04:49 AM   #3
81gen1
shims?
1988 GXL-White
1985 GS-Red
1984 GSL-Primer
1981 GSL-White
1981 GS-Blue
1980 SA-Black
Old 04-13-2008, 08:20 PM   #4
Kentetsu
Kentetsu's Avatar
Go to www.rockauto.com and check out the Disc Brake Hardware Kit. For 10 bucks it has all of the little spring clips and stuff. There is also a brake pad shim kit, which is thin pieces of metal that go between the pad and the piston in order to reduce squeeling. Pick them both up for under 20 bucks and you should be all set.
Old 04-13-2008, 09:08 PM   #5
$100T2
Big Daddy
$100T2's Avatar
Shims and the sticky spray you are supposed to treat the pads with will do wonders.
Old 04-26-2008, 07:39 PM   #6
whitey85mtu
whitey85mtu is on a distinguished road
did you properly bed the pads?
whitey85mtu is offline   Reply With Quote
