Old 06-17-2012, 05:46 AM   #226
Tegheim
Tegheim is on a distinguished road
You mean that the combusion is not the same all over?
Tegheim is offline   Reply With Quote
Old 06-17-2012, 07:59 AM   #227
Pettersen
It refers to the shape of the combustion chamber.
LDR = Leading deep recess Good performance high emissions.
MDR = Middle deep recess Compromise to get down emissions.
Old 06-17-2012, 10:06 AM   #228
Libor
Libor is on a distinguished road
Well, I have seen too much data on this stuff so I forget most, but looking at "Recent Technology Development of High-powered Rotary Engine in Mazda", its clear that MDR design produces highest BMEP from all tested variants, especially in the top-end. Note: this is with both spark plugs. Second best was "leading flat" recess and LDR design was third as far as power goes.
With leading only ignition, leading flat was best and LDR/MDR were about the same at the top-end, LDR slightly better in midrange, but both considerably worse than leading flat variant. But the point is moot since the most people do use both spark plugs.
IIRC R26B and 13G also has MDR rotor pockets. Maybe this desing has bad name due to Renesis rotors, but their problem probably lies much more in inferior gas sealing - low dynamic compression.
Libor is offline   Reply With Quote
Old 06-21-2012, 07:39 AM   #229
Tegheim
Huh?!
Old 06-21-2012, 09:49 AM   #230
Tegheim
Finished the lower brackets for the Coilovers.
Have changed my Cad a little. Moved the bracket 50mm to the center of the car, to gain 61.5° angle on the coil at rideheight, and 66.0° angle at full bump.
This is what it looked lite before the change.
Old 06-21-2012, 12:13 PM   #231
Tegheim
Time for welding!
Old 06-24-2012, 07:45 AM   #232
Tegheim
Today I got the spindle-surface straightend.
To be sure that the caliper and disc are in level.
And also, to get a fine surface to attach to.
Old 06-30-2012, 09:46 AM   #233
Tegheim
I did some stabilizer bar knifes a while ago.
I am also satified with the IFS now. This will give me som adjustments and will be good at both road and hopefully track.
Today I worked a little in the CNC.
Turned out pretty good.
Old 06-30-2012, 12:13 PM   #234
Monkman33
Still Building my FD
Amazing work. Really!
Uh.... hi.
Old 06-30-2012, 11:51 PM   #235
lokirx706
lokirx706's Avatar
lokirx706 is on a distinguished road
Amazing, I have worked with CNC in the past, but this is well over my head... Excellent build thus far! Cant wait to see it finished!!
lokirx706 is offline   Reply With Quote
Old 07-01-2012, 08:24 AM   #236
RICE RACING
Don Mega
RICE RACING's Avatar
Reminds me of designing and building fabricated uprights (and all other parts!) for our Formula SAE cars back and the University I worked at ......... so so so many hours of work and I can relate to what you are doing!@
Keep it up.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 07-01-2012, 01:40 PM   #237
Weltall
Weltall's Avatar
Weltall is on a distinguished road
This is mind blowing! Hurry and get this done so I can buy one from you to put in my Opel GT!
Weltall is offline   Reply With Quote
Old 07-01-2012, 05:02 PM   #238
Yoshi
Yoshi's Avatar
Yoshi is on a distinguished road
This is quite the excellent build, sir!
-bump steer makes driving more exciting- (>_<)
Yoshi is offline   Reply With Quote
Old 07-01-2012, 07:32 PM   #239
I want to make sweet, sweet love with this build.
I may have to pick your brain in a few years about some of your engine stuff. Consider yourself warned.
Old 07-01-2012, 07:37 PM   #240
Raksj04
I have Ultra power in me.
Raksj04's Avatar
I still wish I had half of the skill to do this.
