Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Defined Autoworks
Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Roll Cage Builds, Unique Fabrication and Transplants
Old 06-02-2012, 11:30 PM   #1
GtoRx7
GtoRx7 is on a distinguished road
700+ Rwhp 13b-rew/re hybrid built engine. *sold*
Here is a really rare and awesome opportunity to buy a full race semi p-port 13b. For those unfamiliar semi p-port is what you see running 6 and 7 second quarter miles. Even better is that this setup is VERY streetable. Slightly more streetable than a bridgeport! Totally reliable as well.
A lot went into this build-up so I will carefully go over all the details, and even better post all the build photos! You can see every last part that went into this badboy. No black box engine purchasing!
Engine irons- 13b-rew irons, defined autoworks circuit port. Runner ported to RE large spec. All of them have been fully lapped for a perfect surface and compression
Engine housings- excellent condition FD 13b-rew rotor housings. Exhaust port is Defined Autoworks race turbo port.
Semi p-ports- We then proceeded to do our legendary semi p-port on the rotor housings. This is the same combo that yeilded the highest horsepower numbers around.
Series 4 turbo II rotors- This engine has the ultra strong and high boost friendly S4 low compression rotors. To enhance them further and make safe for 8500-8800 rpm we race clearanced them too!
FD eccentric shaft- This is the strongest e-shaft around, and we added extra clearance for high boost
FD stationary gears- The RE engine has big ports but the stat gears are just FC stuff. We installed FD gears with race clearanced bearings too
Oversize tension bolts- The housings all were machined and tapped to accept goopy oversize tension bolts. This combo with FD irons makes for a solid block to 900rwhp!
Uses a FD oil pressure regulator (110psi)
2mm goopy apex seals- Suitable for 8500-8800 rpm and lots of horsepower. Proven apex seals for durability.
Solid 2mm corner seals- Atkins makes the best solid corner so this was a no brainer
All FD corner seal springs and side seal springs- The FD uses the highest grade springs
New FD oil pump
Come with complete FD intake, KG parts secondary rail (tossed in some 1200cc injectors too) and modified lower intake that is setup for semi p-ports. No fab work needed!
Underdrive lightweight aluminum pulley included!
The pricing on this engine if a customer had us do all the work would be this-
13b-rew engine from japan $1600
S4 turbo rotors $600
Semi p-port for two housings $900
Circuit porting on 4 intakes $450
Turbo race porting on exhaust $150
Porting to RE spec on runners, port match manifold $300
Rotor clearancing $300
Side housing lapping $300
13b rebuild, clean and assemble with all new springs and seals $2400
Oversize tension bolts $175
Machine work for tension bolts $250
Solid corner seals $120
Modified lower intake for semi ports $500
New oil pump $165
$8210 total regular price!!
Selling here at a total steal for $5700!
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
Old 06-02-2012, 11:32 PM   #2
GtoRx7
DEFINED AUTOWORKS
Old 06-02-2012, 11:34 PM   #3
GtoRx7
DEFINED AUTOWORKS
Old 03-08-2013, 07:19 PM   #4
specs
specs is on a distinguished road
whats the hp on the motor
and how high is the redline
how reliable is this motor
Is this Motor still for sale
specs is offline   Reply With Quote
Old 03-11-2013, 08:05 PM   #5
GtoRx7
The HP depends on the boost really. RPM capacity is 8500. It sold a while ago unfortunately. Good news is I have another engine almost assembled that is much like this one.
Its a 13bre/ 13brew hybrid, largest runners but with the fattest dowel pin castings. Half bridge port on secondaries/ street port primaries. Goopy apex seals 2mm, FD rotors/ race clearanced. Oversize tension bolts, resurfaced and nitrated side housings. New rotor housings, RE intake manifold.... fuel rails... etc etc. Nice motor
DEFINED AUTOWORKS
Old 06-07-2013, 10:50 AM   #6
afgmoto1978
afgmoto1978's Avatar
Price?
Old 06-09-2013, 01:44 PM   #7
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
right before all the pictures start, he has a price set at $5,700
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 12-22-2013, 07:36 AM   #8
Black7Conv
Black7Conv is on a distinguished road
if you ever have a semi p-port 13b engine for sale, please send me a pm.
thanks
Black7Conv is offline   Reply With Quote
