#226 |
Rep Power: 15 ![]() |
You mean that the combusion is not the same all over?
#227 |
It refers to the shape of the combustion chamber.
LDR = Leading deep recess Good performance high emissions. MDR = Middle deep recess Compromise to get down emissions. |
#228 | |
With leading only ignition, leading flat was best and LDR/MDR were about the same at the top-end, LDR slightly better in midrange, but both considerably worse than leading flat variant. But the point is moot since the most people do use both spark plugs. IIRC R26B and 13G also has MDR rotor pockets. Maybe this desing has bad name due to Renesis rotors, but their problem probably lies much more in inferior gas sealing - low dynamic compression. |
#229 |
Huh?!
#230 |
Finished the lower brackets for the Coilovers.
![]() ![]() Have changed my Cad a little. Moved the bracket 50mm to the center of the car, to gain 61.5° angle on the coil at rideheight, and 66.0° angle at full bump. This is what it looked lite before the change. ![]()
#231 |
![]() Time for welding! |
#232 |
Today I got the spindle-surface straightend.
To be sure that the caliper and disc are in level. And also, to get a fine surface to attach to. ![]()
#233 |
I did some stabilizer bar knifes a while ago.
![]() I am also satified with the IFS now. This will give me som adjustments and will be good at both road and hopefully track. ![]() ![]() ![]() Today I worked a little in the CNC. Turned out pretty good. ![]() ![]()
#234 |
Still Building my FD
Rep Power: 17 ![]() |
Amazing work. Really!
Uh.... hi. |
#235 |
Amazing, I have worked with CNC in the past, but this is well over my head... Excellent build thus far! Cant wait to see it finished!!
#236 |
Don Mega
Reminds me of designing and building fabricated uprights (and all other parts!) for our Formula SAE cars back and the University I worked at ......... so so so many hours of work and I can relate to what you are doing!@
Keep it up.
#237 |
This is mind blowing! Hurry and get this done so I can buy one from you to put in my Opel GT!
#238 |
This is quite the excellent build, sir!
-bump steer makes driving more exciting- (>_<) |
#239 |
Rep Power: 20 ![]() |
I want to make sweet, sweet love with this build.
I may have to pick your brain in a few years about some of your engine stuff. Consider yourself warned.
#240 |
I have Ultra power in me.
I still wish I had half of the skill to do this.
