		#46 |
			 IT'S ALIVE!
				Rep Power: 16 ![]()  |
			Engine shot with the revised fuel line:
	![]() I'm now working on mounting the AEM/Mercury Marine/IGN-1A coils. I think I'm going to mount them in a 2x2 arrangement as shown below: ![]() I'' probably align the terminals versus staggering them as shown above as it makes accessing the connectors a little easier. They're got to go somewhere in this area: ![]() My original plan was to mount them on the strut tower but with the alternator relocated that area's getting pretty crowded. I'm thinking about mounting them behind the headlight where the stock leading coils were mounted. This makes for longer spark plugs leads and I'd need to extend some wires but over all I think it's a cleaner location. I just need to make sure the leads stay away from the CAS wires!  |
		#47 |
			 IT'S ALIVE!
			Just about done mounting the IGN-1A coils in the car. Here's some in-process shots while the bracket is being painted.  Test fitting the bracket in the car:
	![]() A little closer: ![]() It's pretty simple really; just two pieces of 1/8" flat stock formed to shaped and drilled a couple times. My welds still suck but it'll hold. ![]() ![]() Pretty simple again. Six 1-1/2", four 1" spacers, and some 10-1/2" sections of all-thread and the coils are mounted. I plan to run the spark plug wires together up by the main fuse box and then down to the spark plugs. Once I have everything finished and mounted I'm going to take some measurements and give a call to Magnecor for some custom length 10.5 mm wire.  |
		#48 |
			 Professional Stick Poker
		  Looking good. That should keep the fires lit.
	1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585  |
		#49 |
			I am truly jealous, that engine bay is becoming a work of art! I wish I hadnt bought a car with all the factory nasty undercoating now... Oh well! Too late now!!
		#50 | |
			 IT'S ALIVE!
 I've finished the bracket and started wiring the coils (switched 12V and trigger done so far): ![]() I've decided to arrange the coils as L2, T2, L1, T1 from left to right. This should result in the shortest possible leads. Ignore the wire tied to the T1 post; I was using it to determine the lengths needed for the leads. Once the coils are done the only wiring that remains is the IAT, starter and alternator, and then I can wrap everything up. Two tasks I've yet to start that I'm not looking forward to are depowering the steering rack and ducting the radiator and fan.  |
		#51 |
			 Rotary Masochist
				Rep Power: 18 ![]()  |
			The way you have the trigger wires routed right across the alternator and, presumably, right under or over where the ignition leads will lay is asking for noise issues.  No reason not to run those right down the middle of the engine to avoid extra length and noise from the alternator and ignition.
	_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI  |
		#52 | |
			 IT'S ALIVE!
		#53 |
				Rep Power: 19 ![]()  |
			Agreed with C. Ludwig here about the alternator...
	The alternator actually runs AC - alternating current - internally and then runs through a rectifier to produce the DC that the vehicle can use. It's the AC that causes all the headaches in terms of RFI. In terms of dealing with the shielded wiring... Cheap way is to use aluminum foil (on the junctions). You can then tape over it with electrical tape so it doesn't look as bad. They do make metallized (shielding) tape for a step up from aluminum foil. -Ted  |
		#54 |
			 IT'S ALIVE!
			I moved the trigger wires last night.  Fortunately there was no wire extending required and it looks like I'll be able to take some length out.  Thanks for the tip!
	Still working on the coils. Just trying to figure out how to run the grounds. C. Ludwig, is the preferred grounding method of the AEM coils still to gang them all together and ground them to the block versus what the wiring guide says? I seem to recall having this conversation with you but I can't find the correspondance.  |
		#55 |
			 Rotary Masochist
			I always send them all to the rotor housing or head.  It's convenient and works.  Basically, two of the grounds are kind of along for the ride and won't influence performance.  The high current (Pin D) is the one you need to have well sorted.  If the block ground is marginal, (which it should not be!) then go to the battery.  Better yet, ensure you have good grounding of the block to the battery negative post and then ground all 3 pins of the coil to the block.
		#56 | |
			 IT'S ALIVE!
		#57 |
			 Rotary Masochist
			IMO you need a minimum of 4 ga running from the battery negative post directly to the engine.  This is the way I setup all relocated batteries.
		#58 |
				Rep Power: 10 ![]()  |
			Could not agree more.  I can't tell you how many electrical headaches are caused by poor grounds.
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
		#59 |
			 IT'S ALIVE!
			I've got it all worked out now.  I had a good ~15 minute call with Chris yesterday and got everything straigtened out.  I redid my engine ground and now I have a 2 AWG cable running from the battery negative terminal to the top of the rear rotor housing.  The same point serves as the grounding location for the coils and a 4 AWG wire connects it to the firewall for the chassis ground.  With this better engine ground hopefully I can avoid having to run dedicated ground wires to the alternator and starter bodies.  I'm still debating if I should add an additional 4 AWG ground from the battery negative terminal straight to the chassis.
		#60 |
			 Mazda Lover
			I could never hurt, and will take only 5 minutes to do.
	![]() 2004 Mazda6 V6 5-spd - still waiting on money for a motor 1991 Mazda RX7 NA 5-spd - my new DD with 145,000 miles  |
