Old 04-24-2008, 09:02 PM   #76
SpooledupRacing
Guest
Posts: n/a
Ok so tonight I have done the following...
put the tb elbow on and the coupler on got the intercooler piping on the drivers side on and the bov mounted
got the radiator in
thermostat in
coolant added
a couple hoses on
got the oil feed one
got the coolant feed on
got the coolant return on
I need the following yet
put the afm on
get a new bolt for the t-stat housing
get a radiator cap
get a vac hose for brake booster to uim
get some plastic put back on
here are pics of what I have done tonight
Old 04-25-2008, 09:45 PM   #77
SpooledupRacing
Guest
Posts: n/a
Ok well I got the last few things on.. checked my fluids etc and of course nothing can go off perfectly..
We pulled the fuel pump fuse cranked the engine to build oil pressure and 3 seconds into it the upper fuel rail sprung a leak... found out the banjo bolt was loose..
so we realised there was a leak and that we had the wrong fuse pulled... so we cleaned the engine off with water and tried again this time on purpose with the pump on to see if any other leaks happen
What do u know crank a few seconds and bam the lower rail leaks..
I tighten that bolt and pull both the fuses and crank till oil pressure comes up.. once that works we put the fuses in and crank 2 it took like 2 seconds and the car started and ran just fine...
we had it die because the throttle adjustment was not set right...
we turn the adjuster screw in so it will idle on its own and it fires right back up...
I let it run for about 45 minutes or so and it just smoked and smoked and smoked...
it still smokes if I start it.. Not sure how long it will smoke for but I know with the crisco, gear lube and engine oil used during the engine build process I figured it would smoke for a while..
after a while I turned the ca and found the low oil level light was on.. so I check the oil and it is fine... a little later it hit me.. I may have grabbed the n/a dipstick instead of the turbo dipstick... sure did so after adding another 2 liters it is just under full
The next thing I noticed was I had lots of bubbling in the cooling system so after that cooled down I pulled the bleed valve on the side of the radiator neck (again) and refilled the cooling system.. this time I am confident that it could be all done up..
now the biggest problem.. the batter wont hold a charge and it really is to big now with the ic pipes run ..
tomorrow I will get another battery, get it started back up and let it run for a while longer..
hopefully the smoke will go away...
Anyways I got 2 short videos.. NO SOUND SORRY.. but u can see the horrific amount of smoke...
as for the smoke shooting from the turbo in the engine bay well the downpipe was only held on by one nut, and I did not have a gasket on it because i only had one nut holding it on.. so one that is all tightned down I should be all set there..
Old 04-25-2008, 11:03 PM   #78
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Congrats!! looks like she's running strong.
Old 04-26-2008, 05:07 AM   #79
SpooledupRacing
Guest
Posts: n/a
is that amount of smoke or that long normal.
Old 04-26-2008, 09:41 AM   #80
Iox106
Iox106 is on a distinguished road
Yep
http://www.rotaryresurrection.com/2n...p_breakin.html
6) Be prepared for smoke…there is assembly lube in the engine, which will be burned out in the form of smoke. Expect this to get into your exhaust and smoke can remain for up to 8 hours afterwards until it is all burned out slowly.
Iox106 is offline   Reply With Quote
Old 04-26-2008, 12:17 PM   #81
SpooledupRacing
Guest
Posts: n/a
Thank you sir.. I feel much better now...
tonight I go for the first test drive
Old 04-26-2008, 06:51 PM   #82
SpooledupRacing
Guest
Posts: n/a
Well I have an external oil leak at the turbo, and it is still smoking now onto hour 3 of the break in.. blue smoke and lots of it...
The intercooler piping is dry, but I have oil just dripping out of the bottom of the turbo somewhere.. I cant figure out where...
all the lines are tight... I just don't know..
I think tomorrow I will pull the turbo off and recheck the mating surfaces of the turbo.. tighten it back down, check all of the oil drain bolts and make sure they are tight... make sure the oil drain tube is god and tight.. and go form there...
THIS SUX...
I have about 20 miles on the motor it runs very well, pulls very good, but cant be driven yet, not with the smoke and the leaking oil...
Old 04-27-2008, 07:21 AM   #83
SpooledupRacing
Guest
Posts: n/a
ok I pulled the turbo... the leak was coming from the oil drain.. easy fix...
here is what I see when I pulled the turbo off and started the car...
the first video is of the car just starting up then reving, unfortunatley the towel it was sitting on covered up the lens when I started to rev the car .
the second video is of the car just idling.. I stuck it down by the opening and then pulled away so u could see the smoke coming out of the engine bay
so are we thinking maybe the oil control ring spring may be moving and causing a leak.. or is this not that bad since I only have about 2 hours of running on it...
the liquid u see by the manifold is coolant.. I don't see any liquid oil coming out of the manifold.. and both the outlet of the turbo was dry and the cat was dry...
Vid 1
vid 2
Old 04-28-2008, 10:55 AM   #84
SpooledupRacing
Guest
Posts: n/a
Here is what the plugs look like after about 80 miles and 4-5 hours of running
Here you go Kevin. I did this this morning after the car had set overnight
Front plugs (leading plug on left, trailing on right)
Rear plugs (leading on left, trailing on right)
What if anything does that tell you?
Old 04-28-2008, 04:42 PM   #85
mm, not an expert by far, but it looks like you got an oil leak in the front, since the plugs are so fucked...
and the rears look nice and dry..not perfect, but much better.
Are these new plugs that you just put in right after the rebuild? Damn.. the fronts are scaring me.... but then I AM a bit of a n00b.
Old 04-28-2008, 09:09 PM   #86
SpooledupRacing
Guest
Posts: n/a
the fronts do look a touch wet but I don't think that bad...
and the turbo and manifold is clean
Old 04-30-2008, 12:44 PM   #87
SpooledupRacing
Guest
Posts: n/a
ok leak solved...
There was a bolt head on the compressor housing that was hitting the drain pipe. This was causing the drain pipe to not sit flush on the cartridge causing a leak anytime the car was running...
I will be putting the turbo back on tonight and going for a nice drive... if everything is cool she will be on the road full time tomorrow..
Total invested 13.00 in gaskets, labor FREE (had a show I do business with check it out and fix it for me)
Old 05-07-2008, 12:21 PM   #88
BadAzz84
BadAzz84 is on a distinguished road
uh....wasup!
BadAzz84 is offline   Reply With Quote
